Overdid it today! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2006, 09:10 PM   #1 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Overdid it today!
Should have done all this yesterday! It was about 6 degrees cooler, but I
had to get my Reg and Inspection from the dealer.
Put new pads on the POS van, just in time for winter! The old pads were
BEYOND toast! Both sides right to the rivets.
Now, I suppose I should have done rotors, too, but I wasn't sure what I'd
find, so I just got the pads.
Surprisingly, as bad as the pads were, the rotor surfaces were not that
bad! They were basically nice and smooth with no real gouging to speak of.
I wanted to do the shoes, too, but it looks more involved than the discs,
so I will do that another day; perhaps I'll find some instructions on line.
It was almost 90 degrees today here in the beautiful Northeast. Good day
for riding with the top off, but the Leaf Peepers will be starting their
yearly run upstream, and the best thing to do is STAY OUT OF THEIR WAY!
I also washed and waxed (Zymol...) the Supra today, inbetween bouts of
removing rusted wheel nuts and letting the brake cleaner dry...
Now, all I need is a windshield...and to get some HEAT in the damn thing...
(I think the water pump is shot...when I keep it out of OD, and leave it
in third at 2500 RPMs there is enough heat to stay warm...)
Old 09-18-2006, 12:44 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Overdid it today!
"Hachiroku" <Trueno@ae86.gts> wrote in message
news:LlmPg.1566$_k1.1341@trndny01...[color=blue]
> line.
> thing...
>[/color]
Try anti-seize on the wheel studs, even though you are not supposed to put
anything on them ;-)
Ray O
Old 09-18-2006, 08:16 AM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:78354$450e24cb$47c97f29$13448@msgid.meganewsservers.com...[color=blue]
> news:LlmPg.1566$_k1.1341@trndny01...[color=green]
>> of.
>> line.
>> thing...
>>[/color]
> Ray O
> (correct punctuation to reply)[/color]
I put some of the brake grease on them. I have used molybdenum grease and
anti seize before on the Celica and the Tercel, and then torqued the nuts
and then checked them again. Sure makes removal a LOT easier!
I weigh 260 LBS, and putting the wrench on the lugs and STANDING on the
wrench wouldn't BUDGE them!!
I took an old metal tube from an Electrolux vacuum and used that as a
'breaker' bar! MAN!!!
I also replaced the nuts with standard sized one. The studs are the same
size as the Corolla and the Celica. The studs are really meant for Alloy
wheels, so I am a bit leery, but the chamfer mated with the holes in the
wheel OK...
But, now I can use one of the DOZEN lug wrenches I have for Toyotas.
Old 09-18-2006, 11:52 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:I6wPg.2504$Se.2395@trndny03...[color=blue]
> news:78354$450e24cb$47c97f29$13448@msgid.meganewsservers.com...[color=green]
>> news:LlmPg.1566$_k1.1341@trndny01...[color=darkred]
>>> I
>>> I'd
>>> of.
>>> discs,
>>> line.
>>> thing...
>>>[/color]
>> put anything on them ;-)
>> Ray O
> wheel OK...
>[/color]
Time to invest in a compressor and impact gun!
Ray O
Old 09-18-2006, 04:07 PM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
On Mon, 18 Sep 2006 10:52:00 -0500, Ray O wrote:
[color=blue]
> news:I6wPg.2504$Se.2395@trndny03...[color=green]
>> news:78354$450e24cb$47c97f29$13448@msgid.meganewsservers.com...[color=darkred]
>>>> I
>>>> I'd
>>>> of.
>>>> discs,
>>>> line.
>>>> thing...
>>> Ray O
>> wheel OK...
>>[/color]
> Time to invest in a compressor and impact gun![/color]
LOL! I just placed a bid for a gun on e-Bay, and found a decent,
low-priced compressor at Lowe's!!
Aslo going to get an air ratchet and a HVLP gun while I'm at it, too!
Now...for a lift...
Old 09-18-2006, 04:19 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:E%CPg.770$x11.439@trndny02...[color=blue]
>[color=green]
>> news:I6wPg.2504$Se.2395@trndny03...[color=darkred]
>>>>> but
>>>>> I
>>>>> were
>>>>> I'd
>>>>> that
>>>>> of.
