Replacing SUV tire(s) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2006, 03:13 PM   #1 (permalink)
Walter Cohen
Guest
Posts: n/a
View Walter Cohen's Photo Gallery
I had a flat tire on the front passenger side tire on my SUV. My wife
didn't know about it and started driving, not realizing the tire was flat,
and a few minutes later came back and told me about it. I'm not sure how
far she drove on a flat tire (never a good thing to do). Anyway, I
temporarily put the spare donut tire on the car and took the wheel/tire to
Sears.
I told them to just fix the flat. They said they couldn't because the tire
was damaged from driving while the tire was flat. Ok, then I said replace
the tire with a new one. He said that's fine but they could/will not mount
it for me because the car is 4WD and the tread depth on the one new tire
would be som much more/taller than the remaining 3 that it could damage the
gear box. They are not authorized to put just one new tire on a 4WD
vehicle. I then said, ok give me two new tires then and put them both on
the same axle. Again they said no as they could not - for the same reason
about the gear box stuff.
So I eventually caved in (perhaps I should not have) and purchased 4 new
tires for the car. I did not want to do that as about 18 months earlier I
had already purchased 2 new tures for the rear. So $600 later, instead of
$125 later I have 4 new tires....
Does this sound right? Did I waste my money buy having to put 4 new tires
on the car to have the same tiure tread depth to not damage the gear box?
I'm thinking of calling Sears and discussing and maybe complaining to them.
What is the deal on a 4WD car and tires with different tread depths?
Thanks,
Walter
Old 10-01-2006, 05:28 PM   #2 (permalink)
SilverStude
Guest
Posts: n/a
View SilverStude's Photo Gallery
Re: Replacing SUV tire(s)
Walter Cohen wrote:[color=blue]
> Sears.
> Thanks,
> Walter
>[/color]
Well, they got what they wanted... your $. Did you get what you wanted?
If the 1st tire was damaged enough to replace, then yes replace it. The
tread depth on most tires is around 5/16"... If the tire you damaged
was a 265/65R16 ( just for example) was half worn and you put a new one
on, the difference in tread height would be maybe 3/16".... let's do
some math
265 / 25 = 10.6" * .65 = 6.89" * 2 = 13.78" + 16 = 29.78" tire
diameter .. 29.78 * pi (3.1415) = 93.55" circumference..... 93.55 /
12 = 7.79' .... 5280 / 7.79 = 677 revolutions per mile for your new
tire.
29.78 less 3/16"(.1875) = 29.59" diameter * pi = 92.92" /12" =
7.74'... 5280 / 7.74' = 682 rev per mile......
So you old tires would revolve 5 turns more per mile than the new
one. I don't think that would be too bad considering what cornering,
turns and scrubbing would to to negate any ill effects on a hefty a**
third member of a 4WD. So two tires would have been my choice. The
other two wouldn't have made an iota of difference. An AWD car is
managed by the transfer case anyway and a 4WD shouldn't always be in
4WD, unless it's off road or in snow, etc....
Old 10-01-2006, 05:45 PM   #3 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Sun, 1 Oct 2006 16:13:39 -0400, "Walter Cohen"
<w_cohen@hotmail.com> wrote:
<Snip>[color=blue]
>What is the deal on a 4WD car and tires with different tread depths?[/color]
Congratulations, more than likely you've just been ripped off for
three tires. Though to be perfectly honest you didn't state how worn
the old tires were, and if they were down to the wear-bars the tire
store had a valid reason to sell you at least two.
You do not mention exactly what make and model your car is, but the
ONLY time the tires must be the same model and size and fairly close
together in tread wear (outside circumference) is when the car has a
Full-Time All-Wheel-Drive system without a center differential, and
those are fairly rare.
Is yours is a standard part-time four-wheel drive system where you
have to hit a button or pull a transfer-case lever and manually engage
the front hubs to go into 4WD? If so the tires do need to be the same
make and model and basic tire size, but the exact tire diameters from
wear are not overly crucial. As long as they aren't worn below the
safe minimum tread or otherwise coming apart, they're fine.
The tires will always spin at slightly different speeds from
cornering, but you are in the dirt, mud, snow, etc. and the wheel slip
on the reduced traction surfaces will relieve any possible drivetrain
wrap-up stresses.
