<projman@optonline.net> wrote in message
news:1158613698.709903.93390@k70g2000cwa.googlegroups.com...[color=blue]
>I have an '83 Cressida that I just inherited. The car has 154k miles,
> 5MGE (2.8L) and AT. The car has been sitting for the past 5 years,
> started 2-3 times, and never driven during that period.
> I want to get this car back on the road. I replaced all the fluids, new
> plugs, cap, rotor, wires, air filter and fuel filter. The engine starts
> easily and idles very well. I measure 22" of manifold vacuum at idle
> (rock steady on the vac gauge), and set the timing to 12 deg BTDC and
> verified the ECU timing advance is OK.
> The problem is a significant hesitation, and loss of power when the
> throttle is opened. When in park, the motor won't stall, but attemtping
> to drive the car, it willl stall, and will not get above 20 mph.
> Anyone have any ideas as to where to start to diagnose this? I'll
> replace the O2 sensor, since it is original, and the motor will run
> better, although I doubt this is the cause of the problem. I may
> replace the TPS also, since it is also relatively inexpensive, and will
> also make the motor run better.
>[/color]
I do not recommend replacing parts without first checking their function.
Does the hesitation occur with the transmission in neutral or park or does
the hesitation occur only under load?
What happens to manifold vacuum when you rev the engine?
When you replaced the cap, rotor, plugs, and wires, did you use OEM parts?
I have seen problems like youa re describing with aftermarket ignition
parts.
Check the plastic intake tube between the air flow meter and the throttle
body for cracks and holes.
[color=blue]
> I don't want to replace the EGR or Air Flow Meter unless I am convinced
> that either/both will solve the problem. These parts are both quire
> expensive.
>[/color]
The EGR is relatively easy to check. With the engine idling, apply vacuum
with a Mighty-Vac or by sucking on the vacuum hose leading to the EGR. The
engine should start to stall if the EGR is functioning properly.
The air flow meter is basically a potentiometer. As air flows past the door
(flap), it pushes the door open, and as the door opens, it sends more
voltage to the ECU. If you measure voltage as you move the door by hand,
voltage should go up proportionately.
[color=blue]
> I sprayed the throttle bottle w/ Gumout to remove buildup.
> Thank you.
> - Glenn
>[/color]
Since the car has sat for so long, there is the possibility that the
injectors are gummed up. I would try either the Toyota branded fuel
injector cleaner that the Toyota dealer sells or Chevron Techron. Follow
the directions on the can. If the injectors are badly clogged, they can be
professionally cleaned.
If you have a fuel pressure gauge, you may want to check fuel pressure.
On Tue, 19 Sep 2006 00:25:16 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:1158613698.709903.93390@k70g2000cwa.googlegroups.com...[color=green]
>>[/color]
>parts.
>[color=green]
>> expensive.
>>[/color]
>[color=green]
>> Thank you.
>> - Glenn
>>[/color]
>If you have a fuel pressure gauge, you may want to check fuel pressure.[/color]
I would suggest to check the fuel pressure as well. I'd even suggest
to check this out first. When a car sits for a while, there's a
potential for the fuel pump to go bad.
That's exactly what caused the symptoms the OP described on my 1982 Cressida
(5ME engine)
"Viperkiller" <nothing@nothing.net> wrote in message
news:n51vg215u9ctali8kbq7jci3dtk1m5sjum@4ax.com...[color=blue]
>[color=green]
> >news:1158613698.709903.93390@k70g2000cwa.googlegroups.com...[color=darkred]
> >>[/color]
> >Does the hesitation occur with the transmission in neutral or park or[/color][/color]
does[color=blue][color=green]
> >When you replaced the cap, rotor, plugs, and wires, did you use OEM[/color][/color]
parts?[color=blue][color=green]
> >parts.
> >[color=darkred]
> >> expensive.
