Re: Engine oil leaking in TOYOTA COROLLA 1994
<jorawer@gmail.com> wrote in message
news:1156520741.717754.18160@i42g2000cwa.googlegroups.com...[color=blue]
> Engine oil of my car TOYOTA COROLLA 1994 leaks after running for few
> miles.
> Mileage of the car is 108k what could be the cause? I see oil traces
> under the car when car is parked.
> I bought car 4 months back and it never gave me any problem before.
> Though timing belt of the car was changed at 68k. In last 4 months i
> drove the car for about 4K in and around city.
> What would be the total expenditure to fix the problem?
> It is still having some engine oil,just over the low mark. So will it
> be wise to drive the car to a mechanic(As it is still running fine.) or
> i should get it towed to nearest mechanic
> Thanks
>[/color]
Engine oil can leak from several places. Possible sources of leaks are
valve cover gasket, crankshaft front and rear seal, head gasket, distributor
shaft o-ring, oil pressure sender, oil pan gasket, oil pan drain plug, and
oil filter housing. If it is a fast leak, I'd start by checking the oil
pressure sender.
If you fill the oil to the full mark, it should be safe to drive to a
service facility, as long as the oil pressure warning light on the
instrument panel is not illuminated.
Ray O
