Re: Lights On
On Fri, 15 Sep 2006 21:35:14 -0500, Reasoned Insanity wrote:
[color=blue]
> "ZR" <ZR@ABC.COM> wrote in message
> news:Z4JOg.2140$UG4.976@newsread2.news.pas.earthlink.net...[color=green][color=darkred]
>>>> I'm wondering if anyone can give some hints on this. The Brake, Charge
>>>> and
>>>> Tail-Brake-Lights indicator lights in my 1990 Camry would come on for a
>>>> few
>>>> minutes during drive. They don't come on right after start and will go
>>>> off
>>>> by themselves after a few minutes. The engine and the car run fine
>>>> during
>>>> this time. All the other indicator do not have this problem.
>>>> So where should I start?
>>>> Thanks for your help!
>>> Classic indicatuion that your alternator is telling you it's on the way
>>> out...[/color]
>> Thanks! Is there a way to test if that's the case when it's not acting up?[/color]
> You could probably take it to autozone and have them test it.[/color]
BAH! They will probably tell you it's bad and have you buy a new one for
$75 or LOTS more...
Well, that IS their business after all!!
BUT...I am willing to bet that the brushes have worn down. You can get
brushed at CarQuest for about $9.
If you're lucky, they are the screw-in type. You replace the brushes and
screw the terminals onto theterminals on the alternator.
I'm not lucky...on my 'Hachiroku' and my Celica GT-S they needed to be
soldered. No big deal, I've been soldering professionally since I was 19.
the BITCH is, getting the whole mess back together, with the springs and
the brushes. If you're lucky, again, you can get a plastic 'sleeve'
somewher that will fit over everything and slide the whole mess back
together. I'm not that lucky. With one hand, you hold one side, with the
other hand you hold the brushes and springs in place, and with your third
hand you mate the two halves together...
Might as well replace the bearings while you're at it...$17 at Toyota, $8
at CarQuest.
Beats $80 or more for a new alternator! Takes a patient person about 2
hours...takes ME three!
