Re: fuel tank problem
On Mon, 18 Sep 2006 12:09:16 GMT, "Hachiroku" <Trueno@ae86.GTS> wrote:
[color=blue]
><pastordonlandis@juno.com> wrote in message
>news:1158560186.736759.118760@h48g2000cwc.googlegroups.com...[color=green]
>>I got some dirty gas in my Avalon gas tank. Is this tank siphon-able?
>> I can't seem to be able to siphon it out. Is there a safe and better
>> way of emptying the tank without taking the whole tank off?
>> Don
>>[/color]
>There is a drain with, I think a 3/4 or 1" square "socket" in it. Just
>remove the drain and drain the tank.
>You'll probably have to buy a tool to do this, unless you're a truck
>mechanic and have a ratchet with the right size...
>[/color]
Before removing the drain bolt, make sure to check with a dealer to
see if there's a gasket for this bolt. If so, it'd be best to obtain
one before removing it.
