Re: 01 camry rubber smell
<deebony@gmail.com> wrote in message
news:1158590546.916058.245390@d34g2000cwd.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> news:1158231562.645498.120900@i42g2000cwa.googlegroups.com...[color=darkred]
>> > Hi all
>> > I recently got my first camry (70K, CE, 4 cyl) and started noticing
>> > something.
>> > When i turn on ignition, the rpm's go up for a second or two (as if
>> > pressing the gas pedal) and at the same time, there is a rubber odor
>> > coming out of the exhaust. it does go away shortly
>> > can any1 tell me if its normal.
>> > thanks
>> >[/color]
>> How high does engine RPM go when you start the engine?
>> Can you smell the "rubber odor" from inside the passenger compartment
>> when
>> you start the car?
>> Ray O
>> (correct punctuation to reply)[/color]
> i think the RPMs go up to around 3000 and drop off right away to a
> little above 1000 and the odor is only coming out from the exhaust. And
> it looks like this happens only when the engine is cold.
>[/color]
3,000 RPM is a little high at startup. You should start the car with your
foot off of the throttle, because if you give it gas when you crank, it will
rev up like that.
If you can only smell the burning rubber odor by standing near the exhaust
pipe and it goes away right away, I wouldn't worry too much. If there are
clouds of blue-gray smoke as well, then have it checked out and monitor your
oil consumption.
Ray O
