door handle failure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2006, 08:45 AM   #1 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
door handle failure
My 97 Camry has a problem with the passenger side outside door handle.
It will not open the door and acts as if it is still locked. The door
opens fine from the inside and the lock mechanism works fine from the
inside and the outside.
Obviously I will have to remove the inside door cover to get to this
mechanism. Any tips on how to accomplish this task? Thanks.
Old 09-29-2006, 11:02 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: door handle failure
"badgolferman" <REMOVETHISbadgolferman@gmail.com> wrote in message
news:xn0ersl9wlkv741001@news.readfreenews.net...[color=blue]
> mechanism. Any tips on how to accomplish this task? Thanks.[/color]
There will be one or two plastic plugs in the underside of the arm rest.
Pop the plugs out to get access to the screws under there. Also, there may
be a screw in the trim bezel behind the inner door latch. It may be
worthwhile to invest in a trim removal tool, it looks almost like one of
those tools for digging weeds out of the garden - screwdriver handle with a
blade with a notch in it. You can also use your fingertips or a putty
knife. Starting at the bottom of the door panel, carefully pull the inner
door panel away from the door and work your way around the leading and
trailing edge of the door. After all of the clips are free, unplug the
courtesy light (if there is one) and the power window/lock controls (if you
have them) and then lift the panel straight up to unhook it from the door
frame. You will see a plastic film covering the opening held in place with
putty. When you pull the plastic away, it is less likely to tear if you use
a quick jerking motion, like ripping a band aid off. Repair any tears with
duct tape. The door latch is connected with clips to rods, see if any are
disconnected or jammed.
Good luck!
Ray O
Old 09-29-2006, 12:27 PM   #3 (permalink)
mack
Guest
Posts: n/a
View mack's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:656b1$451d4475$44a4a10d$22956@msgid.meganewsservers.com...[color=blue]
> news:xn0ersl9wlkv741001@news.readfreenews.net...[color=green]
> may be a screw in the trim bezel behind the inner door latch. It may be
> a blade with a notch in it. You can also use your fingertips or a putty
> you have them) and then lift the panel straight up to unhook it from the
> door frame. You will see a plastic film covering the opening held in
> place with putty. When you pull the plastic away, it is less likely to
> tear if you use a quick jerking motion, like ripping a band aid off.
> Repair any tears with duct tape. The door latch is connected with clips
> to rods, see if any are disconnected or jammed.
> Good luck!
> Ray O
>[/color]
Getting the door panel off is the easy part. If, as on MY '97 Camry, which
experienced the same problem, the clip and rod have separated, you'll have
to put on a new clip to hold the mechanism together. It's fairly
straightforward to see and figure out, but getting a clip into this limited
access area is a pain. I ended up fabricating a substitute for the clip
(which had disappeared) and putting it in place with some difficulty.
Good Luck!
Old 09-29-2006, 11:10 PM   #4 (permalink)
Dave L
Guest
Posts: n/a
View Dave L's Photo Gallery
What is it with Toyota door handles? Great cars, but the only vehicles I
can recall when people have broken door handles have all been Toyotas. Is
this just a coincidence or a weak link on Toys?
-Dave
Old 09-30-2006, 06:47 AM   #5 (permalink)
High Tech Misfit
Guest
Posts: n/a
View High Tech Misfit's Photo Gallery
Dave L wrote:
[color=blue]
> -Dave[/color]
I've seen it on many makes, foreign and domestic. I remember a guy who had
to enter his Audi on the passenger side beside the driver's door handle was
busted.
Old 09-30-2006, 01:45 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
"Dave L" <davelieuREMOVEME@yahoo.com> wrote in message
news:t8ydnfQv466LcoDYnZ2dnUVZ_qudnZ2d@comcast.com...[color=blue]
> -Dave[/color]
I've seen the problem with other makes as well. I think that most of the
time, it comes from trying to force the handle when the door is locked or
from trying to slim jim the car.
Ray O
Old 09-30-2006, 05:11 PM   #7 (permalink)
Dave L
Guest
Posts: n/a
news:254f9$451ebed1$180ffe52$1098@msgid.meganewsservers.com...[color=blue]
> news:t8ydnfQv466LcoDYnZ2dnUVZ_qudnZ2d@comcast.com...[color=green]
>> news:xn0ersl9wlkv741001@news.readfreenews.net...[color=darkred]
>> Is this just a coincidence or a weak link on Toys?
>> -Dave[/color]
> Ray O
> (correct punctuation to reply)[/color]
I'm sure. Maybe it's because I know so many people who own Toyotas vs.
other makes. Either way it's probably more from abuse than anything else.
-Dave
Old 09-30-2006, 05:53 PM   #8 (permalink)
badgolferman
Guest
Posts: n/a
Ray O, 9/30/2006,2:45:43 PM, wrote:
[color=blue]
> the time, it comes from trying to force the handle when the door is
> locked or from trying to slim jim the car.[/color]
I suspect this is the case since my son has a habit of trying to open
the door at the same time as I'm trying to unlock it. In fact this was
when it happened I think.
Old 10-02-2006, 07:11 AM   #9 (permalink)
badgolferman
Guest
Posts: n/a
Ray O, 9/29/2006, 12:02:06 PM,
<656b1$451d4475$44a4a10d$22956@msgid.meganewsservers.com> wrote:
[color=blue]
> > handle. It will not open the door and acts as if it is still
> > locked. The door opens fine from the inside and the lock mechanism
> > works fine from the inside and the outside.
