99 Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2006, 10:37 AM   #1 (permalink)
adam
Guest
Posts: n/a
View adam's Photo Gallery
99 Sienna
Hi all,
I have 1999 Toyota Sienna LE with 96 K miles. When I push the gas pedal
to the floor trying to get it to "shift up" and it's like it comes out
of gear all together and the engine revs like it's in neutral. However,
If I release it when RPM reaches 4 and then push the gas pedal, it
shifts easily. I put the car into diagnosis test. The test resulted in
"solenoid shift with code number(don't remember the cde right now).
If you help me regarding this problem I'll apreciate.
Old 07-15-2006, 11:27 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 99 Sienna
"adam" <ulussever@gmail.com> wrote in message
news:1152974260.803600.9060@i42g2000cwa.googlegroups.com...[color=blue]
> Hi all,
>[/color]
When you depress the throttle pedal to the floor, the transmission usually
will downshift, not upshift.
Check the operation of the shift solenoid identified in the code.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
99 sienna problems HLP!!!! HOOKEDonLP 1st Generation (1998-2003) 3 10-13-2006 06:47 PM
Aftermarket brake pad recommendations for '99 Sienna? cinepro 1st Generation (1998-2003) 6 05-16-2006 09:42 PM
05/06 camry mags on a 99 sienna CE jeprox 1st Generation (1998-2003) 2 03-22-2006 01:51 PM
99 Sienna Brake Bulb replacement jimi 1st Generation (1998-2003) 4 01-25-2006 06:08 PM
How much $$$ should I pay to change the timing belt (99 Sienna)? cinepro 1st Generation (1998-2003) 12 11-19-2005 09:59 PM
