Re: Car won't start?! '90 Celica
<omnineko@yahoo.com> wrote in message
news:1158599068.528157.54640@m73g2000cwd.googlegroups.com...[color=blue]
> Now this seemed a little odd to me. I have never had a problem with the
> car starting until today. It's about 63 degrees and raining.
> EVERYTHING in the car seems to function except the engine won't
> actually start. When I turn the key to the START position, NOTHING
> happens (no clicking, no nothing). Anything that could run off the
> battery (radio, lights, etc.) works perfectly fine.
> When I parked the car last night, everything was functioning perfectly.
> I'm a little stuck now.......
>[/color]
You will have to diagnose the starting system to determine why it will not
turn over.
If the car has an automatic transmission, is it in Park? If yes and yes,
try neutral.
If the car has a manual transmission, make sure there is nothing under the
clutch pedal like a floor mat.
Otherwise, check for power to the starter solenoid and work your way
backwards through the starting circuit to the ignition switch.
Ray O
