MPG Indicator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2006, 10:51 AM   #1 (permalink)
matthewclydehavard
Guest
Posts: n/a
View matthewclydehavard's Photo Gallery
MPG Indicator
Is there a MPG Indicator one can buy and personally install on his/her car?
Old 06-22-2006, 12:57 PM   #2 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
Re: MPG Indicator
On Thu, 22 Jun 2006 14:51:14 GMT, "matthewclydehavard" <u23312@uwe>
wrote:
[color=blue]
>Is there a MPG Indicator one can buy and personally install on his/her car?[/color]
Sure....
An inexpensive calculator.
Old 06-22-2006, 01:29 PM   #3 (permalink)
steve-o
Guest
Posts: n/a
View steve-o's Photo Gallery
Re: MPG Indicator
matthewclydehavard wrote:[color=blue]
My 2006 Solara has one. It does a few things. 1. AVG MPG 2. Actual
MPG(While driving you get a real time reading of how many gallons per
mile you're consuming. Don't know how accurate it is 3. AVG MPH. 4.
Driving Range(Miles left before you run out of gas). 5. ETZ - haven't
looked at that one yet.. :) . So I fugure you should be able to get
one.- Good luck
Old 06-22-2006, 02:02 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: MPG Indicator
"matthewclydehavard" <u23312@uwe> wrote in message news:62285862d97f8@uwe...[color=blue]
> car?[/color]
I've seen aftermarket trip computers that have instantaneous and average MPG
readouts but they are not easy to install for someone without pretty
thorough knowledge of automotive systems. You have to install a magnet and
reluctor on the driveshaft, calibrate distance for driveshaft revolutions,
install fuel flow sensors in the fuel line, and then wire everything up.
The best way to calculate MPG is to record distance traveled between fillups
and use a calculator.
Ray O
Old 06-22-2006, 02:42 PM   #5 (permalink)
B A R R Y
Guest
Posts: n/a
View B A R R Y's Photo Gallery
Re: MPG Indicator
steve-o wrote:[color=blue]
> Actual
> mile you're consuming. Don't know how accurate it is[/color]
Theoretically, this could be very accurate. All it requires is a simple
fuel flow rate vs. ground speed calculation.
If Toyota chose to make it accurate may be up for discussion.
Old 06-22-2006, 05:16 PM   #6 (permalink)
mack
Guest
Posts: n/a
View mack's Photo Gallery
Re: MPG Indicator
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:115c8$449adcab$44a4a10d$32105@msgid.meganewsservers.com...[color=blue]
> news:62285862d97f8@uwe...[color=green]
>> car?[/color]
> fillups and use a calculator.[/color]
[color=blue][color=green]
>>[/color][/color]
Or the back of an envelope or shopping list.
simple divide the mileage driven by the number of gallons on your fillup.
200 miles divided by 10 gallons means you've gotten 20 miles per gallon.
But you knew that.
Old 06-22-2006, 07:15 PM   #7 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: MPG Indicator
wrote:
[color=blue]
They have one at thinkgeek.com that plugs into the OBD-II computer
connection, sticks on the dash, and gives you instantaneous and
average MPG, as well as a lot of arcana like temperature and pressure
sensor readings from around the car. Isn't cheap, somewhere around
$150.
Of course, if you're asking about a 1980 vehicle that isn't even EFI
(let alone OBD-II compliant) you're out of luck with that one...
--<< Bruce >>--
Old 06-22-2006, 07:46 PM   #8 (permalink)
Built_Well
Guest
Posts: n/a
View Built_Well's Photo Gallery
Re: MPG Indicator
Warning: The following is an **OFF TOPIC** tangent to this thread.
OFF TOPIC:
You all seem to be pretty knowledgeable when it comes to
electrical matters. So I thought I'd ask if it's advisable to
plug your television and other entertainment equipment into
a regular computer-type UPS (Uninterruptible Power Supply)?
I know you're not suppose to plug a laser printer into
a UPS--tried that at home a few years ago, and fried the
whole computer. Oh oh. Computer said bye-bye for good.
(Luckily it was an old computer.)
But would a UPS work with a 32-inch CRT television, DVD, VCR, etc.?
By the way, here's a great deal on a UPS. As of 2 or 3
days ago, Best Buy has been selling the Geek Squad 685 VA UPS for
an unheard of $20 plus about another $12 for shipping (6 outlets, 3
with battery backup). Get yours while supplies last! Got mine 2
nights
ago. Hope they're still available for you at this link:
[url]http://www.bestbuy.com/site/olspage.jsp?skuId=6819552&productCategoryId=cat08029&type=product&tab=1&id=1091101368673[/url]
Old 06-22-2006, 08:59 PM   #9 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
Re: MPG Indicator
On 22 Jun 2006 16:46:58 -0700, "Built_Well"
<Built_Well_Toyota@hotmail.com> wrote:
[color=blue]
>OFF TOPIC:
>But would a UPS work with a 32-inch CRT television, DVD, VCR, etc.?[/color]
The laser printer was too big a load for the UPS, and they always
tell you NOT to do that in the instructions - I'm surprised it didn't
blow the UPS. Printers are not a critical item, you can always
reprint it later - they're meant for running the CPU and monitor, and
critical stuff to keep the net connection up like the DSL or Cable
Modem and the Ethernet Hub only.
