Re: Toyota Celica 94 have roller lifter/valve?
"Somadis" <u26658@uwe> wrote in message news:664ef764fd2d0@uwe...[color=blue]
> First of all i just want to say that I'm extreamly happy that I have found
> this website through yahoo.com. I've only scan through the forum for a few
> minute but I can already tell that there are so many good mechanic here.
> Anyway enough of that
> My question for today is
> Does a stock Toyota Celica 1994 use roller lifters or roller rockerarm?[/color]
No and no.
[color=blue]
> If it doesn't then I'm thinking about doing a valve job to my car but I
> was
> hoping that someone could give me some information on what kind of
> tools/special tools do i need to perform this job. Also do i need to make
> valve adjustment to my engine after I installed the roller valve? How do
> I
> make the adjustment?
> thanks for taking your time to help me out.
>[/color]
I cannot tell how much automotive experience you have from your post, so I
will assume that you have not removed a head before. You will have to
remove the head to do a valve job, so you will need a head gasket set that
includes the head gasket and associated gaskets like valve cover gasket,
intake manifold gasket, valve stem seals, etc. as well as new head bolts.
The head bolts are known as plastic region bolts that must be torqued and
stretched. For tools, you will need the usual assortment of sockets and
ratchets, a scraper, torque wrench, a valve spring compression tool, a
magnetic pickup tool, feeler gauges, and a micrometer or good vernier
caliper. You will need to do a valve adjustment after you have re-installed
the head. For this, you will need an assortment of shims. It helps to
have an air ratchet and a die grinder with a Scotch Brite pad to clean up
the gasket surfaces.
Grinding valves and cleaning up the valve seats is no longer a
do-it-yourself job and so I recommend that you send them out to a machine
shop.
Adjusting valve lash requires a feeler gauge and a valve spring compression
tool. To adjust lash, you have to first use the feeler gauge to take a
measurement, then use the spring compression tool to relieve tension on the
shims, use the magnet to pick out the shims, then measure the shim
thickness, then change shims to arrive at the correct thickness.
You will need a repair manual to get the proper torque and valve lash specs.
If you have not removed a head before, I recommend having a knowledgeable
person help you the first time.
Ray O
