Re: corolla cruise control?
"Rick" <parker@rowan.edu> wrote in message
news:1158414166.903190.120390@b28g2000cwb.googlegroups.com...[color=blue]
>I don't own a repair manual, and I'm not sure exactly what a TSB is
> (technical service bulletin?). Is any of this stuff online? If not, is
> it worthwhile to buy it? Can this stuff be worked on by a backyard
> mechanic w/o professional training?
> Rick[/color]
Sorry, a TSB is a technical service bulletin.
You can access TSBs and the factory service manual in pdf format at
techinfo.toyota.com for $10/day.
Most electronic and electrical components can be diagnosed with a volt-ohm
meter if you know how to use one.
Ray O
(correct punctuation to reply)[color=blue]
> Ray O wrote:[color=green]
>> news:1158350625.853752.3620@m73g2000cwd.googlegroups.com...[color=darkred]
>> > The cruise control on my 03 corolla isn't working properly. The light
>> > goes off and on, and when it goes off the cruise goes off; that means I
>> > can't safely use cruise because the car would slow down unexpectedly. I
>> > read somewhere that Toyota had issued a recall for something like this
>> > for V6 models, but mine is a 4. Help!
>> >[/color]
>> All Corollas are 4 cylinder so there are no V6 Corollas.
>> There are no recalls in the U.S. for 2003 Corollas regarding the cruise
>> control.but there is a TSB with a correction to the repair manual
>> regarding
>> diagnosis for the cruise control system.
>> Ray O
>> (correct punctuation to reply)[/color]
>[/color]
