Rear Brakes/ Parking Brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2006, 09:40 AM   #1 (permalink)
Cornerman
Guest
Posts: n/a
View Cornerman's Photo Gallery
92 Tercel.
I have new shoes and turned drums. No leaks, relatively low fluid. Two
(or three) questions:
The parking brake lever works, and spreads the shoes, but doesn't hold
until about 7 clicks. I think that's too far. The pedal travel is also
what I believe is too much. I think I need to adjust the star adjuster
on my brakes, but I'm just not sure how spread out I should go. Should
I go until the drum can't move with light force, and the slightly back
off???
In other vehicles, I just adjust until very slight drag, and the
auto-adjuster seat the brakes in reverse. The auto-adjusting doesn't
seem to be happening in the Tercel. Is there a different method of
self-adjustment?
TIA,
Fred
Old 09-22-2006, 10:09 AM   #2 (permalink)
njmodi
Guest
Posts: n/a
View njmodi's Photo Gallery
Re: Rear Brakes/ Parking Brake
Cornerman wrote:[color=blue]
> 92 Tercel.
>[/color]
<snip>
I think I need to adjust the star adjuster[color=blue]
> off???
>[/color]
<snip>
That's what I always do. It should take care of your problem. You
should be able to turn the drum by hand without the wheel on the hub
but feel a slight resistance from the shoes.
Nirav
97 Corolla DX - Sold
Old 09-22-2006, 01:11 PM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Fri, 22 Sep 2006 07:40:00 -0700, Cornerman wrote:
[color=blue]
> 92 Tercel.
> off???
> self-adjustment?
> TIA,
> Fred[/color]
If you assembled everything properly, and DIDN'T put one of the adjusters
on BACKWARDS like I did (Hey...all my other cars were Disc rears!) Then
all you have to do is hold the button on the parking brake handle and move
it up and down a few times.
As for the atcual travel of the handle, there is an adjustment under the
console for that...it means the cable is stretching.
Old 09-22-2006, 02:31 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Cornerman" <ohagnir@gmail.com> wrote in message
news:1158935999.926531.312000@i42g2000cwa.googlegroups.com...[color=blue]
> 92 Tercel.
> off???
> self-adjustment?
> TIA,
> Fred
>[/color]
I adjust rear brakes so that with the wheel and tire mounted, it rotates
about 1 to 1 and a half times when you give it a spin by hand.
Ray O
Old 09-25-2006, 07:47 AM   #5 (permalink)
Cornerman
Guest
Posts: n/a
Ray O wrote:
[color=blue][color=green]
> > Fred
> >[/color]
> --[/color]
Thanks Ray. I definitely wasn't that far.
Fred
Old 09-25-2006, 08:38 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1159188439.753856.229230@m73g2000cwd.googlegroups.com...[color=blue]
> Ray O wrote:
>[color=green][color=darkred]
>> > Fred
>> >[/color]
>> --[/color]
> Fred
>[/color]
you're welcome!
Ray O
Old 09-25-2006, 06:12 PM   #7 (permalink)
TeGGeR®
Guest
Posts: n/a
View TeGGeR®'s Photo Gallery
"Cornerman" <ohagnir@gmail.com> wrote in news:1158935999.926531.312000
@i42g2000cwa.googlegroups.com:
[color=blue]
> 92 Tercel.
> until about 7 clicks. I think that's too far.[/color]
You "think" thatt's too far? What is the basis for your "think"?
According to the Tercel factory workshop manual, the brake lever should be
fully engaged between 5 and 8 clicks.
Adjustment is done by working the parking brake handle up and down
repeatedly until it won't adjust any more.
Keep in mind that new shoes will take a while to wear to the exact diameter
of the drum, so you may find the lever and pedal to be a tad loose for a
few months until they wear in.
TeGGeR®
Old 09-29-2006, 12:50 PM   #8 (permalink)
Cornerman
Guest
Posts: n/a
TeGGeR® wrote:[color=blue]
> few months until they wear in.[/color]
To conclude, the brakes did indeed settle in and self-adjust after
about a week (or at least, that's when I noticed how good everything
felt). Parking brake engage and hold at about 5 or 6 clicks.
Thanks everyone,
Fred
BB code is Off
Smilies are Off
[IMG] code is Off
Parking brake adjustment 93ToyCorolla Archived Corolla threads 16 10-01-2006 08:28 PM
engine/ABS light help.... trninhds Camry & Solara Lounge 11 06-17-2006 11:06 PM
'87 4wd pickup rear brake clunk krupy13 Pre-88 Toyota Pickup/Hilux 1 10-05-2005 06:15 PM
Rear brake squeal on an '03 LE (drum) Corollaized Archived Corolla threads 0 10-15-2004 07:05 PM
