Re: Camry squeaks when braking after rain
"Dan" <Dan@homenetwork.com> wrote in message
news:hj2vg2tapr4r4n38k2bqevjsh7mk320pgq@4ax.com...[color=blue]
> My 2000 Carmy (4-Cylinder) would squeak a little when braking after
> rain. It's obvious that the brakes becomes a little rusty after rain.
> This happened after I left my car at a local garage shop for two
> hours. So right away I'm thinking if they did something stupid or
> ileggal with the brake.[/color]
A little surface rust on the rotors is normal under humid conditions.
[color=blue]
> The front brake rotors was replaced with brand new Toyota parts at a
> Toyota dealer when it squeaked last time about two years ago. They
> worked fine and never squeaked after either rain or snow in the past.
> So I'm thinking, could the guy at the shop take mine and replace them
> with something inferior. At this point, is there anything that I can
> do to make sure that the brake rotors are what they were?[/color]
I doubt if the garage would go through the trouble to take or steal used
rotors or pads. They would have to put some kind or replacement part on,
and the value of used parts, OEM or not, is not enough to make it worth
investing in the labor to take them.
[color=blue]
> If I take my car back to the dealer, which is at another state, would
> they be able to know if the rotors are what they put on two years ago?[/color]
They can only make a guess and they can tell if the rotors are OEM or
aftermarket.[color=blue]
> I'm sorry for not trusting others in this case.[/color]
If you have drum brakes in the rear, they may need to be cleaned.
Ray O
