Failed Emission Test - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2006, 06:30 PM   #1 (permalink)
kenny_frohlich
Guest
Posts: n/a
View kenny_frohlich's Photo Gallery
Hi All,
I took my 93 Corolla in for an inspection last week and it failed the
emission test. The NOx levels both for high speed and low speed were
high. I then took my car to a shop to get the catalytic converter
replaced. However, when I went back to the inspection station to get
it re-inspected yesterday, not only it still failed, but the failing
levels were even higher than the first inspection. Can someone please
tell me what the problem is?
Thanks,
Kenny
Old 08-26-2006, 08:11 PM   #2 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Re: Failed Emission Test
kenny_frohlich wrote:[color=blue]
> Hi All,
> high.[/color]
Check the EGR vavle.
Old 08-26-2006, 08:11 PM   #3 (permalink)
Guest
Posts: n/a
> Hi All,
> high.[/color]
Check the EGR valve.
Old 08-26-2006, 10:01 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"kenny_frohlich" <kenny_frohlich@yahoo.com> wrote in message
news:1156631451.671884.51450@i42g2000cwa.googlegroups.com...[color=blue]
> Hi All,
> Thanks,
> Kenny
>[/color]
What are the other readings for the emissions tests, ie., Hc, CO?
I would check EGR and MAP sensor operation, depending on the results of the
test.
Ray O
Old 08-26-2006, 11:26 PM   #5 (permalink)
View toyomoho's Photo Gallery
High NOx levels are also caused by high combustion temps. Things like high coolant temp, a really lean air/fuel ratio (manifold system leaks), O2 sensor improper operation, EGR system problems (VSV, modulator, hoses), improper timing and spark advance.
toyomoho is offline
Old 08-27-2006, 09:31 AM   #6 (permalink)
kenny_frohlich
Guest
Posts: n/a
Ray O wrote:[color=blue]
> news:1156631451.671884.51450@i42g2000cwa.googlegroups.com...[color=green]
> > Hi All,
> > Thanks,
> > Kenny
> >[/color]
> test.
> Ray O
> (correct punctuation to reply)[/color]
Ray,
Other readings are passing and they are:
HC: 22
CO: 00
CO2: 13.5
O2: 1.3
Dillution: 13.5
By the way, I know the EGR valve looks like a flying sauce thing, but I
can not seem to locate it under the hood. Can you please tell me where
I can find it (This is a 93 Corolla)?
Thanks,
Kenny
Old 08-27-2006, 07:11 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:1156685499.120084.18320@74g2000cwt.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> news:1156631451.671884.51450@i42g2000cwa.googlegroups.com...[color=darkred]
>> > Hi All,
>> > Thanks,
>> > Kenny
>> >[/color]
>> the
>> test.
>> Ray O
> Ray,
> HC: 22
> CO: 00
> CO2: 13.5
> O2: 1.3
> Dillution: 13.5
> Thanks,
> Kenny
>[/color]
This California Smog Check web site lists common causes for emissions
failures: [url]http://www.smogsearch.com/index.php?page=faq[/url]
A lean mixture could be due to a bad O2 sensor or clogged injectors. Check
ignition timing to make sure it is not too advanced (are you getting any
knocking/pinging on acceleration?)
Not all vehicles have an EGR valve. I don't recall if yours does nor not.
The EGR valve is generally located near the intake manifold with a pipe
leading to the exhaust manifold.
Ray O
Old 09-01-2006, 10:33 AM   #8 (permalink)
someone@somewhere.org
Guest
Posts: n/a
View someone@somewhere.org's Photo Gallery
kenny_frohlich <kenny_frohlich@yahoo.com> wrote:
[color=blue]
> I can find it (This is a 93 Corolla)?[/color]
If you have a 49 state version you need to find a California model first.
Then it should be easy to find. :-)
BB code is Off
Smilies are Off
[IMG] code is Off
K&N: Why take filtercharger over drop-in filter? dELuX-4x4 2nd Generation (2005+) 88 10-02-2007 02:13 AM
Avalon and Impala score best among IIHS side crash test results for large sedans IFCAR Toyota News 1 06-24-2006 06:28 AM
vehicle emission test (ON Drive Clean).. what the hell Tubbyc General Discussion 4 03-31-2004 03:02 PM
failed emission test nirAE86taba General Discussion 4 10-25-2003 12:28 PM
I FAILED emission! TRDragoon General Discussion 39 10-03-2003 12:17 AM
