Procedure for changing transmission fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2006, 08:51 AM   #1 (permalink)
Samuel
Guest
Posts: n/a
View Samuel's Photo Gallery
I tried to drain the auto trans fluid and refill it, but it goes back to
dirty for a short time, say 2 months. Is any specific procedure for changing
the fluid? I heard someone saying that I need to wash the transmission by
the new transmission fluid for a few times, how?
Thanks in advance
Sam
Old 10-04-2006, 10:41 AM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Procedure for changing transmission fluid
On Wed, 04 Oct 2006 23:51:52 +1000, Samuel wrote:
[color=blue]
> Thanks in advance
> Sam[/color]
You don't say what model (really not that important) or How many miles
(REALLY IMPORTANT!)
If it is a newer car and has had somewhat routine service, you can try
having the transmission flushed. Some say, if the trans has been serviced
regularly this is OK, but I still shy away, since they use a base of
DexronII-Mercon with 'modifiers' for other types like Chrysler ATF+3 or +4.
Not my idea of a good job...I have also personally seen two older Escort
trannies go belly up after being flushed, having never had service before.
There are about 12-16 QTS of fluid. Changing out 3-4 at a time at least
gets fresh fluid in there, and replenishes the friction modifiers and
detergents.
If you're really nervous about it, drive for 3-7,000 miles, and do it
again! It will take about 5-6 changes to change out about 50% of the
tranny fluid.
A word: If your transmission fluid is BLACK, it is probably NOT a good
idea to change too much of it at once. See that Black stuff? THAT is
mostly what is providing the friction for the car to move!!!
Old 10-05-2006, 05:40 AM   #3 (permalink)
Samuel
Guest
Posts: n/a
My car is 2004 Corolla 1ZZ-FE engine, I am a driving instructor, so I've
already driven the car for 120000km within 2 years!!
"Hachiroku" <Trueno@ae86.gts> ???????:ECQUg.1763$We.636@trndny08...[color=blue]
>[color=green]
>> changing
>> Thanks in advance
>> Sam[/color]
> (REALLY IMPORTANT!)
> +4.
> detergents.
> tranny fluid.
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
DIY flush transmission fluid popeye08 Camry & Solara Lounge 6 07-02-2010 11:10 AM
power steering fluid colour!? wtf 95 COROLLA Archived Corolla threads 14 06-02-2009 10:18 AM
Transmission Fluid Change? James Schmidt 1st Generation (1995-1999) 3 08-10-2006 03:49 PM
Transmission fluid drain % total1 General Discussion 7 06-03-2005 07:28 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
