Re: 1998 Sienna LE
"eblaster" <eblaster@comcast.net> wrote in message
news:nsidnfAlg5SYX5LYnZ2dnUVZ_rWdnZ2d@comcast.com...[color=blue]
>I think it's electrical, sometimes the drivers side popup won't open or
>close.
> Thanks[/color]
The way to diagnose an electrical component is to use a volt meter to check
for voltage at the actuator or motor when you move the switch. If there is
power at the actuator or motor, then the actuator or motor may be bad so you
check the actuator or motor next. If there is no power at the
actuator/motor, then check the switch and then the circuit in between.
Ray O
[color=blue]
> "Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
> news:81a05$450f80d4$47c97f29$25685@msgid.meganewsservers.com...[color=green]
>> news:mYmdnVCjjpTdsJLYnZ2dnUVZ_rCdnZ2d@comcast.com...[color=darkred]
>>>I have two annoying problems with my 1998 Sienna LE.
>>> 1. The passenger side view mirror casing is loose and shakes while
>>> driving. I can't seem to find any way to tighten it.[/color]
>> Remove the interior trim to expose the mounting screws.
>>[color=darkred]
>>> 2. The passendger side rear pop-ip window no longer closes.
>>> Any help would be greatly appreciated.
>>> /Phil[/color]
>> Is the latch broken? Is the hinge broken:?
>> Ray O
>>[/color]
>[/color]
