crankshaft pulley 1993 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2006, 12:05 PM   #1 (permalink)
Ralph
Guest
Posts: n/a
View Ralph's Photo Gallery
Jack wonders,
1993 Corolla ~300,000 km 1.8 liter 7A-FE
When replacing the timing belt, I spotted a crack on the hub of the
crankshaft pulley (harmonic balancer). The crack runs along above the
keyway.
Is there a recall or extended warranty on the pully?
Also, do you have an opinion on Canadian Tire spark plugs for this vehicle?
Your expert opinion is invited.
Old 09-21-2006, 12:54 PM   #2 (permalink)
Stuart Krivis
Guest
Posts: n/a
View Stuart Krivis's Photo Gallery
Re: crankshaft pulley 1993 Corolla
On Thu, 21 Sep 2006 13:05:41 -0400, "Ralph" <nospam@thanks.com> wrote:
[color=blue]
>Jack wonders,
>keyway.
>Is there a recall or extended warranty on the pully?[/color]
You could try asking a local Toyota dealer if there is or not.
[color=blue]
>Also, do you have an opinion on Canadian Tire spark plugs for this vehicle?[/color]
I've never heard of this brand (mainly because I don't live in
Canada), but I'd probably stick to ND (Nippon Denso) or NGK. I'd bet
the Denso plugs are OEM, so they could be the best bet.
The Canadian Tire ones may be perfectly fine and could save you some
money, but I guess you'll have to decide whether that's worth it or
not.
Old 09-21-2006, 01:39 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Ralph" <nospam@thanks.com> wrote in message
news:4512c66a_2@news.cybersurf.net...[color=blue]
> Jack wonders,
> keyway.
> vehicle?
>[/color]
A search of Transport Canada's web site shows only 2 recalls for 1993
Corollas. One is to remove an unused wire harness routed under the carpet
that can get corroded and the other is to fix a condition where the air bag
sensor may be damaged by liquids that are spilled in the center console.
There are no recalls, extended warranties, or service bulletins in the U.S.
on the crankshaft pulley.
In my experience, aftermarket ignition parts sometimes cause drivability
problems with Toyotas. There does not seem to be a pattern on which
aftermarket brands cause problems because an aftermarket brand that works
fine in one model might cause a problem in another. Rather than take a
chance in being stuck with ignition parts that cause drivability problems, I
recommend OEM ignition parts.
Ray O
Old 09-21-2006, 06:45 PM   #4 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Thu, 21 Sep 2006 13:54:38 -0400, Stuart Krivis wrote:
[color=blue]
>[color=green]
>>Jack wonders,
>>keyway.
>[color=green]
> the Denso plugs are OEM, so they could be the best bet.[/color]
Ya, I second that opinion. CT plugs are probably made by AC or Champion
and are cheap at best.
Depending on the engine model, either NGK or Densos are the best choice.
[color=blue]
> not.[/color]
Old 09-21-2006, 07:35 PM   #5 (permalink)
Ralph
Guest
Posts: n/a
Jack responds,
Thank you gentlemen.
- Jack
BB code is Off
Smilies are Off
[IMG] code is Off
Need advice for crankshaft pulley bolt removal BIG A Camry & Solara Lounge 13 08-13-2011 09:31 AM
Crankshaft pulley trouble... BIG BIG TROUBLE!! and little bit of reading... _VVTi_ Camry & Solara Lounge 12 06-18-2005 09:20 PM
How Do You Aim At The Crankshaft Pulley? jonrhaider MR2 Forum 12 04-22-2005 03:36 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
89 GTS Crankshaft Pulley? CameronG Archived Corolla threads 0 09-23-2004 11:56 AM
