Corolla temp - overheating - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2006, 10:13 AM   #1 (permalink)
hammo@ihug.com.au
Guest
Posts: n/a
View hammo@ihug.com.au's Photo Gallery
Greetings
The puzzle of why the car was overheating has been solved.
It was not clogged radiator (Internal/external), dud pump, leaks,
thermostat, coolant type or level, radiator pump, EGR valve, belt
tension or timing.
It was confirmed (or actually disproved) during a 4 hour freeway run
with a multimeter and thermocouple insitu. Despite the guage showing
red zone and even higher than red super hot, the coolant temp never got
higher than 92 degrees celcius (+/- 3 %).
Travelling with the needle in the red for over 120 kilometres meant
that either Toyota build bomb proof cars, or, the temp sender is
stuffed.
Thanks to all that offered ideas.
Cheers
Hammo
Old 08-24-2006, 01:21 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Corolla temp - overheating
On Thu, 24 Aug 2006 07:13:55 -0700, hammo wrote:
[color=blue]
> Greetings
> tension or timing.
> stuffed.
> Cheers
> Hammo[/color]
The question: Were you measuring at the same point that the temp gauge
sender is?
Old 08-26-2006, 06:44 AM   #3 (permalink)
hammo@ihug.com.au
Guest
Posts: n/a
Hachiroku wrote:
[color=blue]
> sender is?[/color]
The answer:
No, I was measuring the coolant temp a short distance from the position
of the temp sender unit. The absence of steam, nil loss of coolant and
that the gauge was showing the temperature was in the red when the
thermo couple showed it was at 70-75 C, I am not concerned in the
minnimal difference in positioning. The flow rate of the coolant at
engine speeds of 3000 rpm plus suggests that the minimal difference in
location is also negligable.
Are you suggesting that the problem is not due to the sender unit?
Cheers
Hammo
BB code is Off
Smilies are Off
[IMG] code is Off
77 Corolla and 81 Starlet Questions curtisz Archived Corolla threads 8 03-19-2009 05:25 PM
1983 corolla overheating problem... mike5721947 Archived Corolla threads 5 05-26-2006 02:27 AM
1989 Toyota Corolla SR5 Temp Guage, Idle, ECU and more retiredat44 Archived Corolla threads 14 03-14-2006 06:43 PM
Overheating? Or not? cozmo_im Archived Corolla threads 7 11-03-2004 03:51 AM
