Replace condenser on 2000 Toyota Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2006, 01:11 AM   #1 (permalink)
clintonb@fflax.net
Guest
Posts: n/a
View clintonb@fflax.net's Photo Gallery
The Toyota dealer says we need to replace our condenser. They said it
would cost about $600. I called other auto repair shops and they
quoted similar prices. But it seems like everyone is charging a lot
for the condenser. I can find one on the internet for about $152 which
is 1/2 the price the repair shops are charging.
So, I'd like to try to replace it myself.
I have a Haynes manual that says it is a do-it-yourself job as long as
a certifed a/c technician discharges before replacing the condenser and
recharges it after.
One potential problem I see is disconnecting the lines to the
condenser. It looks like there really is no room for me to disconnect
the "liquid line" (Hayne's term). I wonder if I should try from
underneath.
Also, I've heard conflicting information on whether it is also
necessary to replace the receiver/drier at the same time.
I'd appreciate advice from those who have replaced their own
condensers.
Thanks.
- Clint
Old 09-13-2006, 12:53 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: Replace condenser on 2000 Toyota Sienna
On 11 Sep 2006 23:11:59 -0700, "clintonb@fflax.net"
<clintonb@fflax.net> wrote:
[color=blue]
>recharges it after.[/color]
Absolutely - you could in theory vent R-134 without lightning bolts
reaching down from the sky and zapping you to your great reward, but
it's the right thing to do.
Now R-12 they might do the recovery for free - because they want to
sell it back to you later at $60 a pound. Or more, haven't checked
the going rate lately.
[color=blue]
>underneath.[/color]
Haven't worked on that particular car, but as a general rule you
usually can get a straight shot at the fittings with wrenches somehow,
might taking removing or moving other items.
Get and use two of the proper flare fitting wrenches, one for the
nut, one backing up on the condenser fitting. If you don't, either
the line will twist and snap (Aluminum is not at all forgiving of
being bent, even once) or the fittings will round off the nuts.
[color=blue]
>necessary to replace the receiver/drier at the same time.[/color]
Whenever you have the system open for any length of time, or the
system has had a zero-leak and sat there empty for a few months (and
was 'breathing' moisture inside from the leak as the temperature
changed) you change the filter/drier.
A pro would have it all done and buttoned back up in an hour (and
kept the lines sealed well enough with tape during that hour) but you
most likely won't be done that fast.
Would be nice if they used separate (and cheap) refrigeration style
in-line filter/driers, but that's asking too much of car makers.
It only takes a few drops of moisture to saturate the drier
crystals, and then you have free water droplets wandering around
inside the system, causing mayhem (system freeze-ups) or damage.
--<< Bruce >>--
Old 09-13-2006, 01:49 AM   #3 (permalink)
View toyomoho's Photo Gallery
Cannot help on this particular car, but. Why did the dealer say the condenser needed replacing? Did you get quotes for discharging and charging the system? The dryer is usually changed if the system is discharged; it absorbs moisture in the system. There may be front grill piece that can be easily removed to allow better access to the fittings.
toyomoho is offline
Old 09-20-2006, 09:29 AM   #4 (permalink)
clintonb@fflax.net
Guest
Posts: n/a
toyomoho wrote:[color=blue]
> fittings.
> toyomoho
> toyomoho's Profile: [url]http://www.toyotanation.com/forum/member.php?userid=59151[/url]
> View this thread: [url]http://www.toyotanation.com/forum/showthread.php?t=155304[/url][/color]
Thanks for your response.
They did a leak test with some dye and determined the leak was in the
condenser.
Recharging the a/c costs around $75-80.
- Clint
BB code is Off
Smilies are Off
[IMG] code is Off
If you have the chk engine light for the evaporative emission. toyota may cover it! popeye08 Camry & Solara Lounge 1 12-15-2010 01:01 PM
Avalon shows dent in Toyota quality sciguy0504 Toyota News 98 03-25-2007 11:49 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
Toyota and Nevada Partners Team Up 02AspenGreen Toyota News 0 04-13-2006 08:41 PM
