My brake back lights are on? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-23-2006, 05:34 PM   #1 (permalink)
duckiegirl
Guest
Posts: n/a
View duckiegirl's Photo Gallery
My brake back lights are still on when i turned off the car and the igintion,
i dunno why but yesterday i moved my car and then i turn around and saw my
brake back lights are on, its been on evey since last night, until i pulled
out the plug in the back trunk, so it wont kill my battery. I need help if
anyone has any clue or similar cases liek this please message me back thanks
<3 girl
Old 06-23-2006, 06:01 PM   #2 (permalink)
Johnny
Guest
Posts: n/a
View Johnny's Photo Gallery
Re: My brake back lights are on?
"duckiegirl" <u23378@uwe> wrote in message news:6238707c54877@uwe...[color=blue]
> igintion,[/color]
Check the switch under the brake pedal.
Old 06-23-2006, 06:02 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> igintion,
> pulled
> thanks
> <3 girl[/color]
Make sure that there is nothing resting on the brake pedal, like a floor
mat.
Check to make sure that the brake light switch is operating properly.
Ray O
Old 06-23-2006, 06:44 PM   #4 (permalink)
Ernie Sty
Guest
Posts: n/a
View Ernie Sty's Photo Gallery
> igintion,
> pulled
> thanks
> <3 girl[/color]
Have someone stand behind the car while you pull up on the brake pedal. If
the lights go off, you know it's the pedal not being properly supported or
something is interfering with its free motion (in my experience it's usually
the government's fault when free motion is restricted, but you'll want to do
your own analysis for sure.)
Check the pivot hinge for grime and grit of nothing else is visibly blocking
the pedal from returning. Hopefully some WD-40 or CRC spray lube on that
hinge will fix it right up. Good luck.
Old 06-23-2006, 07:11 PM   #5 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Fri, 23 Jun 2006 21:34:37 GMT, "duckiegirl" <u23378@uwe> wrote:
[color=blue]
><3 girl[/color]
I believe the problem is a plastic spacer on the brake light switch.
Same thing happened to my '92 Corolla Wagon. I pulled into the Toy
dealer and the service writer got the part and installed it at no
charge.
The spacer (if that is the right term) is located on the brake pedal
almost out of sight connecting the pedal to the brake light switch.
I'm sure one of the MDTs will get on here and correct my nomenclature.
Old 06-23-2006, 11:16 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
"Scott in Florida" <askifyouwant@mindspring.net> wrote in message
news:12to92la6rhkvohk09htc1qt18kecchrrj@4ax.com...[color=blue]
>[color=green]
>>igintion,
>>pulled
>>thanks
>><3 girl[/color]
> charge.
>[/color]
It's called a "round donut-looking thingamabobber"
Ray O
Old 06-23-2006, 11:35 PM   #7 (permalink)
Scott in Florida
Guest
Posts: n/a
On Fri, 23 Jun 2006 22:16:24 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:12to92la6rhkvohk09htc1qt18kecchrrj@4ax.com...[color=green]
>>[color=darkred]
>>>igintion,
>>>pulled
>>>thanks
>>><3 girl[/color]
>> charge.
>>[/color]
>It's called a "round donut-looking thingamabobber"[/color]
LOL....
That's it.
Matter of fact the guy at the dealership showed me the broken
donut on the floor...LOL
Old 06-23-2006, 11:55 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:9mcp92hjhmdr64kahe71mq8fbn0hvgeegh@4ax.com...[color=blue]
>[color=green]
>>news:12to92la6rhkvohk09htc1qt18kecchrrj@4ax.com...[color=darkred]
>>>>igintion,
>>>>my
>>>>pulled
>>>>if
>>>>thanks
>>>><3 girl
>>> charge.
>>>[/color]
> LOL....
> That's it.
> donut on the floor...LOL[/color]
BTW, if I had to guess, "spacer" is what you would find in the parts
catalog.
Ray O
Old 06-24-2006, 07:12 PM   #9 (permalink)
Scott in Florida
Guest
Posts: n/a
On Fri, 23 Jun 2006 22:55:55 -0500, "Ray O"
[color=blue]
>news:9mcp92hjhmdr64kahe71mq8fbn0hvgeegh@4ax.com...[color=green]
>>[color=darkred]
>>>>>igintion,
>>>>>my
>>>>>pulled
>>>>>if
>>>>>thanks
>>>>><3 girl
>>>> charge.
>> LOL....
>> That's it.
>catalog.[/color]
Well the parts guy said .... 'we don't have the part in stock' and
the writer said BS under his breath and went back in the back and
found one.
That service writer has since moved to the mountains of Tennessee. I
miss that kind of competence...
Old 06-24-2006, 09:38 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:tihr92dpseoo2knkbr0nfm22c1poqngk9s@4ax.com...[color=blue]
>[color=green]
>>news:9mcp92hjhmdr64kahe71mq8fbn0hvgeegh@4ax.com...[color=darkred]
>>>>>>igintion,
>>>>>>saw
>>>>>>my
>>>>>>pulled
>>>>>>help
>>>>>>if
>>>>>>thanks
>>>>>><3 girl
>>>>> charge.
>>> LOL....
>>> That's it.
>>catalog.[/color]
> found one.
>[/color]
Yup, good help is hard to find!
Ray O
Old 06-25-2006, 07:57 AM   #11 (permalink)
adam de jong
Guest
Posts: n/a
View adam de jong's Photo Gallery
Hey its probably youre brake light switch which is located
under the dash connected to the brake pedal which is sticking try adjusting
it and if the lights come off you will
need to replace it as it will more than likely keep reoccuring
> My brake back lights are still on when i turned off the car and the[/color]
igintion,[color=blue]
> brake back lights are on, its been on evey since last night, until i[/color]
pulled[color=blue]
> anyone has any clue or similar cases liek this please message me back[/color]
thanks[color=blue]
> <3 girl[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
My bed Lights and Backup lights Pb 2nd Generation (2005+) 104 02-24-2011 06:35 AM
Charge AND Brake Lights on-HELP! Longstreet Pre-88 Toyota Pickup/Hilux 14 08-14-2006 12:40 AM
92 Tercel rear and brake lights NickR Tercel, Paseo, Starlet, and Sera Forum 3 08-01-2005 07:12 PM
No brake lights and won't shift from park olyengineer Camry & Solara Lounge 3 10-04-2004 06:53 PM
Brake lights out carstuff Camry & Solara Lounge 0 05-08-2003 01:44 AM