Then again, Sears has been busted over and over for selling unneeded
parts and services - from replacing "worn brakes" that were almost new
right down to those fraudulent practices from the 1930's that still
work in 2006 (if nobody spots them), like squirting a bit of oil on
the shock absorbers to show you that 'the shocks are leaking and must
be replaced'.
The California DMV Bureau of Automotive Repair almost yanked Sears'
licenses several times. Along with several other big chain stores.
Here's the "Money Paragraph" -
[url]http://www.autorepair.ca.gov/stdPAge.asp?Menu=/includes/Menu_GenInfo.htm&Body=/Geninfo/Factsheets/BAR_Enforcement.htm[/url]
[color=blue]
>BAR> FALSE AND MISLEADING STATEMENTS: BAR can take administrative
>BAR> action against an auto repair dealer for making false or misleading
>BAR> statements to a customer. When a technician uses scare tactics to
>BAR> coerce a customer to authorize unnecessary repairs – a practice called
>BAR> “oversell” – he or she has violated the Automotive Repair Act. A twist
>BAR> on this scenario involves advertising a service at an incredibly low
>BAR> price. After the customer leaves their car for the low-priced special
>BAR> service, an unscrupulous shop may attempt to convince the customer
>BAR> that they need costly, additional – and often unnecessary – parts and
>BAR> service.[/color]
Seems that every Mechanic and Customer Service Rep at these national
and regional chain stores has a quota of sales to meet. Corporate
wants each and every employee to push every service they see that is
applicable to get add-on sales out of every single customer that walks
in the door, so your report is not surprising.
Jiffy Lube gets you in the door for a '$19.99 Oil Change Special',
but their corporate policy is to sell at least $60 to every customer -
and to do that "every 3,000 Miles", of course.
And if they have to stretch the rules and cite nonexistent "safety
rules" and "federal laws" to make that "oversell" sale, they'll do it.
If they quote a rule or law to get you to buy, you have every right to
have them show it to you in writing - put up or shut up.
Some of it is to avoid liability suits - their lawyers not wanting
to let you out the door on marginal tires where they can get sued
after the accident. But most of it is pure "revenue enhancement".
They operate under the age-old principle that there's a sucker born
every minute. You have to remain eternally vigilant to ensure you
aren't one of those suckers.
--<< Bruce >>--
Old 10-01-2006, 05:47 PM   #4 (permalink)
Bonehenge
Guest
Posts: n/a
View Bonehenge's Photo Gallery
On Sun, 01 Oct 2006 22:45:16 GMT, Bruce L. Bergman
<blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
>[/color]
Actually, my 2001 Subaru did have a center diff, and they had some
clearly stated specs for tire replacement and allowable circumference
differences.
I don't think it's all that rare for AWD cars.
Old 10-01-2006, 07:43 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"SilverStude" <rfjohnstone@Cox.net> wrote in message
news:cgXTg.7317$Go3.702@dukeread05...[color=blue]
> Walter Cohen wrote:[color=green]
>> flat,
>> to
>> Sears.
>> tire
>> replace
>> mount
>> the
>> reason
>> I
>> of
>> tires
>> them.
>> Thanks,
>> Walter
>>[/color]
> tread depth on most tires is around 5/16"... If the tire you damaged was
> a 265/65R16 ( just for example) was half worn and you put a new one on,
> the difference in tread height would be maybe 3/16".... let's do some
> math
> 265 / 25 = 10.6" * .65 = 6.89" * 2 = 13.78" + 16 = 29.78" tire diameter
> .. 29.78 * pi (3.1415) = 93.55" circumference..... 93.55 / 12 = 7.79'
> .... 5280 / 7.79 = 677 revolutions per mile for your new tire.
> 29.78 less 3/16"(.1875) = 29.59" diameter * pi = 92.92" /12" = 7.74'...
> 5280 / 7.74' = 682 rev per mile......[/color]
The tread depth on most new tires is actually closer to 5/16" for passenger
car tires and 11/32 or 4/8" for truck tires.
[color=blue]
> So you old tires would revolve 5 turns more per mile than the new one.
> I don't think that would be too bad considering what cornering, turns and
> scrubbing would to to negate any ill effects on a hefty a** third member
> of a 4WD. So two tires would have been my choice. The other two wouldn't
> have made an iota of difference. An AWD car is managed by the transfer
> case anyway and a 4WD shouldn't always be in 4WD, unless it's off road or
> in snow, etc....