>>>>> discs,
>>>>> line.
>>>>> day
>>>>> their
>>>>> WAY!
>>>>> thing...
>>>>> it
>>>> Ray O
>>> and
>>> nuts
>>> wheel OK...
>>>[/color]
>[/color]
The plastic cover on the trigger for my impact gun broke off so it kind of
hurts to use my impact gun. It was a free sample and still works, but now I
have an excuse for a new one!
[color=blue]
>[/color]
The really nice thing about the Snap-On air ratchet is that it is
reaction-less. When the bolt is finally tightened, it won't swing around
and smash your knuckles. The not-so-nice thing about the Snap-On air
ratchet is that it costs about 4 times what a Craftsman one costs, and its
larger size makes it harder to fit into tight spots.
My craftsman air ratchet is good enough for what I use it for.
Keep in mind that pneumatic sanders and die-grinders use a lot more air than
other tools, so a larger compressor with a capacity of at least 90 cubic
feet per minute at 90 PSI is nice.
[color=blue]
> Now...for a lift...
>[/color]
I'd love to have a lift too!
Ray O
Old 09-19-2006, 01:32 AM   #7 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Mon, 18 Sep 2006 15:19:15 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
>news:E%CPg.770$x11.439@trndny02...[/color]
[color=blue][color=green]
>> low-priced compressor at Lowe's!![/color][/color]
If you are buying retail and have a choice, an oil lube compressor
is a MUST - they live a lot longer than the oilless.
If you have the room, get a belt-drive "old-style" unit with the
horizontal tank, the slower compressor RPM adds to the longevity. The
direct drive 1725 RPM units are a lot noisier, too.
[color=blue]
>have an excuse for a new one![/color]
Depending on who made it, those molded rubber grip sections are
available as replacement parts. Or go get a set of the special
"anti-vibration" gloves with the gel pads in the palms and
second-knuckle areas of the fingers.
>> Aslo going to get an air ratchet and a HVLP gun while I'm at it, too![/color][/color]
For HVLP, you are probably better off going with one of the turbine
units, I have the Campbell Pro and it works fine for my uses.
Unless they've really improved them a lot the HVLP venturi
conversion type guns use way too much shop air to run them. For a
Body Shop with a pair of 15 HP turbine compressors the air consumption
isn't a problem, but for home use it is.
[color=blue]
>feet per minute at 90 PSI is nice.[/color]
90 CFM? Refer to that Body Shop above, with the twin 15 HP units...
9 CFM at 90 is plenty for anything at home.
I have a "5 HP" (around 3 real HP) 80-gallon two stage at home, and
it will keep up with almost anything except the bead-blast cabinet - I
can't just sit there and wail on a part non-stop or it runs dry. But
as you stop to reposition the piece, and see if it's done yet or not,
the compressor is catching up.
Anything bigger at home becomes a power draw problem - you have to
make sure you have the juice available first. the "5 HP" runs on a
30A 220V clothes dryer circuit no problem.
>> Now...for a lift...[/color]
>I'd love to have a lift too![/color]
Well then, go out to the highway overpass and stick out your thumb.
(Or keep your eyes open for a used one, new runs around $4K.
Problem is, it'll cost you more than that to raise the ceiling in your
garage - unless you want cars bumping into the attic joists...)
--<< Bruce >>--
Old 09-19-2006, 08:14 AM   #8 (permalink)
Hachiroku
Guest
Posts: n/a
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:3ltug214940q3tru6d9umh7rat3k2de2b9@4ax.com...[color=blue]
> <rokigawaATtristarassociatesDOTcom> wrote:[color=green]
>[color=green][color=darkred]
> direct drive 1725 RPM units are a lot noisier, too.[/color]
I could have had one for $100! When I was selling used cars we had one in
the shop. It was HUGE, but I would have been able to run ANYTHING off it! I
don't really have room for that thing in my garage. Would have been nice,
though! It was probably made sometime in the 50's or 60's.
