Noisy disc brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2006, 12:33 PM   #1 (permalink)
timagine@hotmail.com
Guest
Posts: n/a
View timagine@hotmail.com's Photo Gallery
Noisy disc brakes
I just had a front-end brake job: turned the rotors, pads... There is a
fluttering sound on the left brake when I'm driving along.
What causes this and how can I fix it?
voice from the past
Old 09-15-2006, 12:52 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Noisy disc brakes
<timagine@hotmail.com> wrote in message
news:1158337995.087671.262750@b28g2000cwb.googlegroups.com...[color=blue]
> voice from the past
>[/color]
It is difficult to diagnose sounds without hearing the sounds, but here are
some common causes of brake sounds that occur when the brakes are not
applied:
Improper rotor installation - fix by removing the rotor and installing
correctly
Improper pad installation - fix by removing the pads and installing them
correctly
Aftermarket parts, particularly pads, that do not fit correctly - fix by
installing OEM pads.
Stuck caliper slide - fix by cleaning up the slide, the slide bushing, and
lubing with anti-seize, wheel bearing grease, or caliper slide grease.
Improper wheel installation or torque - fix by removing and reinstalling the
wheel and torquing the lug nuts properly
Bad wheel cover - fix by installing a new wheel cover.
Ray O
Old 09-15-2006, 01:27 PM   #3 (permalink)
mack
Guest
Posts: n/a
View mack's Photo Gallery
> voice from the past
>[/color]
have you yet been back to the garage that did your brake job to tell them
about the problem? and if so, what did they say?
Old 09-15-2006, 01:45 PM   #4 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:9b669$450ada70$44a4a10d$20479@msgid.meganewsservers.com...[color=blue]
> news:1158337995.087671.262750@b28g2000cwb.googlegroups.com...[color=green]
>> voice from the past
>>[/color]
> are some common causes of brake sounds that occur when the brakes are not
> applied:
> correctly
> correctly
> the wheel and torquing the lug nuts properly
> Ray O
> (correct punctuation to reply)[/color]
Damaged, improperly greased or misadjusted wheel bearings, most common if
you have the older style tapered roller bearings. Ray didn't overlook this,
it's merely an expansion of his comment "improper rotor installation."
One other problem - very rare in my experience, is an improperly remachined
rotor. Many years ago I had disks turned by an auto parts store that owned
their own brake lathe. The lathe's collet was out of true.
Mike Harris
Austin TX
Old 09-15-2006, 08:02 PM   #5 (permalink)
Don Fearn
Guest
Posts: n/a
View Don Fearn's Photo Gallery
I think it was [email]timagine@hotmail.com[/email] who stated:
[color=blue]
>What causes this[/color]
Don't know.
[color=blue]
>and how can I fix it?[/color]
YOU shouldn't have to!
Go back to whomever did your brake job and tell them about the sound
(assuming it wasn't there before the job was done). THEY should figure
out the problem they caused and fix it . . . .
-Don
"What do *you* care what other people think?" --Arline Feynman
Old 09-16-2006, 09:32 AM   #6 (permalink)
Guest
Posts: n/a
I should have mentioned that the sound stops when I apply the brakes.
voice from the past
Ray O wrote:[color=blue]
> > voice from the past
> >[/color]
> applied:
> correctly
> correctly
> Ray O
Old 09-17-2006, 12:57 AM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:1158413550.019045.63800@b28g2000cwb.googlegroups.com...[color=blue]
> voice from the past
>[/color]
Same advice applies.
Ray O
[color=blue]
> Ray O wrote:[color=green]
>> news:1158337995.087671.262750@b28g2000cwb.googlegroups.com...[color=darkred]
>> > voice from the past
>> >[/color]
>> are
>> applied:
>> correctly
>> correctly
>> and
>> the
>> Ray O
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
rear disc brakes for 2nd gen camry WVcamry3sfe Camry & Solara Lounge 8 06-29-2006 06:17 PM
Gen 3 4cyl with rear disc brakes? PtBaller 3rd & 4th Generation (1992–1996 & 1997–2001) 31 08-24-2004 01:46 AM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 11:38 PM
disc brakes to fit? gasman Archived Corolla threads 2 06-22-2004 11:34 PM
