Replacement Electrical Connectors 4 1991 Supra - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2006, 03:48 PM   #1 (permalink)
Archon
Guest
Posts: n/a
View Archon's Photo Gallery
Hey all,
My son has a 1991 Supra and has torn it down and put a new head gasket
on it. We are reassembling it now but have noticed it is missing a
Knock sensor connector and some previous owner cobbled something
together for it. Also we had a VSV connector break off right flush with
the connector so no way to re-attach it to the wires.
Does anyone have a line on a source for replacement connectors that
come with pigtails attached?
TIA
Archon
"PC load letter WTF does that mean?"
Old 08-26-2006, 05:36 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Replacement Electrical Connectors 4 1991 Supra
On Sat, 26 Aug 2006 15:48:40 -0400, Archon wrote:
[color=blue]
> Hey all,
> TIA[/color]
Good luck on that VSV.
I got one on EBay for $20. It won't pass emissions without it.
You might be able to get some kind of very small tube adapter and epoxy it
in with hi-temp epoxy, but I'd start looking. They're $65+ from Toyota.
Old 08-26-2006, 09:48 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Archon" <noone@nunya.biz> wrote in message
news:2006082615484016807-noone@nunyabiz...[color=blue]
> Hey all,
> My son has a 1991 Supra and has torn it down and put a new head gasket on
> it. We are reassembling it now but have noticed it is missing a Knock
> sensor connector and some previous owner cobbled something together for
> it. Also we had a VSV connector break off right flush with the connector
> Does anyone have a line on a source for replacement connectors that come
> TIA
> Archon
> "PC load letter WTF does that mean?"[/color]
I believe the knock sensor has a single wire connected, so if the engine
wire harness side of the connector is missing, just use an insulated bullet
or spade connector. If the engine wire harness connector is OK, then use
spade connectors that fit inside the factory connector. Another approach is
to back the spade connections inside the wire harness connector out of the
plastic housing so that you have loose spade connections. Save the plastic
housing so that you can return it back to it original state if you replace
parts later.
If you cannot find a replacement VSV, use the same trick for the knock
sensor wiring, then solder the wire to the VSV contacts or try something
like DevCon.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
83 Celica Supra GTS electrical problem MrPipes Celica Forum 3 08-14-2004 05:21 PM
mk3 supra for sale, sniff, sniff...... cdnsupra Vehicles 5 10-30-2003 02:12 PM
Toronto Supra Club Monthly Mini Meet March 7th cdnsupra Supra Forum 0 03-03-2003 10:28 AM
[b]1982 Celica Supra Factory Electrical Manual[/b] Brum Supra Forum 0 11-08-2002 04:26 PM
82 Celica Supra Factory Electrical Manual Beeson Celica Forum 0 11-08-2002 04:19 PM
