Check engine light...again - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2006, 08:25 AM   #1 (permalink)
Reasoned Insanity
Guest
Posts: n/a
View Reasoned Insanity's Photo Gallery
This time it's just kinda weirding me out instead of making me panic. It's
the same code as before (71 ERG system), but the light is intermittently on.
It will be on one day and be off the next few days and then come back on for
a few days. I've kinda kept quiet about it and haven't messed with it just
to see what it would do on it's own. From the looks of it, the car is
possessed.
Old 09-17-2006, 05:00 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Check engine light...again
"Reasoned Insanity" <mintclovers@@yahoo.com> wrote in message
news:u_fPg.13725$B14.10084@dukeread03...[color=blue]
> on. It will be on one day and be off the next few days and then come back
> on for a few days. I've kinda kept quiet about it and haven't messed with
> it just to see what it would do on it's own. From the looks of it, the car
> is possessed.
>[/color]
When you had it apart before, did you clean out the passages that are
accessible in the EGR valve and associated metal tubing?
Ray O
Old 09-17-2006, 05:29 PM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
My '95 Bronco was throwing a code that said it detected a lean condition.
The Check light would randomly cycle on on some trips but not others, then
it would go off on some of the trips where it came on, but not on others. It
never came on a second time in the same trip.
I took a wild guess and replaced one of the O2 Sensors (I have two of them)
that is before the CAT, and my problem was solved.
You did not say what year your car is, but by the description of your
symptom I assume it is a pre-'96 model that has the OBD I management system.
I found Autozone sells a scan tool for my Ford for $35. It is a no-frills
unit, but it provides enough information to make an educated guess to fix
stuff at home. I'm sure there is a model that fits your Toyota.
> is possessed.
>[/color]
Old 09-17-2006, 05:56 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:PvKdnaHJ8YGtI5DYnZ2dnUVZ_sednZ2d@ez2.net...[color=blue]
> It never came on a second time in the same trip.
> them) that is before the CAT, and my problem was solved.
> system. I found Autozone sells a scan tool for my Ford for $35. It is a
> no-frills unit, but it provides enough information to make an educated
> guess to fix stuff at home. I'm sure there is a model that fits your
> Toyota.
>[/color]
For a pre OBD II Toyota, you do not need a scan tool to check trouble codes,
a paper clip will do.
There are 3 possible causes of a lean condition trouble code: 1) bad air
flow sensor; 2) bad #1 O2 sensor; 3) leak in the intake tube between the air
flow sensor and the throttle plate.
The air flow sensor (MAF) can be contaminated by some air filters that use
an oil bath or are soaked in oil, an air filter that allows a lot of
contaminants to pass through like some "high performance" filters, or by
fumes from the PCV system.
Ray O
[color=blue]
> news:u_fPg.13725$B14.10084@dukeread03...[color=green]
>> It's the same code as before (71 ERG system), but the light is
>> intermittently on. It will be on one day and be off the next few days and
>> then come back on for a few days. I've kinda kept quiet about it and
>> haven't messed with it just to see what it would do on it's own. From the
>> looks of it, the car is possessed.
>>[/color]
>[/color]
Old 09-17-2006, 06:05 PM   #5 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Sun, 17 Sep 2006 16:56:27 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>Ray O[/color]
You are being too politically correct, Ray.
It is K&N filters that could be the cause....
Why anyone would want a filter on their engine that lets MORE dirt
thru is beyond me....and it can screw up a very expensive sensor to
boot....
Scott in Florida
Old 09-17-2006, 06:48 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
"Scott in Florida" <askifyouwant@mindspring.net> wrote in message
news:aghrg25ou6g1r1kbkog6i5s9h0mi1tc430@4ax.com...[color=blue]
>[color=green]
>>air
>>Ray O[/color]
> boot....
> Scott in Florida[/color]
Most "high performance" modifications are not well suited for street use and
have a tradeoff in either comfort or vehicle longevity.
Ray O
Old 09-18-2006, 03:50 PM   #7 (permalink)
Reasoned Insanity
Guest
Posts: n/a
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:75a11$450db86a$47c97f29$30346@msgid.meganewsservers.com...[color=blue]
>>[/color]
> Ray O
> (correct punctuation to reply)[/color]
There are 3 hoses that connect to the valve. Two on the top and one coming
up from the bottom. The top two have been replaced because the ends broke
off when I pulled the valve. With the bottom one going straight down I don't
really see a way to make sure it is unobstructed. If I detatch all three
hoses, the valve comes out once I get the clamp off.
I also cleaned out the filter in the top of the valve with an air hose.
Old 09-18-2006, 04:12 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:uMCPg.13828$B14.253@dukeread03...[color=blue]
> news:75a11$450db86a$47c97f29$30346@msgid.meganewsservers.com...[color=green]
>> news:u_fPg.13725$B14.10084@dukeread03...[color=darkred]
>>> and
>>> the
>>>[/color]
>> Ray O
> don't
>[/color]
Did you do the check where you apply vacuum to the EGR valve while the car
is idling to see if the engine starts to die? If the engine does not start
to die when you open the EGR, then the EGR needs cleaning or replacement.
If the engine does start to die, then look at the vacuum switching valve
that is connected to the EGR.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 02:02 AM
Locking gas cap and check engine light on Tacos paco 2nd Generation (2005+) 36 06-06-2008 11:00 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 10:50 PM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 12:52 PM
