high pitched squeak on suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2006, 08:36 AM   #1 (permalink)
Torgeaa
Guest
Posts: n/a
View Torgeaa's Photo Gallery
Hi, novice has 1994 toyota corolla. we are being driven mad by a high
pitch squeak that is coming from underneath. it seems connected to the
suspension. i have squirted WD-40 into the bushes of the anti roll bars, but
no joy.
i know this is a long shot asking someone to guess where on the suspension a
high pitched squeak is coming from, but someone who is really familiar with
this car might be able to give a good guess, i wonder? thanks
Old 09-11-2006, 09:03 AM   #2 (permalink)
Iain Miller
Guest
Posts: n/a
View Iain Miller's Photo Gallery
Re: high pitched squeak on suspension
"Torgeaa" <vacuous632@voidacious.net> wrote in message
news:RDdNg.6156$s4.2323@newsfe3-win.ntli.net...[color=blue]
> but no joy.
> a high pitched squeak is coming from, but someone who is really familiar
> with this car might be able to give a good guess, i wonder? thanks[/color]
Had that on a VW once - turned out to be the driver's seat (!)
Sometimes your ears can deceive you - worth a check.
I.
Old 09-11-2006, 09:05 AM   #3 (permalink)
Adrian
Guest
Posts: n/a
View Adrian's Photo Gallery
Iain Miller (donot@spam.me) gurgled happily, sounding much like they
were saying :
[color=blue][color=green]
>> suspension a high pitched squeak is coming from, but someone who is
>> really familiar with this car might be able to give a good guess, i
>> wonder? thanks[/color][/color]
[color=blue]
> Had that on a VW once - turned out to be the driver's seat (!)[/color]
You sure it wasn't the passenger's earring?
Old 09-11-2006, 10:21 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> but no joy.
It is very difficult to diagnose the source of a sound without hearing the
sound and the conditions under which the sound occurs. The chances of
anyone's guess being correct will be higher if you describe the conditions
when the noise occurs. Can you make the sound happen when the vehicle is
sitting still by bouncing on the front or rear suspension? Left or right
turn? What speed? Accelerating or decelerating? Weather conditions?
I do not recommend WD-40 as a lubricant, especially on something that gets a
lot of contact like a sway bar bushing. Even if you have correctly
identified the source of the noise, the WD-40 will not have any effect. The
best stuff I've found to use on sway bar bushings is Ford bushing lube, next
best is lithium or wheel bearing grease. For any attempt to lube the
bushing to be effective, you have to remove the bracket holding the bushing,
remove the bushing, clean it off, apply the lube, and re-assemble. This
takes about 5 minutes per side.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Suspension setup for comfort doru Camry & Solara Lounge 12 04-05-2005 12:52 PM
Even a year out of high school, I am still bitter... kenratboy Off Topic 17 02-16-2004 02:56 PM
Attn: Soundlzrd (regarding Camry suspension parts) StickyDilJoe Camry & Solara Lounge 10 11-21-2002 04:03 PM
