OT (sorta) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2006, 09:48 AM   #1 (permalink)
jor
Guest
Posts: n/a
View jor's Photo Gallery
OT (sorta)
It's not a Toyota but it is an automotive issue. My son can't get his
87 Suburban through emissions. Here's my post to a chevy group. Anybody
got any ideas on how to get the darn hydrocarbons down??? Thanks.
jor.
[color=blue]
> jor7 Suburban, 350, Throttle Body Injection
> My son is having a rough time getting his Suburban through Arizona
> emissions. The hydrocarbons are really high. He's done all the usual
> (new oil, new PCV valve and so on). He even added a gallon of alcohol
> to the tank. On my old carbureted Ford (sorry) pickups I usually retard
> the ignition a couple of degrees, lean out the idle mixture and add a
> gallon of alcohol. I sail right through emissions. With the TB
> injection though, I'm at a loss how to adjust it so the HC levels are
> acceptable. Thanks.
> jor[/color]
Old 08-02-2006, 10:49 AM   #2 (permalink)
Don Moore
Guest
Posts: n/a
View Don Moore's Photo Gallery
Re: OT (sorta)
"jor" <jor@jor.com> wrote in message news:2006080206482075249-jor@jorcom...[color=blue]
> jor.
>[color=green]
> > acceptable. Thanks.
> > jor[/color]
>[/color]
Just a guess here, but maybe a new CAT?
Old 08-02-2006, 12:05 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: OT (sorta)
> It's not a Toyota but it is an automotive issue. My son can't get his 87
> Suburban through emissions. Here's my post to a chevy group. Anybody got
> jor.
>[color=green]
>> emissions. The hydrocarbons are really high. He's done all the usual (new
>> oil, new PCV valve and so on). He even added a gallon of alcohol to the
>> tank. On my old carbureted Ford (sorry) pickups I usually retard the
>> ignition a couple of degrees, lean out the idle mixture and add a gallon
>> of alcohol. I sail right through emissions. With the TB injection though,
>> I'm at a loss how to adjust it so the HC levels are acceptable. Thanks.
>> jor[/color]
>[/color]
High HC is usually the result of incomplete combustion. Make sure the spark
plugs for every cylinder are firing, that they are the correct plugs and in
good condition, and that the high tension ignition wires, rotor, and coil
are in good shape.
Ray O
Old 08-02-2006, 12:55 PM   #4 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: OT (sorta)
Excessive hydrocarbons is an indicator of incomplete combustion, and since
that can occur from a rich mixture or someting like a lean miss, the HC
number alone cannot be used as an indicator to diagnose anything. Do you
have any of the the other figures from the test like co, nox, or o2?
Old 08-02-2006, 11:15 PM   #5 (permalink)
jor
Guest
Posts: n/a
Re: OT (sorta)
On 2006-08-02 09:55:43 -0700, "qslim" <Suckers@suckersdotcom> said:
[color=blue]
> have any of the the other figures from the test like co, nox, or o2?[/color]
HC Loaded: 127 (passed)
HC Idle Reading: 477 (standard is 220) = FAIL
CO Loaded: .85 (passed)
CO Idle: .27 (passed)
It passed the Air System, CAT & Gas Cap tests.
Thanks.
Old 08-03-2006, 12:11 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
Re: OT (sorta)
"jor" <jor@jor.com> wrote in message news:2006080220152250073-jor@jorcom...[color=blue]
>[color=green]
>> since
> Thanks.
>[/color]
If the HC higher at idle than loaded, I'd suspect a lean miss. Make sure
the throttle body plate moves freely and closes properly, check the ignition
system.
