2000 Sienna - spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
The Gameroom
There is 1 open event in the Betting section.
Old 08-19-2006, 02:21 PM   #1 (permalink)
Jill
Guest
Posts: n/a
View Jill's Photo Gallery
I have a 2000 sienna van I bought new. It now has abt 75000 miles and I
would like to change the spark plugs. The engine has never been touched.
(V6 3.0L)
Anyone with experience or know what is envolved in changing plugs in this
car?
Old 08-19-2006, 02:45 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2000 Sienna - spark plugs
"Jill" <Jill@usa.net> wrote in message
news:dk1cez9ik5w6$.102vm0ltcfhrn.dlg@40tude.net...[color=blue]
> (V6 3.0L)
> car?[/color]
Changing the spark plugs is not technically difficult. I believe the 2000
Sienna has a coil for each plug so remove the coil, remove the plug, and
reverse the process.
The difficult part is reaching the spark plugs on the back side of the
engine. You will need a ratchet, spark plug socket, extensions, a universal
joint, and the ability to do lots of stretching and twisting to get back
there.
An old trick to getting spark plugs started when re-installing them is to
get a one or two foot piece of vacuum hose that fits tightly over the top of
the spark plug. You hold on to the hose and twist it to get the spark plug
started. This method greatly reduces the likelihood of cross-threading and
allows you to reach into tight spaces.
I recommend using OEM plugs from your dealer.
Ray O
Old 08-20-2006, 12:06 AM   #3 (permalink)
View toyomoho's Photo Gallery
If the engine is operating OK, you might consider leaving them in a little longer. The newer plugs should last 100K+. Check the owner’s manual maintenance schedule.
toyomoho is offline
Old 08-20-2006, 10:04 AM   #4 (permalink)
Jill
Guest
Posts: n/a
On Sat, 19 Aug 2006 13:45:36 -0500, Ray O wrote:
[color=blue]
> Path: border1.nntp.dca.giganews.com!nntp.giganews.com!nx01.iad01.newshosting.com!newshosting.com!feeder2.on.meganewsservers.com!meganewsservers.com!reader1.on.meganewsservers.com!reader1.on.meganewsservers.com!not-for-mail
> ath: nntpswitch.com
> From: "Ray O" <rokigawaATtristarassociatesDOTcom>
> Newsgroups: alt.autos.toyota
> References: <dk1cez9ik5w6$.102vm0ltcfhrn.dlg@40tude.net>
> Subject: Re: 2000 Sienna - spark plugs
> Date: Sat, 19 Aug 2006 13:45:36 -0500
> X-Priority: 3
> X-MSMail-Priority: Normal
> X-Newsreader: Microsoft Outlook Express 6.00.2900.2869
> X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2962
> X-RFC2646: Format=Flowed; Original
> Message-ID: <e6bd4$44e75c57$47c97f29$30306@msgid.meganewsservers.com>
> Organization: We
> Lines: 32
> NNTP-Posting-Host: 69.49.124.165
> X-Trace: 1156013143 reader1.on.meganewsservers.com 4216 69.49.124.165:56696
> Xref: number1.nntp.dca.giganews.com alt.autos.toyota:392101
> news:dk1cez9ik5w6$.102vm0ltcfhrn.dlg@40tude.net...[color=green]
>> (V6 3.0L)
>> car?[/color]
> there.
> I recommend using OEM plugs from your dealer.[/color]
Thanks for the information. The three plugs in front look easy enough to
get to - but the three in the back look like a problem. Any idea of what
has to come off the engine?
Old 08-20-2006, 01:59 PM   #5 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Jill, 8/20/2006,10:04:33 AM, wrote:
[color=blue]
>[color=green]
> > Path:
> > not-for-mail ath: nntpswitch.com From: "Ray O"
> > <rokigawaATtristarassociatesDOTcom> Newsgroups: alt.autos.toyota
> > References: <dk1cez9ik5w6$.102vm0ltcfhrn.dlg@40tude.net> Subject:
> > Re: 2000 Sienna - spark plugs Date: Sat, 19 Aug 2006 13:45:36 -0500
> > X-Priority: 3 X-MSMail-Priority: Normal
> > Message-ID:
> > Organization: We Lines: 32
> > 69.49.124.165:56696 Xref: number1.nntp.dca.giganews.com
> > news:dk1cez9ik5w6$.102vm0ltcfhrn.dlg@40tude.net...[color=darkred]
> > > and I
> >> would like to change the spark plugs. The engine has never been[/color][/color]
> touched. >> (V6 3.0L)[color=green][color=darkred]
> >> Anyone with experience or know what is envolved in changing plugs[/color][/color]
> in this >> car?[color=green]
> > the 2000 Sienna has a coil for each plug so remove the coil, remove
> > the plug, and reverse the process.
> > the engine. You will need a ratchet, spark plug socket,
> > extensions, a universal joint, and the ability to do lots of
> > stretching and twisting to get back there.
> > is to get a one or two foot piece of vacuum hose that fits tightly
> > over the top of the spark plug. You hold on to the hose and twist
> > it to get the spark plug started. This method greatly reduces the
> > likelihood of cross-threading and allows you to reach into tight
> > spaces.
> to get to - but the three in the back look like a problem. Any idea
> of what has to come off the engine?[/color]
I have the same vehicle as you but have not changed the plugs yet.
They say nothing must come off. You just need a couple of three-inch
extensions and a u-joint between them on a ratchet.
Old 08-20-2006, 02:57 PM   #6 (permalink)
Check Camry TN post history on the subject changing rear plugs on the V6. Lots of good info.
toyomoho is offline
Old 08-20-2006, 05:59 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:m5c23wvp5yfh.sqg2tnz2z4vm.dlg@40tude.net...[color=blue]
>[/color]
[color=blue][color=green]
>>> (V6 3.0L)
>>> this
>>> car?[/color]
>> 2000
>> universal
>> there.
>> of
>> plug
>> and
Nothing should have to be removed in order to change the back 3 plugs. You
just need some extensions, 1 or 2 u-joints, and some flexibility.
Good luck!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
How long do platinum spark plugs last? NewRacer Camry & Solara Lounge 8 05-24-2006 07:52 PM
190,000 km - 1st spark plugs change ToyotaToday Camry & Solara Lounge 8 04-23-2006 12:56 AM
spark plugs cam01speak Camry & Solara Lounge 10 01-24-2006 01:27 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 07:21 PM
Quick question about oil above the spark plugs on 94-I4 ']['R][) camry 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-09-2002 08:25 AM
