Corolla engine oil debate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2006, 01:53 PM   #1 (permalink)
Rick
Guest
Posts: n/a
View Rick's Photo Gallery
Hi,
I live in Florida and have a Corolla '94 with 112K miles in reat
condition, used but not abused. What thickness oil would you recommend
according to model/miles/climate?
Thank you in advance,
Rick
Old 09-26-2006, 02:22 PM   #2 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Re: Corolla engine oil debate
Rick, 9/26/2006, 2:53:26 PM,
<1159296806.062945.137800@m73g2000cwd.googlegroups.com> wrote:
[color=blue]
> Hi,
> according to model/miles/climate?[/color]
What does your owner's manual say?
Old 09-26-2006, 04:49 PM   #3 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On 26 Sep 2006 11:53:26 -0700, "Rick" <e_man_online@hotmail.com>
wrote:
[color=blue]
>Hi,
>Rick[/color]
I have a '92 Corolla Wagon
The book recommends 5W-30.
I would assume yours is the same.
Scott in Florida
Old 09-26-2006, 06:30 PM   #4 (permalink)
Rick
Guest
Posts: n/a
The owners' manual doesn't tell about the thickness, probably b/c it
depends on mileage and climate.
badgolferman wrote:[color=blue]
>[color=green]
> > Hi,
> What does your owner's manual say?[/color]
Old 09-26-2006, 10:11 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Rick" <e_man_online@hotmail.com> wrote in message
news:1159313410.794327.62540@h48g2000cwc.googlegroups.com...[color=blue]
> depends on mileage and climate.[/color]
I would be very surprised if the owner's manual did not give a specification
for oil viscocity because it has been in every other Toyota owner's manual
I've seen. Oil viscosity and grade should also be screened on nthe oil
filler cap.
If in doubt, use oil that is marked "API Service SM" 5W-30.
Ray O
Old 09-26-2006, 11:04 PM   #6 (permalink)
Truckdude
Guest
Posts: n/a
View Truckdude's Photo Gallery
[color=blue]
> badgolferman wrote:[color=green]
>>[color=darkred]
>> > Hi,
>[/color]
>[/color]
Oh, really??
Are you missing any pages? Your owner's manual most definitely recommends
what viscosity to use based on climate. You'd better check again...
Old 09-27-2006, 07:42 PM   #7 (permalink)
Joey
Guest
Posts: n/a
View Joey's Photo Gallery
Ray,
I would like to followup with another question. My Highlander
recommends 5W-30 and I've used this weight in Castrol Oil but....it's
getting harder to find in my area but 10W-30 is plentiful. What are
your thoughts on switching weights?
J
Ray O wrote:[color=blue]
>[color=green]
> filler cap.
> If in doubt, use oil that is marked "API Service SM" 5W-30.[/color]
Old 09-27-2006, 08:27 PM   #8 (permalink)
SlyckTom
Guest
Posts: n/a
View SlyckTom's Photo Gallery
I have a 93 Corolla...Look at the oil filler cap. If your manual
doesn't say it (it does for my year) it will certainlly be labled
there. In any case, the oil recommendation for my year Corolla is
10w-30.
Tom
wrote:
[color=blue]
>Hi,
>Rick[/color]
Old 09-27-2006, 08:40 PM   #9 (permalink)
badgolferman
Guest
Posts: n/a
Joey, 9/27/2006,8:42:34 PM, wrote:
[color=blue]
> your thoughts on switching weights?[/color]
I think it depends upon the temperature range of your area. 5W-30 oil
has a wider temperature range than 10W-40, especially at colder
temperatures. Most manufacturers recommend 5W-30 because it is
supposedly fuel-saving compared to 10W-30. Your manual probably has a
chart like mine does.
Old 09-27-2006, 09:48 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
"Joey" <J_nospam_@mou.net> wrote in message
news:12hm6jl560kv7c8@corp.supernews.com...[color=blue]
> Ray,
> I would like to followup with another question. My Highlander recommends
> 5W-30 and I've used this weight in Castrol Oil but....it's getting harder
> to find in my area but 10W-30 is plentiful. What are your thoughts on
> switching weights?
> J[/color]
I would stick to the factory recommendation. The recommendation for most,
if not all, newer Toyotas is 5W-30, and so I doubt if it will go away. I'd
start looking at another store for oil.
