Toyota Sienna: start and then shut off - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2006, 08:52 AM   #1 (permalink)
dig314@gmail.com
Guest
Posts: n/a
View dig314@gmail.com's Photo Gallery
I have had a used 2002 Toyota Sienna ( 68k miles ) for about a year and
a half. One day in the summer, I drove it to the mountains. Once I
arrived, the van was shut off for about a couple of hours...then the
van had trouble running. It would start, but immediately shut off. If I
keep my foot on the gas pedal it would rev up, but stall out as soon as
I took my foot off the gas. Of course, you can't put it in gear
without your foot on the brake. Eventually, I thought to open up the
gas cap, which appeared to release a large amount of pressure. Then the
van started normally and drove fine.
Well, it happened again this weekend. Except, the van was at home and
had only been driven around town the day before. I opened up the gas
cap and a little pressure came out. But, even after that, the van would
only run if I kept a foot on the gas. Again, it would rev up and
immediately stop when I let off the gas.
The indicator lights seems to turn off while the engine is running.
What could cause this? Something going foul in the Electronics? I dread
taking any vehicle in that has an intermittent problem.
Thanks for your suggestions.
Dig314
Old 10-08-2006, 01:51 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyota Sienna: start and then shut off
<dig314@gmail.com> wrote in message
news:1160315526.328444.213990@e3g2000cwe.googlegroups.com...[color=blue]
> Dig314[/color]
Several things can cause the condition you are describing, including fuel
pressure regulator, fuel pump, coolant temperature sender, and idle air
control valve. Replacing those components without checking them is
expensive, I recommend that you take it to the dealer for diagnosis and
repair.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
