Corolla 94 differential fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2006, 12:34 AM   #1 (permalink)
e_man_online@hotmail.com
Guest
Posts: n/a
View e_man_online@hotmail.com's Photo Gallery
Hi,
The only fluids I've serviced in my Corolla 94 1.6lt, automatic
transm.are the brake, engine
oil, the coolant and the transmission fluid. Do I need to replace the
differential fluid also? How is that done?
Thanks in advance,
Rick
Old 09-20-2006, 01:06 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Corolla 94 differential fluid?
<e_man_online@hotmail.com> wrote in message
news:1158726884.158793.292620@e3g2000cwe.googlegroups.com...[color=blue]
> Hi,
> Thanks in advance,
> Rick
>[/color]
Usually, the differential fluid is changed with the transmission fluid in a
vehicle with a transaxle. If the differential does not have a separate
drain and fill port, then its fluid is shared with the transmission.
Ray O
Old 09-20-2006, 08:28 AM   #3 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Wed, 20 Sep 2006 00:06:42 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:1158726884.158793.292620@e3g2000cwe.googlegroups.com...[color=green]
>> Hi,
>> Thanks in advance,
>> Rick
>>[/color]
>drain and fill port, then its fluid is shared with the transmission.[/color]
If the 94 is like my 92 there is a separate drain and refill point for
the differential.
The filler is a bitch to get to.
My transmission guy suggested filling the differential with hypoid
oil, which he did. His reasoning is the heat here in Florida is
better handled with hypoid oil.
Toyota suggests transmission fluid for the differential.
Scott in Florida
Old 09-20-2006, 12:18 PM   #4 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Scott in Florida wrote:[color=blue]
> the differential.
> oil,[/color]
Use the recommended fluid.
If you want to upgrade, use Mobil 1 synthetic ATF.
Use a funnel and 1/2" plastic hose to fill more easily from above.
Old 09-20-2006, 02:30 PM   #5 (permalink)
Rick
Guest
Posts: n/a
View Rick's Photo Gallery
Thanks Ray, so when the transmission fluid is changed, does the
differential gets automatically the fluid replaced or is it necessary
to tell the service technician?
Thank you in advance.
Rick
Ray O wrote:[color=blue]
> > Hi,
> > Thanks in advance,
> > Rick
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
Old 09-20-2006, 03:09 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
"Rick" <e_man_online@hotmail.com> wrote in message
news:1158777048.501159.164920@m73g2000cwd.googlegroups.com...[color=blue]
> Rick[/color]
I would not assume that the differential fluid will automatically be changed
when the transmission fluid is changed and so one should ask for
clarification at the service facility.
If you have had the transmission fluid changed in the past, the service
facility probably would list that they worked on the differential fluid if
they actually did so.
Ray O
(correct punctuation to reply)[color=blue]
> Ray O wrote:[color=green]
>> news:1158726884.158793.292620@e3g2000cwe.googlegroups.com...[color=darkred]
>> > Hi,
>> > Thanks in advance,
>> > Rick
>> >[/color]
>> a
>> Ray O
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
94 Corolla DX Sedan makes slight screeching noises when idle jinster Archived Corolla threads 1 07-09-2006 07:08 PM
getting a 94 corolla, wondering how possible a 20vavle swap is josh..just josh Archived Corolla threads 11 05-02-2006 12:12 AM
'94 Corolla Axle Trouble fyrcap100 Archived Corolla threads 1 03-20-2006 12:58 PM
94 Corolla power steering rack Toyota06 Archived Corolla threads 0 03-13-2006 04:02 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