I kind of kick myself now...
[color=blue]
>[color=green]
>>I
>[color=green]
>>than
> --<< Bruce >>--
>[/color]
Old 09-19-2006, 12:17 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
> is a MUST - they live a lot longer than the oilless.[/color]
The oil-less compressors were just coming out when I got my compressor
around 20 years ago, and since they were so new, I stuck to conventional (at
that time) oil-lube compressor. I use my compressor quite a bit for
everything from blowing off the lawnmower to filling tires to air tools.
The only thing I don't like about the compressor is the oily mess when I
drain the tank.
[color=blue]
Does the horizontal tank have an advantage over a vertical one or are you
talking just about the belt drive configuration? BTW, how long do those
belts last? I've never done any maintenance or repairs to the compressor
other than draining the tank and refilling the oil.
[color=blue]
>[color=green]
>>I
> second-knuckle areas of the fingers.[/color]
The brand name on the gun is Fuji, which I've never heard of here in the
U.S. I got it from my dad, who says that company supplies them to
factories. The guns supposedly can be calibrated to apply accurate torque
over many uses. The instructions were in Japanese and I never bothered to
ask someone to translate for me. I like the gun because it is relatively
light and it doesn't over-torque alloy wheels. I don't like the gun because
it is relatively gutless at removing stubborn bolts that someone with one of
those monster impact guns torqued.[color=blue]
>[color=green]
>>than
> 90 CFM? Refer to that Body Shop above, with the twin 15 HP units....[/color]
Oops! typo! I meant 9 CFM.[color=blue]
> 30A 220V clothes dryer circuit no problem.[/color]
My compressor is Craftsman brand, listed as 220V, 5 HP 30 gallon single
stage. I don't know who made it. It is fine for air ratchets and impact
guns but it runs quite a bit when I use a cutoff tool or die grinder.
[color=blue]
> --<< Bruce >>--
>[/color]
But we have to dream about something!
Ray O
Old 09-19-2006, 12:19 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:maRPg.2443$zs6.652@trndny07...[color=blue]
> news:3ltug214940q3tru6d9umh7rat3k2de2b9@4ax.com...[color=green]
>> <rokigawaATtristarassociatesDOTcom> wrote:[color=darkred]
>>[color=darkred]
> I don't really have room for that thing in my garage. Would have been
> nice, though! It was probably made sometime in the 50's or 60's.
>[/color]
You could have put just the compressor and motor in the garage and put the
tank outside or up in the rafters and connected them with pipe.
Ray O
Old 09-19-2006, 12:47 PM   #11 (permalink)
ron
Guest
Posts: n/a
View ron's Photo Gallery
hey Hach, a bit of Moly grease on the threads does good regardless of
what it says, but I'd use sparingly. Its high temp so hangs in there.
Ron
Old 09-19-2006, 07:10 PM   #12 (permalink)
Hachiroku
Guest
Posts: n/a
On Tue, 19 Sep 2006 16:47:58 +0000, ron wrote:
[color=blue]
> Ron[/color]
I had a wheel fall off because the tire guy didn't tigten the lugs about 6
years ago...
Bet your @ss I check lug nuts, greased or not!
Old 09-19-2006, 10:38 PM   #13 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Tue, 19 Sep 2006 11:17:21 -0500, "Ray O"
>> <rokigawaATtristarassociatesDOTcom> wrote:[/color][/color]
[color=blue]
>drain the tank.[/color]
So put a hose on the tank drain and aim it into a bucket of kitty
litter. The water evaporates and the clay absorbs the oil nicely for
easy disposal.
>other than draining the tank and refilling the oil.[/color]
I was talking about the belt between motor and pump. For small
units with the 14 to 20-gallon tanks, they're usually horizontal.
Belt drive lets them use a more efficient 3600 RPM motor and gear it
down with the pulleys for a compressor head that would rather see 600
- 900 RPM for long life and better volumetric efficiency.
Direct drives have to run the compressor head at either 1800 or 3600
RPM in lock-step with the motor, which is not the preferred way to go.
You have to go with smaller pistons and/or shorter crank throws, and
it's harder to dissipate heat.
