Re: 1999 Civic transmission problem
"Jeff Bertrand" <wjbertrand@NOSPAMearthlink.net> wrote in message
news:wpafg.7191$921.1814@newsread4.news.pas.earthlink.net...[color=blue]
> Hi All, new to the group. We just picked up a very clean '99 Civic EX
> 2-door automatic for my daughter's first car. Lately it's been
> shuddering,
> slipping a shifting harshly, mostly when pulling away from a stop. Seems
> to
> run OK once up to speed though. Coincident with this behavior the CEL
> illuminates. Retrieving the error code with a scanner reveals a code
> "PO730 - Gear Ratio Incorrect" is present. This seems to be consistent
> with
> the poor shifting performance. Any clues as to what's wrong? Automatic
> transmissions are scary things as they are usually very expensive to fix.
> -WJB
>[/color]
You might want to try the Honda group, but before you do that:
Check the condition of the automatic transmission fluid and make sure it is
red and not brown or black.
When you scanned the codes, did you check to see if there is more than 1
code? A malfunctioning shift solenoid can cause problems.
Ray O
