snapped antenna - how to repair/make do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-21-2006, 07:27 PM   #1 (permalink)
vpallaver@gmail.com
Guest
Posts: n/a
View vpallaver@gmail.com's Photo Gallery
[url]http://tinyurl.com/gh2jr[/url]
1991 Corolla. Above is a link to a picture of the radio antenna on my
car. Or rather, what's left of it after the neighborhood kids walked
by it this afternoon. They snapped it off, you can see the little stub
that sticks out. This is not a power antenna, and it lives on the
strut between the front windshield and the driver's window. I
unscrewed the black assembly, but it doesn't help much - the antenna
and ground wires are not detachable from the assembly. I can't reach
the back of my stereo. I went to the Kragen, but they didn't have
anything useful (they had cheap replacement antennas if I could simply
plug it into the stereo).
Oh, and my radio reception is severely compromised now.
So the question is, what is the simplest way to get radio reception
back? Does it involve coat hangers, solder, or ball point pens and
swiss army knives?
v
Old 06-21-2006, 08:45 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: snapped antenna - how to repair/make do?
<vpallaver@gmail.com> wrote in message
news:1150932421.474837.111890@b68g2000cwa.googlegroups.com...[color=blue]
> swiss army knives?
> v
>[/color]
The simplest way to get radio reception back is to jam a coat hanger in the
hole so that it touches the remaining antenna nub. The best way is to get a
replacement antenna from your local Toyota dealer.
Reach around behind the radio - you may be able to unplug the antenna
without having to remove the radio, and then pull the antenna coax cable out
through the A pillar (the pillar that the antenna is mounted on). If you do
not want to mess with the antenna connection behind the radio, go to Radio
Shack or electronics store and get a female RCA connector plug for the
coaxial cable. Snip the old coaxial cable where it attaches to the old
antenna mast and attach the female RCA connector plug to the old cable.
Attach the male RCA plug to the newly installed female plug, and pull the
new coax through the opening and under the dash, install the new antenna,
and secure the excess cable under the dashboard with twist ties or plastic
zip ties.
Ray O
Old 06-22-2006, 01:37 PM   #3 (permalink)
steve-o
Guest
Posts: n/a
View steve-o's Photo Gallery
Ray O wrote:[color=blue]
> news:1150932421.474837.111890@b68g2000cwa.googlegroups.com...[color=green]
> > swiss army knives?
> > v
> >[/color]
> zip ties.
> Ray O
> (correct punctuation to reply)[/color]
Here's what I did.. Faced with the same problem. I went to the toyota
dealer thinking it was an easy fix. Well I was in for a rude
awakening... when the parts mgr explained snaking the thing to the
radio, I said o.k. forget it. I found an old CB radio antenae I BROKE
OFF the very top because it looked like it would fit and was long
enough to hit the base. Well, it worked like a charm till the day I
traded it in w/ 255,000 miles. I guess you can find any metal rod with
a diameter small enough and long enough it will work and look fine.
just slide it in and you're done if it jars around here is always duct
tape...
- Good Luck!!
BB code is Off
Smilies are Off
[IMG] code is Off
Original Wires for Factory Power Antenna... JayMax03 Audio, Video, and Security - Tech 3 06-22-2006 02:02 AM
Can't get stations... Antenna help!! nat77 Camry & Solara Lounge 10 05-17-2005 11:24 PM
someone snapped off my antenna :( Colleenie82 Audio, Video, and Security - Tech 1 03-31-2005 01:52 PM
S2000 Antenna HELP! phat555 Camry & Solara Lounge 25 01-25-2002 08:00 PM
