You gave me some pointers re: overheating 4AC earlier on.
I'm still not convinced that it is overheating [1] and have been logging
temp readings. What would Toyota's max temp for the 4AC 1.6 be?[2].
Cheers
H
[1] No coolant loss, no contamination of fluids etc etc and the erratic
nature of tacho and temp gauge (not dissimilar to a volvo and VW that had
poorly connected voltage regulators on/in the circuitry of the gauge).
On Fri, 06 Oct 2006 14:25:23 +0000, Hammo wrote:
[color=blue]
> Hi Ray O
> Cheers
> H
> [2] I'm guessing 130 degrees Celsius?[/color]
130C seems a bit high! (When you consider 100 is Boiling)
Now, are you talking COOLANT temps, or are you measuring the engine itself?
Seems to me on this engine, about 190-200 would be the max for coolant
temps (that's Degrees F, BTW)
"Hammo" <hbaj2006@aapt.net.au> wrote in message
news:C14CA46E.DA10%hbaj2006@aapt.net.au...[color=blue]
> Hi Ray O
> Cheers
> H
> poorly connected voltage regulators on/in the circuitry of the gauge).[/color]
By any chance, are there any aftermarket accessories installed like fog
lights, audio system, security system, remote start, etc.? If so, check the
installation very carefully to make sure any power taps or screws are not
causing the problem.
This is not easy, but you may want to check to make sure the connectors in
the back of the instrument cluster are tight and ground connections are
tight. I believe that there is a voltage regulator on the back of the
instrument cluster, but they do not fail very often.[color=blue]
>[/color]
Without looking at the actual specifications, I can't say for sure, but I do
not think the max temp is that high. My guess would be in the 115 to 200
Celsius range.
If you can get a hold of a factory repair manual, there are voltage or
resistance specifications for temperature sender output. You can measure
the voltage at the sender and then again at the instrument cluster to see if
they are the same. The repair manual also shows how to diagnose whether the
instrument cluster is working or not.
On 7/10/06 1:18 AM, in article
86393$452674d3$44a4a10d$11521@msgid.meganewsservers.com, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
> news:C14CA46E.DA10%hbaj2006@aapt.net.au...[color=green]
>> Hi Ray O
>> Cheers
>> H
> causing the problem.[/color]
There are several and I am not convinced that they haven't caused the
problem. The quickest (and hence most efficient) way to check the actual
temp was to insert a thermocouple into the coolant stream at roughly the
same point as the temp sender and compare. The only draw back of this
method is that I do not know the maximum operating temp slated for the 4AC
motor.[color=blue]
> instrument cluster, but they do not fail very often.[/color]
True, but things fail and considering I have experienced this problem before
in other vehicles, I don't consider it outside the realms of probability.
The thermocouple shows a temp of 110 and the gauge is _above_ red, which is
just not possible (without the usual obvious signs of overheating).[color=blue][color=green]
>>[/color]
> Celsius range.[/color]
That is the normal op temp, or do you mean max temp that should result in
the engine being damaged?[color=blue]
> instrument cluster is working or not.[/color]
I have replaced the sender unit and both unit where within a small amount of
the other in terms of voltage. How this translates into temperature, I
don't have that manual with me, nor do I have with me a device to increase
the voltage to ensure I have the correct voltage is applied to the gauge.
On 7/10/06 1:15 AM, in article dquVg.19$HP.18@trndny08, "Hachiroku"
<Trueno@ae86.gts> wrote:
[color=blue]
>[color=green]
>> Hi Ray O
>> Cheers
>> H
> 130C seems a bit high! (When you consider 100 is Boiling)[/color]
100 is only boiling when coolant is pure water and does not include
dissolved salts. Also, as the coolant is in a pressurised system, boiling
at 100 would not make any sense.