>[/color]
AWD vehicles generally have a center differential; 4WD vehicles have a
transfer case.
Ray O
Old 10-01-2006, 08:54 PM   #6 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Sun, 01 Oct 2006 16:13:39 -0400, Walter Cohen wrote:
[color=blue]
> Sears.
> Thanks,
> Walter[/color]
Are you kidding me?
a 1/8" difference in tread size is NOT going to throw the differential off
that much! I could see if you had, say, 225/60-16 on one axle and
235/60-16 on antoher axle, but the difference in tread (from the same make
and model tire) is not going to make that much difference!
I have 205/75-15s on the front of my Grand Voyager, and 215/70-15's on the
rear. The system is full time AWD with a fluid trtansfer in the middle of
the van. Close enough for government work!
And, if you have a Transfer Case, chances are you're in RWD except when
the going gets slippery, and when it DOES get slippery, it gives the tires
enough leeway to not make a difference over tread depth!
Old 10-02-2006, 06:26 AM   #7 (permalink)
Walter Cohen
Guest
Posts: n/a
The car is a 1999 Mercedes ML320 SUV.
The two rear tires (different axle than the busted tire) were in relatively
good shape, not near the wear bars. The other front tire I could make a
case for replacing, and I did suggest that option to the sales rep and again
he said he still wouldn't mount them for me; sell them to me yes, mount them
on the car - no.
Walter
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:4od0i2plkhjqfd1knfd0npk64q1dmap6ch@4ax.com...[color=blue]
> <Snip>[color=green]
>>them.
> wrap-up stresses.
> be replaced'.
>[color=green]
>>BAR> coerce a customer to authorize unnecessary repairs - a practice
>>called
>>BAR> "oversell" - he or she has violated the Automotive Repair Act. A
>>twist
>>BAR> that they need costly, additional - and often unnecessary - parts and
> --<< Bruce >>--
>[/color]
Old 10-02-2006, 08:04 AM   #8 (permalink)
C. E. White
Guest
Posts: n/a
View C. E. White's Photo Gallery
----- Original Message -----
Newsgroups: alt.autos.toyota,alt.autos
Sent: Sunday, October 01, 2006 4:13 PM
Subject: Replacing SUV tire(s)
[color=blue]
> Sears.
> tire
> mount
> the
> them.
> Thanks,
> Walter[/color]
What was your vehicle? What size was your doughnut tire? If driving around
with different size tires was likely to damage the 4WD system, then the
vehicle manufacturer would have included a spare with the same OD.
There is an interesting thing about radial tires that comes in to play. The
OD of the tire has only a secondary affect on the rolling radius (the
dimension that affect the number of revolutions per mile). The tread
sections act more like a tank tread than the outside diameter of a solid
wheel. The actual rolling radius is mostly dependent on the radius of the
steel belt instead of the outside diameter of the tread. For instance, a
Michelin CrossTerrain P235R16 Tire has an outside diameter of 29". If this
was a hard wheel with a 29" diameter, it would take 695.4 revolutions of the
wheel to go one mile. According to the Michelin specs, the actual number of
revolutions per mile is 720 (at 45 mph - speed is a factor because it
changes the tire diameter slightly). 720 revolutions per mile gives you an
effective diameter of 28". This is close to the diameter of the steel belt
inside the rubber. This diameter of the steel belt is not effected by
wearing the tread down. There is some slight change in rolling diameter as
the tread is worn away, but not to the extent the outside diameter change
would indicate. In the case of the Michelin P235R16 tires, the tread depth,
was 10/32. Even if the effective rolling diameter was decreased from 29" to
28.4" (new to bald), the theoretical number of revolutions per mile would
have only changed from 695.4 to 710.1. Any system that can't handle 15
revolutions in a mile is already defective. Going around corners is a more
significant difference than that. And in actual fact the difference in
effective rolling diameter between the new tire and the old tire (assuming
the same brand, size, and type) was probably more like 5 revolutions per
mile and probably less.
I think it was justifiable to replace two tires (the bad one and the other
one on the same axle). Replacing four was totally unnecessary. And didn't
warning bells go off when this tire store forced you to buy four tires since
18 months earlier you had already just replaced two of the four?
Ed
BB code is Off
Smilies are Off
[IMG] code is Off
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 10:53 PM
Help with rims and tires!!! rpj1984 Camry & Solara Lounge 0 09-30-2002 11:31 AM
