transmission drain plug and capacity: 2000 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2006, 09:14 PM   #1 (permalink)
gp
Guest
Posts: n/a
View gp's Photo Gallery
I just replaced the transmission fluid (dexron III from toyota). I
pulled out about 3.3 litres but put back in the specified amount of 3.1
L (it is a 4 speed automatic). The manual says to check the dipstick,
but difficult to read as the fluid smears along the dipstick --I am
good with the oil changes, not so good here. It seems like where it is
solid is on the upper end of the cold, the dipstick has 2 v-grooves for
cold and I put it at the 2nd or higher level indicating v-groove if
that makes sense.
Also, it seems I may have stripped the drain plug and if so, it did not
take much. No fluid is leaking but essentially, when I try to tighten
it eventually loosens so that I can turn it by hand so I tightened it
to just until it gives. It has 80,000 km and the plug was surprisingly
easy to remove --any thoughts on whether it is/was stripped, whether a
washer is crushed. Prefer good news.
Back the the refill, I filled it with 3 litres, started the vehicle and
ran it through Low to Park a few times and the put in park and idled
for a while. Does that sound like the right procedure?
Appreciate any help.
Old 10-02-2006, 11:17 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: transmission drain plug and capacity: 2000 corolla
"gp" <gpagmail-news@yahoo.com> wrote in message
news:1159841694.667542.282840@b28g2000cwb.googlegroups.com...[color=blue]
> that makes sense.[/color]
You may want to double check the correct transmission fluid. I am not sure
when Toyota changed over to T-IV, but if T-IV is specified, I'd drain and
replace with the correct fluid.
[color=blue]
> washer is crushed. Prefer good news.[/color]
A stripped drain plug is bad news. If it leaks, you can ruin the
transmission. You can either replace the transmission pan or try to have it
filled in and re-tapped.[color=blue]
> Appreciate any help.[/color]
Yes.
Ray O
(correct punctuation to reply)[color=blue]
>[/color]
Old 10-02-2006, 11:36 PM   #3 (permalink)
gp
Guest
Posts: n/a
tomorrow, I am going to buy a new drain plug/washer and keep my fingers
crossed. A bit surprised that it striped so easily.
The fluid is correct as listed on the dip stick, owner's manual and as
given to me by the toyota part's dept based on the vehicle VIN. I too
was worried about ensuring I was using the right fluid.
Ray O wrote:[color=blue]
> news:1159841694.667542.282840@b28g2000cwb.googlegroups.com...[color=green]
>[color=green]
> filled in and re-tapped.[color=green]
> Yes.
> Ray O
> (correct punctuation to reply)[color=green]
> >[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
2000 Camry Maintenance Diy Tips cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-26-2011 11:04 PM
