Water on Drivers Floor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2006, 09:39 PM   #1 (permalink)
Charles Pisano
Guest
Posts: n/a
View Charles Pisano's Photo Gallery
For some reason I'm getting wetness on drivers floor. No I'm not
incontinent..And it hasn't been raining. I did recently have the
windshield replaced and thought it was due to improper install.
I had another put in and that didn't change the situation. Could it be
something else??
Old 08-23-2006, 09:50 PM   #2 (permalink)
Reasoned Insanity
Guest
Posts: n/a
View Reasoned Insanity's Photo Gallery
Re: Water on Drivers Floor
"Charles Pisano" <pisanochas@webtv.net> wrote in message news:25778-44ED0337-2@storefull-3274.bay.webtv.net...
something else??
I would guess something to do with the A/C, but I don't really know crap. Hopefully Ray comes along soon.
Old 08-24-2006, 12:08 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
something else??
I don't remember what kind of car you have, but there are a few
possibilities:
Since it happens even though it is has not been raining, the AC evaporator
drain tube may not be routed through the opening in the floor or it may be
clogged. The evaporator drain tube is usually on the passenger side behind
the carpet under the dash. If the tube is pulled out of the hole in the
floor, it will drain on the floor and get the carpet wet. Since the wetness
seems to be on the driver's side, I'd also check for a blockage in the tube
by poking a wire up from underneath the car. If the drain tube is clogged,
you may have had critters build a nest in the blower motor and the debris
from the nest got into the tube.
If your car has a sunroof, the sunroof drain tube on the driver's side may
be blocked or mis-routed. Open the sunroof and look for a drain hole in the
front corners of the sunroof opening near the windshield pillars. If you
slowly pour water down the holes, it should drain under the car. If it does
not, check to make sure the tubes come out under the car. To be honest,
this is not a high likelihood since it hasn't been raining.
Another possibility is that the drain holes in the bottom of the door are
partially blocked and so water drains into the car instead of outside. Open
the door and from underneath, look for small holes in the bottom of the door
and poke a wire through the holes.
Ray O
If the wetness has a sickly sweet smell like anti-freeze, the heater core
may be leaking.
Old 08-28-2006, 08:57 PM   #4 (permalink)
Charles Pisano
Guest
Posts: n/a
Re: Water on Drivers Floor-2001 Toyota Camry.
Actually it HAS been raining and alot (I'm not sure why I said it
wasn't ). There was a good size puddle in there today. Could it be the
windshield again?
They are coming back a 3rd time, but I can't see how it could be that.
This didn't happen in Florida, but then again I park under a huge tree
there and it hasn't rained alot there lately..
I will check the sunroof drain ..
New home has a 2 car garage, but I'm not a believer in parking a car in
an attached garage (kinda like parking it in the house?)
But I'm doing it till I get is figured out...
CP
Old 08-29-2006, 11:45 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:28482-44F390DF-644@storefull-3278.bay.webtv.net...
windshield again?
The likelihood that you will get a proper diagnosis and repair will go up
exponentially if you describe the correct symptoms and conditions under
which the symptoms appear. ;-)
I am certainly not a meterologist, but wouldn't Ernesto bring a lot of rain?
CP
Also try parking with the front of the car facing downhill and see if the
water problem goes away. If it does, check to make sure all firewall
grommets are in place and that the cowl drains properly.
Ray O
Old 08-30-2006, 12:34 PM   #6 (permalink)
Charles Pisano
Guest
Posts: n/a
Thanks for responding Ray. My car is parked on a down slope now and the
problem remains.
I'm not in Florida right now (TG) but eventually I've got to go back to
work..
I get a pretty good puddle on the driver side closer to the firewall
than to the seat. I guess I have to run a hose over it.
Passenger side is dry as a desert.. go figure..
CP
BB code is Off
Smilies are Off
[IMG] code is Off
The Free Mod Series: Part VII Cheap Water Injection Toysrme Camry & Solara Lounge 17 05-26-2010 03:13 PM
Water soaked floor board - A/C prob? cody 2nd Generation (2005+) 12 08-19-2008 09:58 AM
Drivers from each state, and how they ranked....NE DRIVERS BLOW!!!!!!!!!!!!!!!!!!! ASG14 Off Topic 20 05-31-2005 09:44 PM
Water coming in from undercarriage kravits Camry & Solara Lounge 3 06-17-2004 10:29 PM
soaked passenger side floor camryLE Camry & Solara Lounge 4 07-28-2002 10:52 PM