> rest. Pop the plugs out to get access to the screws under there.
> Also, there may be a screw in the trim bezel behind the inner door
> latch. It may be worthwhile to invest in a trim removal tool, it
> looks almost like one of those tools for digging weeds out of the
> garden - screwdriver handle with a blade with a notch in it. You can
> also use your fingertips or a putty knife. Starting at the bottom of
> the door panel, carefully pull the inner door panel away from the
> door and work your way around the leading and trailing edge of the
> door. After all of the clips are free, unplug the courtesy light (if
> there is one) and the power window/lock controls (if you have them)
> and then lift the panel straight up to unhook it from the door frame.
> you use a quick jerking motion, like ripping a band aid off. Repair
> any tears with duct tape. The door latch is connected with clips to
> Good luck![/color]
Ray,
I disassembled the door and can barely get a peek at the door latch
mechanism through the round hole opposite the rod that attaches to the
door handle. There is a rod coming up from the latch or someplace that
has a pin at the end at a 90 degree angle. This pin goes through a
protrusion from the outside door handle and sticks out barely on the
other side of the hole. The pin has an indentation at the end which
looks like it takes a retaining ring to lock it in place so it won't
fall out of the hole. I have tried e-clips, different sized retaining
clips to snap onto the pin but have been unsuccessful. They are all
now at the bottom of the door somewhere and I am unable to find them
anymore.
Do you have any suggestions on how to keep that pin from falling out of
the hole?
Old 10-02-2006, 08:49 AM   #10 (permalink)
badgolferman
Guest
Posts: n/a
badgolferman, 10/2/2006, 8:11:47 AM,
<xn0erzjp3prtwey003@news.readfreenews.net> wrote:
[color=blue]
>[color=green]
> > > mechanism works fine from the inside and the outside.
> > > this mechanism. Any tips on how to accomplish this task? Thanks.[/color]
> > can also use your fingertips or a putty knife. Starting at the
> > bottom of the door panel, carefully pull the inner door panel away
> > from the door and work your way around the leading and trailing
> > (if you have them) and then lift the panel straight up to unhook it
> > from the door frame. You will see a plastic film covering the
> > opening held in place with putty. When you pull the plastic away,
> > it is less likely to tear if you use a quick jerking motion, like
> > ripping a band aid off. Repair any tears with duct tape. The door
> > latch is connected with clips to rods, see if any are disconnected
> > or jammed.
> > Good luck![/color]
> Ray,
> that has a pin at the end at a 90 degree angle. This pin goes
> through a protrusion from the outside door handle and sticks out
> barely on the other side of the hole. The pin has an indentation at
> the end which looks like it takes a retaining ring to lock it in
> place so it won't fall out of the hole. I have tried e-clips,
> different sized retaining clips to snap onto the pin but have been
> unsuccessful. They are all now at the bottom of the door somewhere
> and I am unable to find them anymore.
> of the hole?[/color]
Never mind. I realize now there is a plastic clip that effectively
makes the pin larger so it fits through the hole. That clip is broken
and I have removed it to get a replacement.
Old 10-02-2006, 09:44 AM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:xn0erzm77pvb22z007@news.readfreenews.net...[color=blue]
>[color=green]
>>[color=darkred]
>> > or jammed.
>> > Good luck![/color]
>> Ray,
> and I have removed it to get a replacement.[/color]
The clips for the various rods in the door should be self-locking, with not
extra retainer clips needed to hold the rods in place. If possible, I
would fish out all of the loose pieces out of the bottom of the door so that
they do not rattle. Use some of the sticky black stuff that holds the
plastic liner on the end of a stiff wire, then peel the black goo off of the
wire and re-use to hold the plastic liner in place.
Ray O
Old 10-03-2006, 01:29 PM   #12 (permalink)
badgolferman
Guest
Posts: n/a
Ray O, 10/2/2006, 10:44:25 AM,
<e0b74$45212891$44a4a10d$8727@msgid.meganewsservers.com> wrote:
[color=blue][color=green]
> > broken and I have removed it to get a replacement.[/color]
> with not extra retainer clips needed to hold the rods in place. If
> possible, I would fish out all of the loose pieces out of the bottom
> of the door so that they do not rattle. Use some of the sticky black
> stuff that holds the plastic liner on the end of a stiff wire, then
> peel the black goo off of the wire and re-use to hold the plastic
> liner in place.[/color]
The clip was purchased at dealer for $4.44. I installed it today and
it works fine. All that's left is getting the door covering back on.
Thanks for your help.
Old 10-03-2006, 01:37 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
news:xn0es186mrkrb89005@news.readfreenews.net...[color=blue]
>[color=green][color=darkred]
> Thanks for your help.\[/color]
You're welcome! Good luck putting the door together!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
93' Heater failure. Possible thermostat failure? Yota_master 89-95 Toyota Pickup/Hilux 9 10-22-2008 10:25 PM
97 Avalon Power Steering Failure parimento1 1st Generation (1995-1999) 5 07-15-2008 05:31 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Have You Had A Power Steering Pump Failure? haa21 Camry & Solara Lounge 3 02-23-2004 07:31 PM
Total Electrical System Failure sargeusmc57 Camry & Solara Lounge 0 12-21-2002 03:55 PM
