Re: 1994 Toyota Camry QUESTION FOR RAY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2006, 11:59 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"mack" <mackerel@dslextreme.com> wrote in message
news:12i930l7d78to38@corp.supernews.com...[color=blue]
> Ray,
> In a case like this, IF (as happened to me once with a 1986 Camry)
> something has happened to the timing belt (it happened to me in our
> driveway) and the car turns over but has no intention of starting....how
> can you diagnose it and pinpoint the timing belt as the culprit?
> Is there a peephole in the shroud thru which you might look to see if the
> belt's moviing as the starter grinds?
> Thanks![/color]
If the timing belt has jumped a tooth the only way to check is to pull the
timing belt cover and visually look at the marks on the camshaft pulleys
when #1 cylinder is at top dead center compression. The likelihood that the
timing belt has jumped a tooth is pretty slim.
If the timing belt is broken, then there are other symptoms. The engine
will crank more quickly than normal because there is no compression for the
starter to overcome and if there is conventional distributor, the
distributor rotor will not turn because the camshaft is not turning. I am
not aware of a peephole in the timing belt cover, but you may be able to
loosen a few bolts enough to pull the cover back enough to see what is
happening.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota History BLUEMEANIE General Discussion 29 06-14-2009 05:56 AM
1994 Camry Reverse Light Question kc3k7 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-29-2006 08:36 AM
1994 Toyota Camry LE Steering Question kc3k7 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-27-2006 07:06 PM
1994 Toyota Camry 5S-FE Parts Car.... 1fastLE Vehicles 9 10-28-2004 10:18 AM