> >>[/color]
> >The EGR is relatively easy to check. With the engine idling, apply[/color][/color]
vacuum[color=blue][color=green]
> >with a Mighty-Vac or by sucking on the vacuum hose leading to the EGR.[/color][/color]
The[color=blue][color=green]
> >The air flow meter is basically a potentiometer. As air flows past the[/color][/color]
door[color=blue][color=green]
> >[color=darkred]
> >> Thank you.
> >> - Glenn
> >>[/color]
> >the directions on the can. If the injectors are badly clogged, they can[/color][/color]
be[color=blue][color=green]
> potential for the fuel pump to go bad.[/color]
Thx for your insight. Below are my responses to your comments.
The hesitation occurs in park and in gear. The motor will not hold any
rpm above, or slightly above, idle. I inspected the duct work between
the AFM and throttle body, and see/hear no leaks. Also, the vac gauge
is rock steady at 22" at idle. I don't think my problem is a vac leak,
or I'd see some movement on the vac gauge, or a lower reading at idle.
I will check the vac gauge, when opening the throttle. The engine does
not rev, so this test probably won't help. I will test the EGR w/ my
Mighty Vac. Thx for that idea. I think it is a good idea (better MPG's)
to replace the O2 sensor given that it is the original part that is 23
years old w/ 154k miles. My replacement parts are all aftermarket. I
don't think the problem is ignition related. My feeling is that it is
air/fuel delivery related, or an exhaust restriction. If the EGR checks
out OK, I will disconnect the exhaust pipe at the exhaust manifold to
confirm/rule out an exhaust restriction. Maybe my aftermkt fuel filter
is bad, but highly unlikely. I will also hook up my fuel pressure
gauge. My elec fuel pump is noisy. Is this normal for this car, or
maybe an indicator that it's going bad??? I'd also like to test the AFM
voltage as you recommend. I just bought a Chilton's book for this car
on eBay. I hope this procedure is in the book. I'll also add some
injector cleaner to the gas tank.
- Glenn
Ray O wrote:[color=blue]
> >[/color]
> parts.
>[color=green]
> > expensive.
> >[/color]
>[color=green]
> > Thank you.
> > - Glenn
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
news:1158675903.770905.170060@d34g2000cwd.googlegroups.com...[color=blue]
> Ray -
> not rev, so this test probably won't help.[/color]
The reason I asked about vacuum above idle is that I have seen some plastic
T-connectors crack and leak only when revving the engine, where the rocking
of the engine pulls on the connector enough to expose the crack. I've only
seen this a few times, and frankly, it is not high on my list of probable
causes.
I will test the EGR w/ my[color=blue]
> Mighty Vac. Thx for that idea.[/color]
I doubt if the EGR is the cause of the problem, but it doesn't hurt to check
it out.
I think it is a good idea (better MPG's)[color=blue]
> years old w/ 154k miles.[/color]
If you use an aftermarket O2 sensor that requires splicing wires, save the
pigtail connector off of the old sensor and splice that so that you do not
have to worry about the vehicle wire harness. I recommend soldering rather
than crimping, and using shrink tubing for insulation.
My replacement parts are all aftermarket. I[color=blue]
> confirm/rule out an exhaust restriction.[/color]
An easier way to check for an exhaust restriction is use a thick rag or
towel to block the exhaust at the tailpipe. The engine should run much
worse is the exhaust is free from obstructions. If it is the same, then
start looking for a restriction.
Maybe my aftermkt fuel filter[color=blue]
> maybe an indicator that it's going bad???[/color]
It has been a long time since I've ridden in an '83 Cressida, but I do not
recall them having a noisy fuel pump.
By the way, there are 4 possible causes of low fuel pressure, in order of
likelihood - bad fuel pump, bad fuel pressure regulator, restriction in the
fuel filter, and a leak or restriction in the fuel line. It is possible,
but unlikely, that fuel pressure will be OK but fuel volume is too low.
The check for fuel volume requires a glass beaker like a chemist would use,
and I forget the check - that is, how much volume over how long.
I'd also like to test the AFM[color=blue]
> - Glenn[/color]
