1992 Toyota Celica ST w/1.6L engine - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2006, 12:22 PM   #1 (permalink)
George Spafford
Guest
Posts: n/a
View George Spafford's Photo Gallery
Hello.
I could really use some help. I lost power and the car wouldn't
start. I checked the computer and the only error code was the vacuum
sensor. If I unplug the vacuum sensor on the firewall, the engine
will at least start but not rev past 1,200 RPM. I now have a new $360
dollar Toyota sensor and the car still will not run.
During my testing with the sensor unplugged, I then noticed the
exhaust down pipe was glowing red and there was air blowing out of the
vacuum lines vs. sucking air in.
I then thought that maybe I had blockage in my exhaust. I removed the
exhaust at the Catalytic converter and it seems to run easier but I
still have air coming out of the vacuum lines (the line going to the
pressure sensor & at the valve cover). Before taking the exhaust off,
I could only get the RPM up to 1,000 without the sensor. With the
exhaust off, I can get the RPM up to 1,200.
At this point, if I plug in the vacuum sensor wire harness then the
car stalls very quickly. I have the exhaust off the car right now and
the brand new sensor installed.
What should I be looking at? I am confused. Do I have a sticking or
bent valve? I don't hear any funny noises and the car seems to turn
over easily. I put a wrench on the crank and can readily turn it.
I have not pulled the valve cover off yet.
I could really use some help right now as I don't know what to make of
these symptoms.
Old 09-27-2006, 01:17 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1992 Toyota Celica ST w/1.6L engine
"George Spafford" <gspaff@sbcglobal.net> wrote in message
news:ftblh213hvgs0b44pf3n6gmncsqisnfn3u@4ax.com...[color=blue]
> Hello.
>[/color]
It is never a good idea to replace a part without first checking the part to
see if it is functioning properly or not.
Also, when a computer identifies a particular component, the correct
procedure is to check to see if the component is functioning properly, and
if it is, check the circuit for that component and other systems and
components that are related to the identified component.
It is very unlikely that a bad vacuum sensor will prevent a car from
starting.
[color=blue]
> over easily. I put a wrench on the crank and can readily turn it.[/color]
I think you still have a blockage in the exhaust. When you say that you
removed the exhaust at the catalytic converter, is that before or after the
converter? In other words, is the catalytic converter still on the car?
What happens if you remove the converter?[color=blue]
> I have not pulled the valve cover off yet.[/color]
Ray O
Old 09-27-2006, 03:59 PM   #3 (permalink)
George Spafford
Guest
Posts: n/a
On Wed, 27 Sep 2006 13:17:44 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>What happens if you remove the converter?[/color]
With the converter off, it runs a little better - RPM increased from
1,000 to 1,200. I'm getting ready to put a replacement exhaust on
right now to see if lack of backpressure is causing any issues. I
figured that eliminates the entire issue.
Why do you think I have air pressure coming out the vacuum lines vs. a
vacuum? Air is literally blowing out the lines.
Old 09-27-2006, 04:53 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:kbplh210u29q50d26ola86lrieebd8s5dg@4ax.com...[color=blue]
>[color=green]
>>the
> vacuum? Air is literally blowing out the lines.[/color]
Old 09-27-2006, 04:56 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
>[color=green]
>>the
> figured that eliminates the entire issue.[/color]
I doubt if the lack of backpressure is causing the problem. A crack or leak
in the exhaust manifold can make it get hot and glow cherry red, and an
obstruction in the exhaust can also cause problems. ]
[color=blue]
I've never run across that problem, but I would imagine that an obstruction
in the exhaust could cause it, along with a valve train problem like a stuck
valve or incorrect valve timing.
Ray O
Old 09-27-2006, 08:12 PM   #6 (permalink)
George Spafford
Guest
Posts: n/a
I sorted it out finally - I thought I was going nuts.
A clogged catalytic converter kicked matters off causing all the
backpressure. Little did I know that the distributor cap was loose
and had shifted all the way to one end of the bracket last night
causing all the poor running today. You were right - lack of
backpressure wasn't the problem.
Thank you for your help Ray. I think I am all set now.
On Wed, 27 Sep 2006 16:56:57 -0500, "Ray O"
[color=blue]
>news:kbplh210u29q50d26ola86lrieebd8s5dg@4ax.com...[color=green]
>>[color=darkred]
>>>the
>[color=green]
>valve or incorrect valve timing.[/color]
Old 09-27-2006, 09:50 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:b58mh2ho5v34dka3rhjnmjbif03ckt2hcd@4ax.com...[color=blue]
>[/color]
You're welcome and thanks for sharing your results!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
90 celica st worth $250 w/o engine? SymtecX2003 Celica Forum 11 08-07-2006 12:28 AM
