Electronic problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2006, 09:54 PM   #1 (permalink)
news
Guest
Posts: n/a
View news's Photo Gallery
Electronic problem
I have a very old camery'91. Two days ago I washed the engine compartment
using tap water while the car was warm after running. Only the battery was
covered by plastic bags. Now I have some electronic problems. The charging
and brake signals are always on the meter panel. It looks there is indeed
charging problem because the car could be started only by boost. I do not
know what the brake signal does since no any brake was engaged.
Any comments for what may have been damaged ? Thank you for any help in
advance.
Ron
Old 05-30-2006, 11:26 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Electronic problem
"news" <y.miao@sympatico.ca> wrote in message
news:nI6fg.932$Su3.86227@news20.bellglobal.com...[color=blue]
> advance.
> Ron
>[/color]
You probably soaked the alternator, or dislodged some wiring. Make sure the
wiring to the alternator is tight, as is the wire coming out of the brake
master cylinder. Make sure that the cover on the master cylinder is on
tightly. If it is loose, the brake fluid is probably contaminated and will
need to be changed ASAP. If the alternator is wet, you can try blowing it
dry with a hair drier on low heat setting.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 02:45 PM
weird electronic problem, need help quick! afyouthbrigade Camry & Solara Lounge 8 09-29-2005 05:06 PM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 05:31 PM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 02:33 PM
Camry electronic problem speedemn Camry & Solara Lounge 13 01-20-2002 06:52 PM
