Questions on 2000 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2006, 08:18 AM   #1 (permalink)
geronimo
Guest
Posts: n/a
View geronimo's Photo Gallery
I am looking into buying a yr. 2000 Corolla with 109K miles, AT AC
for (asking price) $3750. I know among sedans, Corolla/Camry rate near
the top for reliability. I checked the fueleconomy.gov site. There
two different versions that have different transmissions? Because they
give a rating for one automatic as 29/37 mpg, and for a different
trans. its only 28/32. So when I look at the car, how do I tell
which tranny, which MPG applies ? This is just the EPA rating, is
real- world going to be lower significantly?
If they haven't changed timing belts, will the valves and pistons be
damaged if it breaks? Should this be done at 100K?
I don't know which trim package it is, but if it is the mid-level LE,
Kelly BB has it listed to a private party as $5475....so this asking
price looks like a good deal, if not damaged.
Does this model yr. have any weak points? Thanks Geronimo
Old 07-16-2006, 09:52 AM   #2 (permalink)
Pop-N-Fresh
Guest
Posts: n/a
View Pop-N-Fresh's Photo Gallery
Re: Questions on 2000 Corolla
ones for the 3speed auto... the other is the fourspeed auto... you may
have to ask whos selling it what tranny it has
geronimo wrote:[color=blue]
> Does this model yr. have any weak points? Thanks Geronimo[/color]
Old 07-16-2006, 01:04 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<geronimo> wrote in message
news:ppakb2tu83svjuilu0su3s17aaok39shhn@4ax.com...[color=blue]
> real- world going to be lower significantly?[/color]
The higher mileage applies to the 4 speed automatic and the lower mileage
applies to the 3 speed automatic. Most likely, the VE trim has a 3 speed
automatic and the LE and CE have 4 speed automatics. Look at the shifter
and shift console. If the shifter has an OD Off button and the console has
PRD2L, then it is a 4-speed auto,
I have always gotten fuel mileage equal to or better than EPA mileage, but
driving conditions and driving style will affect whether you do or not.
[color=blue]
> damaged if it breaks? Should this be done at 100K?[/color]
The 2000 Corolla has a timing chain that does not need routine replacement.
[color=blue]
>[/color]
No significant ones that I am aware of.
Ray O
Old 07-16-2006, 02:04 PM   #4 (permalink)
geronimo
Guest
Posts: n/a
Well, how do I determine what is worth? I mean I have a new Kelly
Blue Book, but there are different values listed. I talked to the
seller and it is a VE with the 3- spd tranny. Bummer. So this
devalues it quite a bit I would think. Its 4-dr sedan, powertrain and
body in excellent shape he says. Cold AC. has 107K miles on it.
The Kelly BB lists the VE "good" trade-in value as $3800... for a
private seller, $5175. the CE trim class goes for $300
more....because of the tranny?
Their asking price is $3750. That would seem to be a good price, since
it is about what the trade-in value is. Its a dealer, a junkyard that
also sells some used cars. Junkyards definitely have low overhead
compared to a conventional sales lot ;-) Maybe offer them $3500?
I need a economical car that will last for another one yr. with no
major breakdowns. In one year, I will be selling it, as I will be
leaving the country. If well-cared for, is this a car I want?
Consumer Reports gives Corolla, even the older 2000 model, very high
marks for reliability.
Actually, there is about 6MPG difference between the 3 and 4 spd
trannys, but that is for HWY travel. We may never go on any long trip
in the next year, and I see that there is only abt 1 MPG difference
with city-driving. So the tranny is probably a non-issue for me.
What should I have done with it if I buy it? Tranny power flush, oil
and filter change?
Thanks for advice geronimo
On Sun, 16 Jul 2006 12:04:16 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:ppakb2tu83svjuilu0su3s17aaok39shhn@4ax.com...[color=green]
>[color=green]
>[color=green]
>>[/color]
>No significant ones that I am aware of.[/color]
Old 07-16-2006, 02:20 PM   #5 (permalink)
mack
Guest
Posts: n/a
View mack's Photo Gallery
news:p7ukb2pt5hfc2khnko33jodf4ct78hen9a@4ax.com...[color=blue]
> compared to a conventional sales lot ;-) Maybe offer them $3500?[/color]
My only qualms would be about the fact that it's for sale by a junkyard.
Is it possible that it's a salvage title and the car has been either in a
bad accident and cobbled back together, or in a flood (remember Katrina?) in
which case the car is practically worthless. I'd be careful about pulling
back the carpet and looking at the floorboards and trunk bottom for rust and
mildew. Go carefully on this one. If you find anything peculiar or
suspicious, leave the premises. There are oodles of used cars out there,
and remember that this isn't the only one by a long shot. Better to find a
little old lady's car with lower mileage and regular maintenance.
Old 07-16-2006, 03:31 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
> more....because of the tranny?[/color]
Partially because of the transmission, which costs more, and partially
because of more content in the higher trim levels.
[color=blue]
>[/color]
See mack's warnings about purchasing a vehicle from a junkyard.
[color=blue]
> marks for reliability.[/color]
If the car is truly in good condition, then it should prove very reliable.
If the car is salvaged or has been in a flood, then it will probably be very
troublesome.
[color=blue]
> and filter change?
>[/color]
Do the maintenance suggested in the owner's manual for that particular time
and mileage interval.
Ray O
Old 07-16-2006, 03:41 PM   #7 (permalink)
geronimo
Guest
Posts: n/a
Yea, The fact that it is at a salvage yard makes it suspect...will
have to check it over very carefully for any signs of being "cobbled
together", flood damage, and will get car fax report. But it may be
perfectly good. I have found that every time I get in a hurry to buy a
car, I make a bad decision...never fails. thanks, Geronimo
On Sun, 16 Jul 2006 11:20:06 -0700, "mack" <mackerel@dslextreme.com>
wrote:
[color=blue]
>news:p7ukb2pt5hfc2khnko33jodf4ct78hen9a@4ax.com...[color=green]
>[/color]
Old 07-16-2006, 07:58 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:vc5lb2pi3mpjn4t6l258jkmsk0rhjlh4go@4ax.com...[color=blue]
>[/color]
It should not be too difficult to tell if the car was cobbled together. The
major body panels should have a sticker with the VIN from the factory. The
VIN stickers on the hood, left and right front fenders, deck lid, doors,
etc. should all match.,
Lifting up the carpet in the passenger compartment is not always so easy, so
look for excessive rust in the spare tire well, and on the front seat
adjuster tracks (look under the front seats from the back seat)
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
just bought a 2000 corolla and i have a few questions Dest Archived Corolla threads 6 06-21-2010 03:14 PM
'06 Corolla S (questions about mods) gtp_Kent Archived Corolla threads 0 02-17-2006 07:32 AM
Does 2000 Corolla Ve has a timing belt? John2000ve Archived Corolla threads 5 02-03-2005 12:44 PM
keyless entry programming for 2000 corolla tmc Archived Corolla threads 1 09-30-2004 05:15 PM
The 2003 corolla vs 2000 Ford Focus dbellemafia Archived Corolla threads 16 09-23-2004 01:29 PM
