"Radek" <radek@istar.ca> wrote in message
news:12h6hpj6rqisdb6@corp.supernews.com...[color=blue]
> Hello group.
> I'm new here, so far the little Echo has been running fine, giving me no
> reason to inquire. However, some time ago the MIL light went on and
> wouldn't go out. I bought a code reader and it gave me P0172 - system too
> rich (bank 1).
> Can anyone interpret this? Where do I go from there? Shoud I suspect the
> oxygen sensor or the mass air flow sensor? There seem to be no air leaks
> along the intake.
> Any help will be appreciated.
> TIA
> Radek in Ottawa, Canada
>[/color]
I would check the air filter, mass air flow sensor, and the oxygen sensor
mounted ahead of the catalytic converter, in that order. You can get access
to the factory service manual at techinfo.toyota.com for $10 U.S. per day
for the factory's procedure for diagnosing the trouble code and for checking
those components. You can try GENTLY cleaning the wire on the mass air flow
sensor with some rubbing alcohol and a cotton cloth or q-tip.
I replaced the filter already so now I will start with cleaning the wire.
Would you know where to get a complete service manual and how much would it
cost? One that would for example give resistance values for testing a
sensor? I've drifted from the VW/Audi world, where a Bentley manual
contains nearly all you need to know. What would be the counterpart of
Bentley in the Toyota world?
Thanks again.
Radek.
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:b8306$45135e47$47c97f29$31649@msgid.meganewsservers.com...[color=blue]
> news:12h6hpj6rqisdb6@corp.supernews.com...[color=green]
>> Hello group.
>> too rich (bank 1).
>> the oxygen sensor or the mass air flow sensor? There seem to be no air
>> leaks along the intake.
>> TIA
>>[/color]
> access to the factory service manual at techinfo.toyota.com for $10 U.S.
> per day for the factory's procedure for diagnosing the trouble code and
> for checking those components. You can try GENTLY cleaning the wire on
> the mass air flow sensor with some rubbing alcohol and a cotton cloth or
> q-tip.
> Ray O
> (correct punctuation to reply)
>[/color]
news:12h925beusdn34f@corp.supernews.com...[color=blue]
> Thanks Ray;
> it cost? One that would for example give resistance values for testing a
> Thanks again.
> Radek.[/color]
You can order a factory service manual from your local Toyota dealer.
Toyota Motor Sales U.S.A. allows consumers to order directly from their
Material Distribution Center, I would imagine that Toyota Canada has a
similar arrangement. The best manual for a Toyota is Toyota's factory
service manual. It has the most complete information of all the manuals
I've seen. There are a few shortcomings to the factory service manual -
their completeness means that they are about the size of a big city phone
book, and you sometimes have to order several volumes at close to $150 U.S.
each; they assume that the user is a professional technician so some
do-it-yourselfers do not understand some procedures, like taking a voltage
reading; and the troubleshooting matrices do not always seem logical.
The other alternative is to pay $10 U.S. per day for on line access to the
factory service manuals at techinfo.toyota.com or subscribe to Alldata,
which a lot of independent shops use for diagnosis.
Ray O
(correct punctuation to reply)[color=blue]
> news:b8306$45135e47$47c97f29$31649@msgid.meganewsservers.com...[color=green]
>> news:12h6hpj6rqisdb6@corp.supernews.com...[color=darkred]
>>> Hello group.
>>> too rich (bank 1).
>>> TIA
>>>[/color]
>> q-tip.
>> Ray O
>>[/color]
>[/color]
I cleaned the wire but the code is back. I guess I should now replace the
front oxygen sensor. Why are there two of these, anyway?
Cheers.
Radek.
news:76463$4514a097$47c97f29$3641@msgid.meganewsservers.com...[color=blue]
> news:12h925beusdn34f@corp.supernews.com...[color=green]
>> Thanks Ray;
>> Thanks again.
>> Radek.[/color]
> U.S. each; they assume that the user is a professional technician so some
> Ray O
> (correct punctuation to reply)[color=green]
>> news:b8306$45135e47$47c97f29$31649@msgid.meganewsservers.com...[color=darkred]
>>>> Hello group.
>>>> no reason to inquire. However, some time ago the MIL light went on and
>>>> too rich (bank 1).
>>>> TIA
>>> sensor mounted ahead of the catalytic converter, in that order. You can
>>> get access to the factory service manual at techinfo.toyota.com for $10
>>> U.S. per day for the factory's procedure for diagnosing the trouble code
>>> and for checking those components. You can try GENTLY cleaning the wire
>>> on the mass air flow sensor with some rubbing alcohol and a cotton cloth
>>> or q-tip.
>>> Ray O
>>>[/color]
>>[/color]
>[/color]
news:12hdtrstgp0668d@corp.supernews.com...[color=blue]
> Thanks again Ray.
> Cheers.
> Radek.[/color]
I would not replace the O2 sensor without first checking it. The procedure
for checking the O2 sensor will pretty much be the same as for a VW.
The MAF measures air flow, and the ECM determines how much fuel to mix with
the air. Once everything is warmed up, the O2 sensors measure O2 content in
the exhaust and "fine tunes" injector pulse duration. Under certain
conditions like wide open throttle, the ECM ignores the O2 sensor output and
uses the pre-set values.
The second O2 sensor monitors the exhaust after the catalytic converter and
monitors catalytic converter performance. The ECM compares the signal from
the second O2 sensor with the signal from the first O2 sensor. If the cat
is doing its job, the signal from the second O2 sensor should detect a
cleaner exhaust. If the quality of the exhaust coming out of the cat is the
same as what is going into the cat, then the ECM assumes that the cat is
bad.
Ray O
[color=blue]
> news:76463$4514a097$47c97f29$3641@msgid.meganewsservers.com...[color=green]
>> news:12h925beusdn34f@corp.supernews.com...[color=darkred]
>>> Thanks Ray;
>>> wire. Would you know where to get a complete service manual and how much
>>> would it cost? One that would for example give resistance values for
>>> testing a sensor? I've drifted from the VW/Audi world, where a Bentley
>>> manual contains nearly all you need to know. What would be the
>>> counterpart of Bentley in the Toyota world?
>>> Thanks again.
>>> Radek.[/color]
>> voltage reading; and the troubleshooting matrices do not always seem
>> logical.
>> the factory service manuals at techinfo.toyota.com or subscribe to
>> Alldata, which a lot of independent shops use for diagnosis.
>> Ray O
>> (correct punctuation to reply)[color=darkred]
>>>>> Hello group.
>>>>> and wouldn't go out. I bought a code reader and it gave me P0172 -
>>>>> system too rich (bank 1).
>>>>> air leaks along the intake.
>>>>> TIA
>>>> can get access to the factory service manual at techinfo.toyota.com for
>>>> $10 U.S. per day for the factory's procedure for diagnosing the trouble
>>>> code and for checking those components. You can try GENTLY cleaning
>>>> the wire on the mass air flow sensor with some rubbing alcohol and a
>>>> Ray O
>>>[/color]
>>[/color]
>[/color]
