2007 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2006, 01:36 PM   #1 (permalink)
bob
Guest
Posts: n/a
View bob's Photo Gallery
2007 Camry
I am going to purchase a 2007 Camry, however, it doesn't have Xenon
headlights. I was hoping someone could help with the process of
putting these on.
Old 10-06-2006, 01:59 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2007 Camry
"bob" <bobcherney@gmail.com> wrote in message
news:1160159809.091802.77480@c28g2000cwb.googlegroups.com...[color=blue]
> putting these on.
>[/color]
If you want help with the process of installing Xenon headlights, potential
helpers probably would want to know where you are so they know if you are
within a reasonable travel distance or not.
If you want an explanation of what it takes to install high intensity
discharge (HID) headlamps, I recommend a google search of "xenon
headlights."
Note that most of the aftermarket conversion kits are for export only and
not designed for use in the U.S.
There are blue-tinted bulbs that make the light appear to be HID.
The HID conversions basically involve mounting a ballast in the vicinity of
the headlamps and then changing the OEM bulb and wire harness over to the
aftermarket one.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
2007 V6 LE Camry - What did you pay? villron 5th & 6th Generation (2002-2006 & 2007-2011) 58 09-19-2006 08:18 PM
2007 Camry SE V6 Performance/Traction Control wireless 5th & 6th Generation (2002-2006 & 2007-2011) 6 04-22-2006 01:37 PM
2007 Camry Seat Belt Trunk Sunroof Problems. Rotten Eggs grosenbeck 5th & 6th Generation (2002-2006 & 2007-2011) 4 04-19-2006 10:17 PM