[color=blue]
> Now, are you talking COOLANT temps, or are you measuring the engine itself?[/color]
Coolant[color=blue]
> temps (that's Degrees F, BTW)[/color]
Why so low? I have a pressurised system in the 4AC.
news:C14D5C37.E1D7%hbaj2006@aapt.net.au...[color=blue]
>[color=green]
>> news:C14CA46E.DA10%hbaj2006@aapt.net.au...[color=darkred]
>>> Hi Ray O
>>> Cheers
>>> H
>>> had
>> the
> motor.[color=green]
>> in
> before
> is
> just not possible (without the usual obvious signs of overheating).[/color]
Assuming that the thermocouple is correct, then the gauge must be incorrect.
[color=blue][color=green][color=darkred]
>>>[/color]
>> do
> the engine being damaged?[color=green]
>>[/color][/color]
Oops! That was a typo! I meant that my guess was 115 to 120 degrees
Celsius. I've since checked the factory repair manual for a Previa, and the
max temp is 110 to 120 degrees Celsius so my guess (at least the one I was
thinking of and not what I typed) was in the right ballpark.
That max temp range is the temp at which the pressure relief in the radiator
cap would open and let the coolant go into the overflow bottle.
>> if
>> the
> of
> Many thanks for your input.
> Hammo
>[/color]
I'm thinking that the problem is with the voltage regulator at the back of
the instrument cluster. I suspect that replacing it involves replacement
of the entire cluster. As a work around, you can install an aftermarket
temperature sender and gauge.
news:C14D5D7F.E1D9%hbaj2006@aapt.net.au...[color=blue]
>[color=green]
>>[color=darkred]
>>> Hi Ray O
>>> Cheers
>>> H
>>> had
>[color=green]
>> itself?[/color]
> Coolant[color=green]
> Cheers
> H
>[/color]
Yup, a pressurized cooling system with a proper mixture of
antifreeze/coolant will raise the boiling temperature, much like a pressure
cooker. This allows the engine to operate at a more efficient temperature
range.
On 7/10/06 2:26 PM, in article
c18c1$45272cc7$180ffe52$17443@msgid.meganewsservers.com, "Ray O"
[color=blue]
> news:C14D5C37.E1D7%hbaj2006@aapt.net.au...[color=green]
>>[color=darkred]
>>>> Hi Ray O
>>>> Cheers
>>>> H
>>>> had
>>> the
>> motor.[color=darkred]
>>> in
>> before
>> is
> Assuming that the thermocouple is correct, then the gauge must be incorrect.[/color]
I agree with you here. I wasn't sure what the maximum operating temp would
be and as the temp gauge was constantly in the red, I was getting
uncomfortable about destroying the car![color=blue]
>>> do
>> the engine being damaged?[color=darkred]
>>>[/color][/color]
> thinking of and not what I typed) was in the right ballpark.[/color]
I agree with that too. I take it boiling would occur and damage would be
beyond that limit. The aftermarket gauge I got had a bulb on it that was
and inch too long to fit into the temp sender "hole". It had an upper limit
of 267 Farnheit!! The mid range was 116 celcius (~240 F).[color=blue]
> cap would open and let the coolant go into the overflow bottle.[/color]
------snippp-------[color=blue][color=green]
>> of
>> Hammo
>>[/color]
> Sorry I haven't been more help![/color]
news:C14DBBC2.E286%hbaj2006@aapt.net.au...[color=blue]
>[color=green]
>> news:C14D5C37.E1D7%hbaj2006@aapt.net.au...[color=darkred]
>>>>> Hi Ray O
>>>>> logging
>>>>> Cheers
>>>>> H
>>>>> erratic
>>>>> had
>>>> check
>>>> the
>>>> not
>>> actual
>>> 4AC
>>> motor.
>>>> in
>>> before
>>> probability.
>>> is
>> incorrect.[/color]
> would
> uncomfortable about destroying the car![color=green]
>>[color=darkred]
>>>> I
>>>> do
>>>> 200
>>>> Celsius range.
>>> in
>>>>[/color]
>> the
>> was
> limit
> of 267 Farnheit!! The mid range was 116 celcius (~240 F).[color=green]
>> radiator
> ------snippp-------[color=green][color=darkred]
>>> amount
>>> of
>>> increase
>>> gauge.
>>> Hammo
>>>[/color]
>> of
>> replacement
> You were helpful indeed!
> Cheers
> Hammo
>[/color]