If the computer went, it was probably the power supply that didn't
like being feed 40 volts. If the power supply failed gracefully (it
didn't short through and send high voltage to the motherboard and fry
everything) it's probably recyclable as spare parts or for a childs'
first computer. (If they break an old one, no big loss.)
The UPS can feed any electronic load IF it's big enough. The
question being why would you want the TV to keep going? If you are
going to protect anything, you plug the Tivo and the Cable or
Satellite Box into it, so your recordings aren't interrupted.
[color=blue]
>nights ago. Hope they're still available for you at this link:[/color]
No thanks, I get the 1100VA models with full-size batteries at
Costco for around $90. Those "power-strip sized" UPS's are sold as a
placebo for desktop machines at offices. They only have enough
battery power for about 5 minutes at full load, and that's not enough
time for an orderly shutdown if you are in the middle of burning a CD,
or something that can't be interrupted like installing new software.
The full-size units will go 20 to 40 minutes at full load, and if
you deliberately oversize it one notch you can get a few hours.
--<< Bruce >>--
Old 06-22-2006, 09:20 PM   #10 (permalink)
Built_Well
Guest
Posts: n/a
Re: MPG Indicator
Bruce L. Bergman wrote:[color=blue]
> I'm surprised it didn't blow the UPS.[/color]
Bruce, thanks very much for the advice.
Umm, I wasn't clear. Everything went bye-bye that
day: the power supply, the motherboard, the UPS... The only
survivor was the laser printer.
I was thinking of plugging the television into the
UPS so I wouldn't have to reset the TV's time--not that I'm
wacky enough to actually watch the tube during a storm-created
blackout [heh].
Old 06-22-2006, 10:14 PM   #11 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: MPG Indicator
On Thu, 22 Jun 2006 16:46:58 -0700, Built_Well wrote:
[color=blue]
> OFF TOPIC:
> nights
> [url]http://www.bestbuy.com/site/olspage.jsp?skuId=6819552&productCategoryId=cat08029&type=product&tab=1&id=1091101368673[/url][/color]
Actually, you're not even supposed to plug a Laser Printer into a Surge
protector. Something about the way they and UPS's work makes the fuser go
batty and they fail real fast.
Finally, after I replaced 5 fuser units for a PUC they FINALLY unplugged
it from the S.P. (they thought I was 'funning' them...they then sent out a
company wide mandate to unplug ALL the laser printers from SP's and UPS')
Old 06-22-2006, 10:18 PM   #12 (permalink)
Hachiroku
Guest
Posts: n/a
Re: MPG Indicator
On Thu, 22 Jun 2006 14:16:46 -0700, mack wrote:
[color=blue]
> news:115c8$449adcab$44a4a10d$32105@msgid.meganewsservers.com...[color=green]
>> news:62285862d97f8@uwe...[color=darkred]
>>> car?[/color]
>[color=green][color=darkred]
>>>[/color][/color]
> But you knew that.[/color]
But that's not Kewl!
I use the 'computers' in my Chryslers all the time to 'modify' my driving.
I was doing 55 in a 40 one time on a back road and saw the blues. The cop
asked if I knew how fast I was going. Um, I have an idea. He asked me if I
was being a wise guy. I said, no, pointed to the readout and said, at this
time of the day, on a clear road, THAT'S the meter I go by. I was getting
45 MPG with my LHS!!! He let me go, with the words...Look at the OTHER
meter more often!
Old 06-22-2006, 10:26 PM   #13 (permalink)
Built_Well
Guest
Posts: n/a
Re: MPG Indicator
Hachiroku wrote:
[color=blue]
> company wide mandate to unplug ALL the laser printers from SP's and UPS')[/color]
Dang! You'd think a company would know better! Glad you set
them straight. Whew....
Old 06-22-2006, 10:34 PM   #14 (permalink)
Built_Well
Guest
Posts: n/a
Re: MPG Indicator
> ....and they always tell you NOT to do that in the instructions[/color]
[Chuckle] My laser printer didn't come with instructions. I got
it really cheap at a garage sale. My 'puter and I had to learn from
the
school of hard knocks.
Old 06-23-2006, 12:16 AM   #15 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
Re: MPG Indicator
On 22 Jun 2006 18:20:22 -0700, "Built_Well"
<Built_Well_Toyota@hotmail.com> wrote:[color=blue]
>Bruce L. Bergman wrote:[/color]
>survivor was the laser printer.[/color]
Sounds more like a lightning strike - and when that happens, all
bets are off.
Your only defense is to install a big whole-house lightning arrestor
at the main panel, and beef the hell out of your grounding and bonding
system so it has a way and a place to dump the surge.
And get your utility to beef up the lightning arrestors on the pole,
because that's the main path the surges follow in. Lightning doesn't
hit your house nearly as often as that nice tall power pole behind it.
[color=blue]
>blackout [heh].[/color]
RTFM, or go buy a new TV - almost all the new gear on the market
reads a timecode on the PBS or Local Commercial broadcasts and sets
it's own clock. The flashing 12:00 is practically extinct.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
Many of you guys seem curiously unaffected by gas mileage mattxwill 2nd Generation (2005+) 155 12-13-2010 04:18 PM
You want better fuel economy? Demand a diesel shampooguy Archived Corolla threads 59 06-01-2007 03:14 AM
Toyota MPG ratings laphan General Discussion 12 06-18-2006 10:30 AM
