Re: tire rotation
On Sat, 5 Aug 2006 16:21:14 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
>"mack" <mackerel@dslextreme.com> wrote in message
>news:12d9t96i1beibcc@corp.supernews.com...[/color]
[color=blue][color=green][color=darkred]
>>> If the tires are not enough out of balance to move the steering wheel or
>>> feel through the chassis, then they are balanced enough.[/color]
>> Okay, Ray, I'll defer to your greater knowledge and experience on this.
>> Thanks[/color]
>You're welcome. Your wallet will thank you too![/color]
I just ask the tire guys to run a simple check when rotating the
tires - leave the old weights alone, throw the tire and wheel on the
machine, and spin it once. If the machine display comes up with a
perfect { 0.0 <> 0.0 }, throw it back on the car. NEXT! If all four
come up good, it takes 30 seconds a tire.
If it comes up a bit off, it wore funny. Throw on a quarter-ounce
or half-ounce of lead on in the right spot and put it on the car.
If it comes up way off, then it probably threw a weight. Yank off
all the old weights and start over.
And any good tire shop shouldn't be charging you for this simple
service at a rotation, especially if you regularly buy all your tires
there. If they are charging, it means you are patronizing the wrong
tire shop and it's time for a change.
--<< Bruce >>--
