On Sat, 5 Aug 2006 14:37:17 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>"Jennifer" <notspam-sec4251@yahoo.com> wrote in message
>news:ocg8d2d4mlngjrjhblja9cik2h1rpuektd@4ax.com...[color=green]
>> On Sat, 5 Aug 2006 01:04:17 -0500, "Ray O"
>>[color=darkred]
>>>"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
>>>news:0s98d2lcsma7svhj1f37numa3bbflek4g3@4ax.com...
>>>> On Sat, 05 Aug 2006 01:59:51 GMT, Jennifer <notspam-sec4251@yahoo.com>
>>>> wrote:
>>>>>Anyone suggest most workable way to reinstall Toyota 4 Runner
>>>>>airbags ?
>>>>>The two front airbags have been deployed in a hand me down 2004 4
>>>>>Runner. I cannot find an on-line price for replacement air bags.
>>>>>Is this a dealer only item ?
>>>>>Even so, any suggestions as to pricing and best way to go about it.
>>>> They are not a 'dealer-only' item, but the installer that buys them
>>>> needs special training and licensing to do it - he's buying some
>>>> serious explosives. Most dealers don't do enough airbag replacement
>>>> work to have someone trained and on-staff full time, so they farm it
>>>> out to a regional specialist.
>>>> The Sodium Azide based initiators are triggered off with blasting
>>>> caps and are considered an explosive, and you can easily kill yourself
>>>> while installing the new airbags if you don't follow all the safety
>>>> procedures to the letter.
>>>> This is one of the few procedures that you MUST leave to an expert -
>>>> unless you want to invest a whole lot of time money and effort to get
>>>> trained, get the tools, and become an expert.
>>>>>It seems that in California one cannot register with the DMV a 4
>>>>>Runner without airbags installed. 'Not perfectly sure about this, but
>>>>>looking.
>>>> They don't want someone disabling the bags or replacing them with
>>>> chunks of foam and reselling the car as having a "good" airbag system
>>>> to an unsuspecting buyer - hence the law.
>>>> A lot of crooks fixed up and sold wrecked cars and jiggered the
>>>> airbags like that, and the driver got killed or hurt badly in the next
>>>> accident when the airbags didn't deploy - because they weren't there.
>>>> They wanted a way to hang the murder rap on the crook who sold the car
>>>> like that, so a law was born.
>>>> If you want to fix it and drive it, there would be no problem - but
>>>> if you don't take it to the wrecking yard, eventually you are going to
>>>> sell the car.
>>>> Most of the time, when the bags are deployed you also have to change
>>>> out all the triggering control boxes behind the grille and a bunch of
>>>> other stuff beside just the bags themselves - which is why many cars
>>>> over three or four years old get totaled out when the bags deploy. It
>>>> is too expensive to fix the bodywork damage AND replace all the
>>>> airbags and sensors, AND repair the interior and broken windshield
>>>> that were damaged by the airbags when they deployed.
>>>> Unless you want to spend a lot of money and effort fixing up the
>>>> car, it probably makes more sense to hand it down again - this time to
>>>> a junkyard.
>>>> --<< Bruce >>--
AFAIK, one does not need a license to install air bags, however one does
>>>need special training to keep it from deploying during installation. The
>>>sensors should be OK for re-use - once the new air bags are installed, the
>>>air bag ECU will self-test. A crash force big enough to deploy air bags
>>>means that any seat belts that were in use at the time of the crash should
>>>also be replaced.[/color]
>> Bruce and Ray O, thanks your time that info is helpful.
>> I might have given the wrong impression, it is not a true hand me
>> down, but would have to be purchased and newly registered by me. I
>> really do not want the air bags at all, I have been driving cars for
>> for all these years without air bags and would prefer to see what was
>> happening in front of me at all times.[/color]
>As far as seeing what is happening in front of you at all times, keep in
>mind that the airbags will only deploy AFTER you have hit something with
>sufficient force so seeing something is kind of a moot point. Also, air bag
>deployment and deflation is something like hundreths of a second, the blink
>of an eye. Most people who have experienced an air bag deployment do not
>even remember them going off.
>[color=green]
>> I would quite prefer to sign a waiver regarding air bags and present
>> it to the DMV and carry on without them. But I would bow to greater
>> intelligence on that point, as I am not expert in this area.
>> In any event, I would not be averse to paying a specialist, if it
>> would come to that, to put the airbags back in (and new seat belts),
>> if the cost were workable to the situation.
>> Is there any kind of a rough guestimate of the cost of replacing two
>> airbags and the dashboard (and the seat belts) that could be
>> speculated on ?[/color]
>Costs vary widely depending on the prevailing labor rates in your area, but
>replacing both fron air bags will easily cost in the thousands of dollars.
>Get quotes from your local Toyota dealer and reputable body shop.
>[color=green]
>> Thanks so much,
>> Jenny
>> PS
>> Would a fender impact that was sufficient to deploy the air bags on a
>> 4 runner be enough to cause frame damage ? On this car there was body
>> work, but supposedly the frame is ok.
>>[/color]
>After any impact that was sufficient to deploy the air bags, the frame
>should be inspected and measured for damage.[/color]
Thanks Ray, you are a gentleman. I did not know that airbags are the
domain of body shops. Otherwise I might have pushed in that direction
sooner. I am now far better educated, thanks again.
And I do own a telephone.
Jenny
