Toyota Corolla does not start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2006, 08:01 PM   #1 (permalink)
captj
Guest
Posts: n/a
View captj's Photo Gallery
The car was stolen and then recovered. Replaced ignition switch and
housing. New battery, distibutor cap and rotor. Current is present at the
coil (inside cap) using test light. The engine cranks over but there is no
spark at the plug. The air bag light stays on (is there a connection to
this problem). A screw driver was used by the thieves to start and drive
the car. Any suggestions on why the car will not start or show spark at
the plugs.
Old 10-03-2006, 08:07 PM   #2 (permalink)
captj
Guest
Posts: n/a
Re: Toyota Corolla does not start, its a 1994
The car is a 1994 corolla forgot to mention that
Old 10-03-2006, 08:16 PM   #3 (permalink)
n.torrey.pines@gmail.com
Guest
Posts: n/a
View n.torrey.pines@gmail.com's Photo Gallery
captj wrote:[color=blue]
> The car is a 1994 corolla forgot to mention that[/color]
OMG, they steal '94 Corollas?! Should I start chaining my '95 Prizm to
street lights, lest it gets stolen too?
Old 10-03-2006, 08:42 PM   #4 (permalink)
Reasoned Insanity
Guest
Posts: n/a
View Reasoned Insanity's Photo Gallery
<n.torrey.pines@gmail.com> wrote in message
news:1159924591.473437.116680@h48g2000cwc.googlegroups.com...[color=blue]
> captj wrote:[color=green]
>[/color]
My 95' Prizm is the first car I've ever had that was nice enough to lock so
I'm always sure to lock it up.
Old 10-03-2006, 08:47 PM   #5 (permalink)
Andrew Stephenson
Guest
Posts: n/a
View Andrew Stephenson's Photo Gallery
In article <1159924591.473437.116680@h48g2000cwc.googlegroups.com>
[email]n.torrey.pines@gmail.com[/email] writes:
[color=blue]
> Prizm to street lights, lest it gets stolen too?[/color]
Is there that much of a market for stolen street lights?
Andrew Stephenson
Old 10-03-2006, 09:28 PM   #6 (permalink)
View toyomoho's Photo Gallery
Check for spark at the coil wire. If none, check for DC power getting to the igniter and coil. If power is there, could be the igniter, coil, ECU, wiring problem, fuse. The airbag light being on means the system is not working. A trouble code should be stored in the ECU and available for readout. This year of car may not need a separate troublecode reader. As the car was stolen, make sure the airbags are still installed.
toyomoho is offline
Old 10-03-2006, 11:38 PM   #7 (permalink)
Carl
Guest
Posts: n/a
View Carl's Photo Gallery
My '93 Dynasty was stolen with 180,000 miles on it. They took the engine and
transmission. Poor bastards, that thing leaked so much oil and trans fluid
and coolant and power steering fluid...
Carl
>[/color]
Old 10-04-2006, 08:09 PM   #8 (permalink)
captj
Guest
Posts: n/a
Thanks for the suggestions
BB code is Off
Smilies are Off
[IMG] code is Off
If you have the chk engine light for the evaporative emission. toyota may cover it! popeye08 Camry & Solara Lounge 1 12-15-2010 01:01 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
'94 Corolla won't start sometimes, will others... Lee280zx Hardcore Tech and Competition 5 06-23-2004 09:14 PM
Toyota Hits Record CDNVITZ General Discussion 0 02-06-2004 01:27 AM
