Ping Ray O re mice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2006, 09:26 AM   #1 (permalink)
---MIKE---
Guest
Posts: n/a
View ---MIKE---'s Photo Gallery
Ping Ray O re mice
Ray, I sent you this in an email but I guess you didn't get it.
Would any special settings of the heater controls block the entry of
mice into the system? I am wondering if setting the control on
re-circulate would help - or setting the heat on cold - or setting the
selector on defrost.
---MIKE---[color=blue][color=green]
>>In the White Mountains of New Hampshire
>> (44° 15' N - Elevation 1580')[/color][/color]
Old 08-26-2006, 09:36 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Ping Ray O re mice
"---MIKE---" <twinmountain@webtv.net> wrote in message
news:18078-44F04BFD-205@storefull-3251.bay.webtv.net...
Sorry Mike, I didn't get your e-mail.
I don't think any particular settings on the heater controls will block the
entry of mice or rodents from the system more than other settings. When you
set the system to the various positions - floor, dash, defroster, etc, a
damper inside the ductwork moves, but there is no position that completely
seals the system. In other words, critters could theoretically get in from
the position that the system is set to - through the floor ducts if the
system is set to floor, defroster ducts if the system is set on defrost,
etc.
I suppose that if the system is set to recirculate, critters would have a
harder time getting in from outside, but then they would still be stuck in
the plenum leading outside.
The temperature setting is controlled by a valve in the heater hose so there
are no mice getting in there.
Check the plastic screening along the base of the windshield to make sure it
has not been chewed through anywhere.
I do not know how well ultrasonic pest chasers work, but this company
[url]http://www.victorpest.com/sonic_pest_control.htm[/url] is well known for making
mouse traps so perhaps one of these gizmos in the passenger compartment may
work.
Ray O
Old 08-27-2006, 09:05 AM   #3 (permalink)
---MIKE---
Guest
Posts: n/a
I wonder if putting a small container of used cat litter (after
scooping) would make mice think a cat was in the car.
Old 08-27-2006, 09:40 AM   #4 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Sun, 27 Aug 2006 09:05:33 -0400, [email]twinmountain@webtv.net[/email]
(---MIKE---) wrote:
[color=blue]
> ---MIKE---[color=green][color=darkred]
> >> (44° 15' N - Elevation 1580')[/color][/color][/color]
Nope....
I'll tell you one thing that worked for me was putting a
JT Eaton Stick-Em mouse trap in the car.
It is a tray with a bit of Peanut Butter scent on a very sticky
surface.
Rodent gets hungry.
Rodent gets on the trap.
Rodent is stuck....waiting for you to help it meet its maker.....
No mess...
Just be CAREFUL not to touch the sticky stuff...
Available at Home Depot
Scott in Florida
'The Land of the Free Thanks to the Brave'
Old 08-27-2006, 06:32 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:10288-44F1989D-520@storefull-3255.bay.webtv.net...
I don't think the cat litter trick will work very well. If the car is
parked in an enclosure, I'd set out poison or mouse traps. If it is parked
outside, I'd think about one of those sticky mouse traps.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Stop the Ping! drugal Camry & Solara Lounge 2 08-03-2005 08:38 AM
nextech reverse cf gauges. Any ideas/ will the install ray ray did work for these? new_yorks_illes Camry & Solara Lounge 14 05-08-2004 03:36 AM
*Graphic* dead mice under my bed Silver Streak Off Topic 26 04-14-2004 11:31 PM
Mice In Car....!!! lcarocha General Discussion 23 02-07-2004 01:18 PM
