Wheel Studs, 4 enough? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2006, 02:53 PM   #1 (permalink)
ZR
Guest
Posts: n/a
View ZR's Photo Gallery
The tire place where I bought tires months ago cross threaded one of the
studs on the right rear wheel on my 90 Camry. The wheel nut was not
tightened all the way in. It has been like this for nearly a year till today
I found it out when rotating tires. I broke the stud when trying to loose
the nut. The wheel hub/bearing assembly looks very expensive to replace for
this car.
So the question is it enough to just have 4 studs?
Thanks for your help!
Old 09-23-2006, 04:03 PM   #2 (permalink)
SilverStude
Guest
Posts: n/a
View SilverStude's Photo Gallery
Re: Wheel Studs, 4 enough?
ZR wrote:[color=blue]
> this car.
>[/color]
[color=blue][color=green]
>>is it enough to just have 4 studs?<<[/color][/color]
Yes, but it won't pass a safety inspection...
I'd go back to the Tire place and put it in their face. They'll
probably tell you to take a hike, but it's worth the try..
The lugs are able to be pressed out of the rotor/drum and replaced.
If you're a bit mechanically inclined, not a big job to remove either,
then take it to a service station. To have them could do the whole
thing would be at around $50.00 an hour.
Old 09-23-2006, 04:23 PM   #3 (permalink)
FantomFan
Guest
Posts: n/a
View FantomFan's Photo Gallery
"ZR" <ZR@ABC.com> wrote in message
news:7hgRg.215$Y24.26@newsread4.news.pas.earthlink.net...[color=blue]
> today I found it out when rotating tires. I broke the stud when trying to
> loose the nut. The wheel hub/bearing assembly looks very expensive to
> replace for this car.
>[/color]
You should be able to replace just the stud.
Old 09-23-2006, 05:01 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
>[/color]
4 is enough for temporary use, but the problem with using 4 nuts on a
vehicle designed for 5 is that the wheel will be tightened unevenly,
contributing to rotor/drum warpage.
Individual studs can be replaced by pressing them out. If you are lucky, by
rotating the hub, you may be able to find a spot with enough clearance to
press the bad stud out without having to remove the hub.
Ray O
Old 09-23-2006, 05:03 PM   #5 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
> ... I broke the stud when trying to loosen the nut.[/color]
Just have your garage replace the stud. Should take at most 30 minutes. In
theory they are pressed in, but in practice all you do is bop the old one
out, put the new one in the hole from the back, stick a socket over the stud
and screw a wheel nut on to pull the stud into the hole. Then put the wheel
back on.
SD
Old 09-23-2006, 07:26 PM   #6 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
New stud about $3 - wack out with a hammer and pull new one in with the
wheel bolt.
>[/color]
Old 09-23-2006, 07:37 PM   #7 (permalink)
ZR
Guest
Posts: n/a
>> The tire place where I bought tires months ago cross threaded one of the[color=blue][color=green]
>>[/color]
> by rotating the hub, you may be able to find a spot with enough clearance
> to press the bad stud out without having to remove the hub.[/color]
Cool! Thanks everyone. I didn't know the stud can be replaced and thought I
had to replace the whole assembly.
I'm assuming I need to push the bad stud in towards the car and pull the new
stud out away from the car from behind the hub. Does that sound right?
Old 09-23-2006, 07:58 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:YqkRg.383$Y24.56@newsread4.news.pas.earthlink.net...[color=blue][color=green][color=darkred]
>>> to loose the nut. The wheel hub/bearing assembly looks very expensive to
>>>[/color]
> I had to replace the whole assembly.
> new stud out away from the car from behind the hub. Does that sound right?
>[/color]
Yes, non only does that sound right, it is right!
Ray O
Old 09-24-2006, 02:02 AM   #9 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sat, 23 Sep 2006 18:03:11 -0400, "Stewart DIBBS" <sjd@pixcl.com>
wrote:[color=blue]
>news:7hgRg.215$Y24.26@newsread4.news.pas.earthlink.net...[/color]
>back on.[/color]
But be warned: If at all possible, you /really/ want to take the
extra effort to remove the hub from the car and remove the broken stud
on the workbench supported by blocks on each side of the hole, or in a
hydraulic press. You can suck the new stud into the hub hole with a
lugnut and a stack of washers if you can't press it in.
Pounding on the broken stud with a hammer to remove it with the hub
still mounted on the car is just asking for Brinnelling damage to the
wheel bearings - the hammering makes tiny dents in the races with the
bearing rollers, and before you know it the wheel bearing is making
those ominous rumbling noises...
--<< Bruce >>--
Old 09-24-2006, 09:01 AM   #10 (permalink)
ZR
Guest
Posts: n/a
>>> ... I broke the stud when trying to loosen the nut.[color=blue][color=green]
>>stud
>>wheel
>>back on.[/color]
>[/color]
Good advise! Thanks!
BB code is Off
Smilies are Off
[IMG] code is Off
wheel studs help me~~~~ djfetus Camry & Solara Lounge 6 08-24-2005 09:48 AM
AE92 GTS wheel studs browner Archived Corolla threads 3 08-24-2005 02:07 AM
Wheel studs help majorgercko1 Camry & Solara Lounge 0 07-18-2005 11:22 PM
Tilt Wheel Vs Non-tilt Wheel atd332 Archived Corolla threads 0 07-15-2005 10:17 PM