Ray O
Old 08-03-2006, 09:56 AM   #7 (permalink)
jor
Guest
Posts: n/a
Re: OT (sorta)
On 2006-08-02 21:11:35 -0700, "Ray O" <rokigawaATtristarassociatesDOTcom> said:
[color=blue]
> sure the throttle body plate moves freely and closes properly, check
> the ignition system.[/color]
Ray,
We were working on it for awhile last night and discovered that the
EGR had been bypassed. Also, the nuts holding on the EGR will little
more than hand tight. Anyhow, we pulled it and it seemed to function
alright but we went ahead and replaced it anyhow and hooked it back up
(vacuum line). Anyhow, would the bypassed EGR contribute to high HC
readings? Thanks.
jor
Old 08-03-2006, 11:12 AM   #8 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
Re: OT (sorta)
The EGR valve only opens under vacuum. I doubt if it is contributing
to the high HC reading at idle.
jor wrote:[color=blue]
>[color=green]
> Ray,
> readings? Thanks.
> jor[/color]
Old 08-03-2006, 11:44 AM   #9 (permalink)
Ray O
Guest
Posts: n/a
Re: OT (sorta)
"jor" <jor@jor.com> wrote in message news:200608030656468930-jor@jorcom...[color=blue]
> said:
>[color=green]
> Ray,
> We were working on it for awhile last night and discovered that the EGR
> had been bypassed. Also, the nuts holding on the EGR will little more than
> readings? Thanks.
> jor
>[/color]
The EGR recirculates some exhaust gas into the combustion chamber to lower
combustion temperatures and reduce oxides of nitrogen (NOx). I doubt if the
bypassed EGR valve caused the high HC readings. Some people bypass the EGR
valve in hopes of improving performance and/or drivability.
A dirty fuel injector could theoretically cause the HC to be high at idle.
How does the engine run at idle? With a set of set of park plug wire
pullers, carefully remove one spark plug wire at a time while the engine is
running. The engine should run noticeably rougher when the spark plug wire
is disconnected. If the engine runs the same when a particular wire is
disconnected, then that cylinder was not firing.
Ray O
Old 08-03-2006, 08:32 PM   #10 (permalink)
jor
Guest
Posts: n/a
Re: OT (sorta)
>> <snip>[color=blue]
> lower combustion temperatures and reduce oxides of nitrogen (NOx). I
> doubt if the bypassed EGR valve caused the high HC readings. Some
> people bypass the EGR valve in hopes of improving performance and/or
> drivability.
> engine is running. The engine should run noticeably rougher when the
> spark plug wire is disconnected. If the engine runs the same when a
> particular wire is disconnected, then that cylinder was not firing.[/color]
It idles smoothly. I don't think any of the plugs aren't firing but
we'll make sure. Thanks.
jor
Old 08-03-2006, 10:20 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
Re: OT (sorta)
"jor" <jor@jor.com> wrote in message news:2006080317324711272-jor@jorcom...[color=blue][color=green][color=darkred]
>>> <snip>[/color]
>> doubt if the bypassed EGR valve caused the high HC readings. Some people
>> drivability.
>> idle.
>> is running. The engine should run noticeably rougher when the spark plug
>> wire is disconnected. If the engine runs the same when a particular wire
> It idles smoothly. I don't think any of the plugs aren't firing but we'll
> make sure. Thanks.
> jor
>[/color]
Incorrect or bad spark plugs could also keep the fuel from burning
completely so pull the plugs and visually inspect. Sniff the end of the
plugs for a gas smell.
Ray O
Old 08-05-2006, 07:13 PM   #12 (permalink)
borfli zank
Guest
Posts: n/a
View borfli zank's Photo Gallery
Re: OT (sorta)
On Wed, 02 Aug 2006 06:48:20 -0700, jor wrote:
[color=blue]
> jor.
>[color=green]
>> acceptable. Thanks.
>> jor[/color][/color]
is it in closed loop?
BB code is Off
Smilies are Off
[IMG] code is Off
OT Forum Explanation of what happened. True? NH05TACOMA 2nd Generation (2005+) 24 02-28-2006 10:25 AM
Can't post new thread in OT ASG14 Site Suggestions, Questions, and Comments 6 02-06-2006 08:27 PM
what happened to OT? gamushara unten General Discussion 2 11-20-2003 04:13 PM
Ot!! Alpha Off Topic 0 08-30-2003 05:11 PM