[color=blue][color=green][color=darkred]
>>>I have an excuse for a new one![/color]
>those monster impact guns torqued.[/color]
Time to do a web search for Fuji, finds a parts list, and order one.
You can get a new monster gun for doing lug nuts and crank pulleys if
you want, but there are times when finesse beats brute strength.
Plus, Murphy's Law says the tool breaks 5 minutes after you could
possibly get to the last store in the area that sells them before they
close - and the car HAS to be on the road tomorrow morning...
>Oops! typo! I meant 9 CFM.[/color]
Yeah, Right, Suuuuuuuure ya did... ;-P
[color=blue]
>guns but it runs quite a bit when I use a cutoff tool or die grinder.[/color]
If you have a "5 Sears Horsepower" unit, it is probably a 2-HP or
possibly a 3-HP unit - check the nameplate for the running amps to
divine the true HP ratings. Sears has had to correct their
literature, electric motors are supposed to be rated at Full Load
Current, not the bigger and more impressive sounding Stall Current
rating Sears wanted to use...
According to the NEC, 2-HP is 12A at 230V. 3-HP is 17A at 230V,
5-HP is 28A at 230V for a single-phase motor. Real 5-Horse units need
a magnetic motor starter, the pressure switch contacts can't switch
that much juice reliably.
Look at the motor nameplate and Century Electric Motors refuses to
lie about it, they just mark the HP Rating box as "Special" - any HP
claims made are not theirs.
--<< Bruce >>--
Old 09-19-2006, 11:37 PM   #14 (permalink)
Ray O
Guest
Posts: n/a
news:k881h252cskv3oo924va23r82u816lctbv@4ax.com...[color=blue]
>>news:3ltug214940q3tru6d9umh7rat3k2de2b9@4ax.com...[color=darkred]
>[color=green]
>>(at
> easy disposal.
>[/color]
Great idea! I'll have to raise the compressor a bit so that I can get
something larger underneath the compressor, but there should be a lot less
mess.
> it's harder to dissipate heat.[/color]
When you explain it that way, it makes a lot of sense.[color=blue]
>>>>of
>>>>now
>>relatively
>>because
>>of
>[/color]
Hmm, looks like an outfit in NY imports them. Time for more research...
[color=blue]
> close - and the car HAS to be on the road tomorrow morning...[/color]
True, plus, one cannot have too many tools!
[color=blue]
> Yeah, Right, Suuuuuuuure ya did... ;-P[/color]
Well, more of a brain fart than a typo.
[color=blue]
>[color=green]
> --<< Bruce >>--
>[/color]
Yup, as usual, you were right. The motor is GE, 13.1 A at 220 V. The
compressor is rated at 12 CFM at 90 PSI.
I know that Sears has a tendency to over rate their lawn mower HP, it makes
sense that they would do it for compressors. Oh well, it is good enough for
my needs most of the time.
Ray O
Old 09-20-2006, 07:45 PM   #15 (permalink)
Hachiroku
Guest
Posts: n/a
On Wed, 20 Sep 2006 02:38:49 +0000, Bruce L. Bergman wrote:
[color=blue]
>[color=green]
> easy disposal.
>[color=green]
> --<< Bruce >>--[/color]
Man, I'll be DIPPED!
Sears has a compressor on sale for $279, all the pressure I would need
(6SCFM@40PSI, 4SCFM@90PSI) WITH a 24 piece tool kit, including an Impact
wrench and a socket wrench!
DAMN!
BB code is Off
Smilies are Off
[IMG] code is Off
Newbie here: Getting 95 camry today! Mjakaz95LE Introduce Yourself Here 24 04-21-2009 07:06 AM
Camry did something wierd today HoboJoe Camry & Solara Lounge 8 01-01-2006 06:52 PM
Getting my driver's license today. epinionator89 Off Topic 21 07-30-2005 02:02 AM
Post Whore of the day YESCA Off Topic 2 04-05-2005 01:18 PM
What is going on in the car forums today? Ne0z31 Off Topic 17 11-30-2004 10:24 PM
