Re: Compressor?
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:b57e3$4529d839$180ffe52$7284@msgid.meganewsservers.com...[color=blue]
> "Mama Bear" <MamaBear@No-Spam.noo> wrote in message news:Xns9856E66756961Mama@216.196.97.142...[color=green]
>> What would be a good portable air compressor to get, that wouldn't cost a
>> lot, would be good for filling the car tires when they get low, and also
>> for blowing out the sprinkler system in the fall?
>> Do they have units small enough to fit in the spare tire well for this?
>> I have a 93 Corolla Wagon.
>> - Mama Bear[/color]
> A 12 volt compressor that runs off the cigarette lighter and fits in the trunk of the car is sufficient to fill tires when they
> get low, however, they take will take several minutes to fill a tire.
> Unfortunately, as 12 volt compressor does not put out enough air volume to blow out a lawn irrigation system. To blow out a lawn
> irrigation system, you will need a compressor with a capacity of around 12 cubic feet per minute (CFM) at 40 pounds per square
> inch (PSI). A 2 horsepower or larger compressor should do the trick, but it will be 110 or 220 volts.
> Ray O
> (correct punctuation to reply)[/color]
Another option could be the 12 volt compressor for your trunk. And then a portable tank for compressed air.
You can buy one complete, or kits (or make one) to use something like a empty refrigerant jug. A 30lb jug
works great for inflating a totally flat car tire. Its fast and you can refill it from any source that can fill a tire.
If I think my tire might go flat its the jug, not the 12v compressor I toss in my trunk.
If you use a refrigerant jug the reusable type are nice. The 30 pound are common but if you find a 50 pound
jug I bet it would hold enough air to fill two full size car tires. They all have a safety pressure release of some type
but I'm sure its well over the 180 lbs or so air compressors can do.
Dan
