Brake Rotor Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2006, 10:34 PM   #1 (permalink)
scholt77@yahoo.com
Guest
Posts: n/a
View scholt77@yahoo.com's Photo Gallery
Brake Rotor Removal
My wife's '97 4runner seems to have developed a nice little shake in
the front end when the brakes are applied. After a little research,
seems we're not the only one! I would like to replace the pads as well
as have the discs machined, but I'm not too sure how difficult it will
be to remove them-- do the rotors just pop off, or will I have to get
into the 4wheel dr. hub? any ideas would be much appreciated.
Old 08-03-2006, 12:05 AM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: Brake Rotor Removal
The 97 should have tophat rotors, so you won't have to mess with the
bearings.
Old 08-03-2006, 12:17 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<scholt77@yahoo.com> wrote in message
news:1154572466.983599.163830@m73g2000cwd.googlegroups.com...[color=blue]
>[/color]
When you remove the caliper and the bracket that holds the pads, the rotors
will come right off. I recommend investing in OEM pads and rotors instead
of having the rotors machined. Machined rotors tend to re-develop the brake
shudder rather quickly.
Ray O
Old 08-03-2006, 09:23 AM   #4 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
[email]scholt77@yahoo.com[/email] wrote:[color=blue]
>do the rotors just pop off[/color]
Yes and no.
In theory they should just release once the wheel is removed, but on
the Camry I've found I need to thread two small bolts into the holes
provided to break the rotor loose from the hub.
Old 08-03-2006, 11:59 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
<nospampls2002@yahoo.com> wrote in message
news:1154611407.897107.4990@i42g2000cwa.googlegroups.com...[color=blue]
> [email]scholt77@yahoo.com[/email] wrote:[color=green]
> Yes and no.
>[/color]
Actually, the rotor will not release just by removing the wheel. The
caliper and bracket that holds the pads must also come off before the rotor
will come off.
As far as the rotor sticking to the hub, you can prevent this by applying a
thin coating of anti-seize or high temp wheel bearing grease where the hub
contacts the rotor.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Are these good rotors to get? cman2000 Camry & Solara Lounge 32 11-24-2007 02:32 AM
Brake Pads will not clear Caliper wannawangan Camry & Solara Lounge 13 09-06-2005 04:06 PM
rav4 brake bleeding rav4jeff RAV4 Forum 1 12-26-2004 09:02 PM
Brake problems, trouble shooting, fix? itzsteven Camry & Solara Lounge 1 11-17-2004 05:50 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 05:56 AM
