did you go yhe junkyard route?
seeray28(steve) wrote:[color=blue]
> well after a little bit of cusssing the job went VERY EASY
> THanks all
> steve
> "Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
> news:e1c1d$45098234$44a4a10d$32086@msgid.meganewsservers.com...[color=green]
> > "seeray28(steve)" <seeray28@charter.net> wrote in message
> > news:jIbOg.90$Nq1.48@newsfe04.lga...[color=darkred]
> > > im talking about after I remove the spring, I have the spring compressor
> > > AND
> > > safety chains (you only need one spring to jump on ya and you will NEVER
> > > do
> > > the job without the safety chains). Apparently there is a lock nut on[/color][/color]
> top[color=green][color=darkred]
> > > of
> > > the strut housing that has to be removed before the inserts can come
> > > out.What I am worried about is:
> > > 1 destroying the housing where the lock nut screws into the housing due[/color][/color]
> to[color=green][color=darkred]
> > > rust and what not, so how would I go about removing the locknut ?
> > > 2 destroying the housing trying to hold it still so I can get the[/color][/color]
> locknut[color=green][color=darkred]
> > > out.
> > > 3 What do I do if the instert is stuck in the housing
> > > Im thinking about going to a junk yard and getting another set of struts
> > > with the inserts and rebuilding them, this way if I have to say OH SH*T[/color][/color]
> I[color=green][color=darkred]
> > > ahve a spare
> > > any and all ideas would be helpfull
> > > Thanks
> > > Steve[/color]
> > I think is use the penetrating oil - tap, repeat many times method to[/color]
> remove[color=green]
> > the lock nut if it is rusted.
AFAIK, there are no special tricks.
> > Ray O
> > (correct punctuation to reply)
> >[color=darkred]
> > > news:a4d3a$4508d8da$47c97f29$26016@msgid.meganewsservers.com...
> > >> news:ou2Og.46$Nq1.6@newsfe04.lga...
> > >> > hey all I have a 89 celica st and need to replace the front struts. I
> > > can
> > >> > only get the strut inserts around here so it looks like I am going to
> > > have
> > >> > to disect the strut its self. I dont want to twist the strut shell[/color][/color]
> (for[color=green][color=darkred]
> > >> > lack
> > >> > of better terms) but am thinking that if I put the whole strut in a
> > >> > vice
> > > I
> > >> > will crush the shell and not get the insert out. . Any ideas on how[/color][/color]
> > > do
> > >> > this?
> > >> > THANK YOU
> > >> > Steve
> > >> If you are talking about using a vice to remove the strut from the
> > >> spring,
> > >> that is very dangerous and is likely to result in either bodily injury[/color][/color]
> > >> property damage. The safest way to remove the strut from the spring is
> > > with
> > >> a wall-mounted strut spring compressor.
> > >> The insert should be mounted like a shock absorber inside the assembly.
> > >> Ray O
> > >[/color]
> >[/color][/color]