Ray O
(correct punctuation to reply)[color=blue]
> Ray O wrote:[color=green]
>>[color=darkred]
>> specification for oil viscocity because it has been in every other Toyota
>> owner's manual I've seen. Oil viscosity and grade should also be
>> screened on nthe oil filler cap.
>> If in doubt, use oil that is marked "API Service SM" 5W-30.[/color][/color]
Old 09-28-2006, 09:49 AM   #11 (permalink)
Stuart Krivis
Guest
Posts: n/a
View Stuart Krivis's Photo Gallery
On Wed, 27 Sep 2006 21:40:07 -0400, "badgolferman"
<REMOVETHISbadgolferman@gmail.com> wrote:
[color=blue]
>[color=green]
>chart like mine does.[/color]
5W-30 is fuel-saving over 10W-30, although I don't know how much
difference there is.
If the auto maker wants the EPA to run their tests using the 5W-30 to
possibly boost the mileage numbers, they have to specify 5W-30 as the
standard recommended oil, no matter whether it's good for the majority
of their customers or not.
Honda is now specifying a 5W-20 in an attempt to boost their overall
CAFE numbers even further.
Old 09-28-2006, 10:20 AM   #12 (permalink)
Kurt Krueger
Guest
Posts: n/a
View Kurt Krueger's Photo Gallery
Stuart Krivis wrote:
[color=blue]
>[color=green]
>>[color=darkred]
>>chart like mine does.[/color][/color]
Something else to consider. Consumer's Report did an article on oil some
years back. The modifiers in the multi weight stuff tend to break down
over the life of the oil. So the 10-40 they tested ended up more like
5-30 after a while. The ones with the least modifiers (i.e. the least
range) did better. That means the 10-30 will do a better job at
maintaining it's characteristics than 5-30.
Your manual should have a chart. Choose an oil from the hot end of
the chart for your Florida climate.
BTW, around here the heavier oils (like 20-50) are hard to find in
the winter, but are plentiful in the summer. Maybe your 5-30 will
be come more prevalent in the next few months.
Old 09-29-2006, 06:39 AM   #13 (permalink)
do_not_spam_me@my-deja.com
Guest
Posts: n/a
View do_not_spam_me@my-deja.com's Photo Gallery
Kurt Krueger wrote:
[color=blue]
> maintaining it's characteristics than 5-30.[/color]
But that article was published in the late 1980s and applied to SF
grade oils, and at about the same time, GM issued a statement that was
critical of SF oils as well and found that none of the 10W-40 oils met
SF standards (CR said only one 10W-40 maintained viscosity). But in
their more recent test, published about 10 years ago, they found that
all SH grade oils maintained viscosity sufficiently. That grade has
since been succeeded by SJ, SL, and currently SM.
Old 09-29-2006, 07:10 AM   #14 (permalink)
ACAR
Guest
Posts: n/a
View ACAR's Photo Gallery
Rick wrote:[color=blue]
> Hi,
> Rick[/color]
Used not abused indicates it's not burning oil. I gotta agree with Ray,
5W-30.
Worried about thermal breakdown? Use synthetic.
Consuming more than a quart every 3000 miles? Go to 10W-30.
Getting the filter changed every time the oil is changed?
I'm still using 5W-30 in a '89 car with over 215K miles.
Old 09-29-2006, 09:23 AM   #15 (permalink)
Scott in Florida
Guest
Posts: n/a
On 29 Sep 2006 05:10:57 -0700, "ACAR" <dimndsonmywndshld@yahoo.com>
wrote:
[color=blue]
>Rick wrote:[color=green]
>> Hi,
>> Rick[/color]
>5W-30.
>I'm still using 5W-30 in a '89 car with over 215K miles.[/color]
I'm using 5W-30 in my 92 Corolla wagon with 195,000.
Scott in Florida
BB code is Off
Smilies are Off
[IMG] code is Off
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
'98 Corolla engine noise earthmover Archived Corolla threads 5 10-28-2009 09:16 PM
Part IV; 20R ENGINE REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 6 10-05-2006 11:28 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
20W-50 or 10W-30 Engine oil for 04 corolla? drstillpatient Archived Corolla threads 20 11-29-2004 12:41 PM
